Help Appreciated: Force Existing Layer Names to UPPER CASE Not Working
Application: BricsCAD V26
Goal: To modify layer names to display as UPPER CASE from Title Case (Example: From existing layer name as "Trim" to "TRIM")
Issues:
  • As coded, the existing layer names in Title Case are not being processed.
  • The confirmation message wrongly states that UPPER CASE was applied to the layer names when it was not.
Help Needed:
Please review the attached program and suggest needed edits.
Resources
My programming skills continue to grow. I am assembling snippets from various sources.
Best regards,
Clint
UPPERCASE-LAYER-NAMES.lsp
You could try the search function... maybe this thread from lasty week might help?
Edited by Steven P
  • Agree 1
Maybe this kind of solution can be interesting (to use a multiple selection, use Shift+Left mouse click, to use a single selection, use CTRL+Left mouse click):
; Functions     :  CHRENLAYERS
; Description   :  Select Layers To Change It To UPPERCASE Or LOWERCASE
; Author        :  SAXLLE
; Date          :  December 04, 2025
(prompt "\nSelect Layers To Change It To UPPERCASE Or LOWERCASE!\nTo run a LISP type: CHRENLAYERS")
(defun c:CHRENLAYERS ( / old_echo dcl_id fname fn laylist lay items rval acad name)
  (vl-load-com)
  (setq old_echo (getvar 'cmdecho))
  (setvar 'cmdecho 0)
  (create_dialog)
  (collect_layers)
  (setq dcl_id (load_dialog fname))
  (if (not (new_dialog "Laylist" dcl_id))
    (exit)
  (action_tile "cancel" "(cancel)")
  (start_list "ls")
  (mapcar 'add_list laylist)
  (end_list)
  (action_tile "ps1" "(read_items) (to_uppercase)")
  (action_tile "ps2" "(read_items) (to_lowercase)")
  (start_dialog)
  (unload_dialog dcl_id)
  (vl-file-delete fname)
  (gc)
(defun cancel ()
  (done_dialog 0)
  (terpri)
  (prompt "Application running were finished...")
(defun collect_layers ()
  (setq laylist (list)
	lay (tblnext "LAYER" T)
  (while lay
    (if (not (equal (cdr (assoc 2 lay)) "0"))
      (setq laylist (cons (cdr (assoc 2 lay)) laylist)
	    lay (tblnext "LAYER")
      (setq lay (tblnext "LAYER"))
  (setq laylist (vl-sort laylist '<))
(defun read_items ()
  (setq acad (vla-get-activedocument (vlax-get-acad-object)))
  (setq items (get_tile "ls")
	rval (mapcar '(lambda (x) (nth x laylist)) (read (strcat "("  items ")")))
(defun to_uppercase ()
  (foreach item rval
    (setq name (strcase item))
    (vla-SendCommand acad (strcat "-RENAME LA " item (chr 13) name (chr 13)))
    (prompt (strcat "\nThe layer " item " were changed into the UPPERCASE!"))
    (setvar 'cmdecho old_echo)
  (done_dialog 1)
(defun to_lowercase ()
  (foreach item rval
    (setq name (strcase item T))
    (prompt (strcat "\nThe layer " item " were changed into the LOWERCASE!"))
  (done_dialog 1)
(defun create_dialog ()
   (setq fname (vl-filename-mktemp "Laylist.dcl")
         fn (open fname "w")
   (write-line "Laylist
:dialog {
  label = \"Select layers to change it to UPPERCASE or LOWERCASE!\";
  :list_box {
	   key = \"ls\";
	   multiple_select = true;
	   height = 10;
	   width = 50;
   :row {
    :button {
    	label = \"Change to UPPERCASE >>\";
    	key = \"ps1\";
    	fixed_width = true;
    	:button {
    	label = \"Change to LOWERCASE >>\";
    	key = \"ps2\";
    	fixed_width = true;
    :button {
        label = \"Cancel\";
        key = \"cancel\";
        mnemonic = \"C\";
        alignment = centered;
        fixed_width = true;
        is_cancel=true;
}" fn)
  (close fn)
Also, you can see the short video example of how it works.
Best regards.
  • Like 2
Hi Gentlemen,
Your code contributions for my learning is greatly appreciated!
Hi Saxlle,
I thank you for the nice video demonstration as well as the excellent program. It appears that my focus should be more on Visual LISP along with including the Dialog box code within the main program file.
