maahee Posted November 12, 2025 Posted November 12, 2025 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; CASE 1 (setq ss (ssadd)) (if (not (ssmemb n ss)) (ssadd n ss) ;code );if ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; CASE 2 (setq flag T) (while flag (setq obj (ssget "_:S")) (cond (obj ;CODE ) ;ar (t (princ "\nNo selection made.") (initget "X") (setq bm (strcase (getstring "\nEnter 'X' to exit or press Enter to continue [X]: " ) ) ) (if (= bm "X" ) (setq flag nil) ; Exit the loop if user types 'x' (princ "\nInvalid input. Please try again.") ) ;if ) ) );WHILE ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; CASE 1: If the dataset is large, it will slow down the process. alternatives or tricks. CASE 2: Press the Enter key once to continue the loop, and press it twice to exit. or Only the letter "x" and empty inputs are acceptable. Quote
mhupp Posted November 12, 2025 Posted November 12, 2025 I'm not quite sure what your asking to optimize. Quote
maahee Posted November 12, 2025 Author Posted November 12, 2025 (edited) @mhupp Case 1: I want to reduce the time. I use the "not (ssmemb n ss)" function, but it takes a long time when the selection set is large. case 2: Press the Enter key once to continue the loop, and press it twice to exit. ( empty selection set handle) The above two cases do not relate to each other. Please Edited November 12, 2025 by maahee Quote
mhupp Posted November 12, 2025 Posted November 12, 2025 I understand what your asking for in case1 case2. I am asking is why your using them. might be a better optimization in how your selecting things. just asking for a higher level of what your trying to do. Quote
Steven P Posted November 12, 2025 Posted November 12, 2025 (edited) Case 1: ssadd does a check if the entity exists in the set, you can change CASE 1 (setq ss (ssadd)) (if (not (ssmemb n ss)) (ssadd n ss) ;code );if to CASE 1 (ssadd n ss) ;code Often in code optimisation is rarely a single line that makes a difference... unless you are doing thousands of calculations, so here taking out an if statement won't do a lot. Most likely you have a loop within a loop that slows things - might be more efficient to look back at how you are selecting the entities and processing them before adding to the selection set. However don't just accept that, if you code will work without the line take out your if statement, and ssadd and you shouldn't really notice a big difference in speed Edited November 12, 2025 by Steven P 1 1 Quote
Steven P Posted November 12, 2025 Posted November 12, 2025 Case 2: This nicest user friendly way I found.. is not the nicest user friendly way in programming - involves grread which the help suggests is rarely needed and for advanced users.... grread if the input is keyboard or mouse input. If keyboard check if it is enter, X, space or escape (enter, space, escape got to use character codes) else ignore text inputs. If mouse input check if they have selected an object or just clicking empty space However the help suggests doing this in other ways. For both cases, and MHUPPs question what is the goal you are wanting to achieve. 1 Quote
mhupp Posted November 12, 2025 Posted November 12, 2025 (edited) 3 hours ago, Steven P said: Case 2: However the help suggests doing this in other ways. Have a progress output to the bottom left for long process is always a good idea because people will cancel commands that they think are hung. https://www.cadtutor.net/forum/topic/75702-all-objects-inside-this-selection-want-to-send-layer-0/#findComment-598604 in the update loop if user hits esc exit lisp Edited November 12, 2025 by mhupp 1 Quote
BIGAL Posted November 12, 2025 Posted November 12, 2025 Like others I really don't understand what your trying to do. You talk about large data sets but what are they and what exactly are you trying to do ? I use a group lists function to look at groups of common item where say 1st item in a sub list is the same, speeds up searches. Quote
maahee Posted November 13, 2025 Author Posted November 13, 2025 (edited) (defun C:123 () (setq ss (ssadd)) (setq i 0) (while (setq m (ssget)) ; selected group of line one by one or in group large scale (repeat (sslength m) (setq n (ssname m i)) (if (not (ssmemb n ss)) (progn (ssadd n ss) ;;;;;code ) ;progn (progn (princ) (print "/nduplicate selected line:") ) ;progn ) ;if (setq i (1+ i)) ) ;Repeat (setq i 0) ) ;while loop ) ;defun ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;case 2 ;;;;;Press the Enter key once to continue the loop, and press it twice to exit. (defun C:bm () (setq flag T) (while flag (setq obj (ssget "_:S")) (cond (obj ;CODE ) ;ar (t (princ "\nNo selection made.") (initget "X") (setq bm (strcase (getstring "\nEnter 'X' to exit or press Enter to continue [X]: "))) (if (= bm "X") (setq flag nil) ; Exit the loop if user types 'x' (princ "\nInvalid input. Please try again.") ) ;if ); seo cond ) );WHILE ) @BIGAL Test Lisp for reference. The selection set gradually increases, which takes a long time when it is large. Edited November 13, 2025 by maahee Quote
mhupp Posted November 13, 2025 Posted November 13, 2025 (edited) You can limit what ssget selects by entity, layer, color, size, basically anything in dxf codes. please read up on ssget This means you could just make a window selection. And not have to zoom in and out to make selections. also @Steven P already said "ssadd does a check if the entity exists in the set" check the length of SS before and after to see if it was already in the list. also also looks like your not using localized variables could be why its taking so long. (defun C:123 ( / ss pick l) (setq ss (ssadd)) (princ "\nSelect Entity: ") (while (setq pick (ssget)) (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex pick))) (setq l (sslength ss)) ; Length before adding (setq ss (ssadd ent ss)) ; Try adding entity (if (= l (sslength ss)) ; If length is the same, item was already in list (princ "\n\nDuplicate Selected Line") ) ) (princ (strcat "\n" (itoa (sslength ss)) " Entities now in Selection SS")) ) ; rest of code goes here (princ) ) (defun C:bm ( / ss ent) (while (setq SS (ssget (ssget "_+.:E:S"))) ;exits if selection isn't made (setq ent (ssname ss 0)) ;CODE ) ) Edited November 13, 2025 by mhupp 1 1 Quote
Steven P Posted November 14, 2025 Posted November 14, 2025 Reading about selection sets yesterday, if you are deleting from a selection set within your code, be aware that the entire set is indexed again which can add in delays (set contains entities 1 2 3 4 5 6 78 9, delete entity 5 from the set, then 6 7 8 and 9 are all indexed again to be 5 6 7 8 - time which can add up with very large selection sets). For case 1 I would be considering what you are doing in ';;;;code' to see if there are efficiencies in there (try running it as you write above to get a benchmark for the speed over your large selection set without any other codes) 1 Quote