Best regards,
Clint Hill
You're welcome @Clint 🙂. Yes, the DCL file are not necessary every time, but it can be helpful and user-friendly to accomplish desired result (like this one from an example video from above) if you have multiple choosing (for eg. buttons or check-boxes for Uppercase, Lowercase, Renaming, etc.).
Best regards.
Edited by Saxlle
  • Agree 1
Could go with a third Middle option.
(setq layname (ApplyCASE "LAYERNAME"))
LaYeRnAmE
(defun ApplyCaSe (s / i n ch out)
  (setq n (strlen s) i 1 out "")
  (while (<= i n)
    (setq ch (substr s i 1))
    (setq out
      (strcat out
        (if (= (rem i 2) 0)
          (strcase ch T)
          (strcase ch)
    (setq i (1+ i))
  out
-Edit
or a more realistic Option Only first letter UpperCase
Layername
(defun ApplyCase (s / i n ch out)
  (setq n (strlen s) i 2 out (strcase (substr s 1 1) T))
  (while (<= i n)
    (setq out (strcat out (strcase ch))))
    (setq i (1+ i))
  out
Edited by mhupp
@Saxlle just a comment a bit hard to see what is going on in video maybe use a screen area rather than full screen.
Win 11,  Shit+Window+R allows screen area record. Drag window area then start / stop.
This may be useful rather than a list box can tick one or all choices, add an All option so one click. Examples in code.
Multi toggles.lsp
Edited by BIGAL
  • Agree 1
Hit the X button bottom Right.
Edited by mhupp
I found this tool online (screenrec), but I'm not satisfied well. The reason is that I'm the using gifcap, so didn't work properly yesterday when tried to make video, so I find this as alternative.
I've forgotten to mention this Multi toggles as alternative, so I agree with that it can be useful. 👍
This is very superior feedback from both of you! Thanks a million!
About this layer name conversion task: Expect all things to change including CAD standard layer name text cases!  🙄
LAYER NAME TEXT CONVERSION
BATCH PROCESSING - calling LISPS in SCRIPT FILES
A BricsCAD-based, custom batch file program (Batcher.lsp) as developed for my company very recently. Currently it processes .SCR file types.
QUESTION 1: Can .LSP programs be included from within script code lines?
If so, ...
BATH PROCESSING - SCRIPT FILE PURSUIT A: Convert both existing Title Case & lower case to UPPER CASE
BATH PROCESSING - SCRIPT FILE PURSUIT B: Batch convert via the following LISP program.
Prerequisite: Researching how to create the following LISP program
Create a AutoLISP/Visual LISP  program called LAYSUB.lsp
This program reads from a old layer name list and a current layer list.*
When old names are found from the old layer list, the program replaces the old layer string with current layer string.
  • Proposed LISP Step 1: (*) Create a program resource text file for each layer list, old and current layer names as a program resource file.
  • Proposed LISP Step 2: If old layers name case-sensitive string exist, substitute them with the new layer name case sensitive (UPPER) that is based on the two text file lists.
SUMMARY
Do the above pursuits sound reasonably practical for batch processing?
Best regards,
Clint Hill
I use Screentogif But SaveAS MP4 not gif. these forums don't like the gif it saves.
-Edit
@BIGAL
Edited by mhupp
If you google "Win 11 screen capture" it will talk about shift+window+R, nice thing is in web information is how to set the destination directory for the recording. So mine are set high in a drive easy to find compared to default buried in C:\Users
Gentlemen,
I think it best to explore the following pursuit "B" in a new post.
If so, ...
SUMMARY
Best regards,
Clint Hill
Obviously we don't have your batch LISP - I guess your company paid for this and so you are not going to be popular sharing that for all online.
LISPs can be added to scripts - both as a command and as code. There are others out there such as ScriptPro and Lee Macs Script Writer which will do this. BigAl will often post snippets of scripts here to batch process files - last one he did was in the last week or so ago. You could even set this up as a stand alone script to do just the one task (see BigAls last example....)
The first step for all is to get a LISP working as you want and well on a single file and then to do it as a batch (first time running the batch with a new LISP, perhaps check carefully that it doesn't do anything unexpected on other files). Plenty of examples out there to change layer names from one to another - have a look to see if you see one you like to use, or if there isn't am sure we can put one together - and use what is above as a started if you want to have a go, I think all the code you need is in the examples, just need to think how to change them to your needs
  • Agree 2
Hi Steven,
This is good to know. I will check out BigAL's related post very soon. Your responses are reassuring and well received!
My task is to hash out a program that reads from two lists and updates layer names to match the old version to both the current name (UPPERCASE).
Thanks,
Clint Hill
If using a script and running it over multiple dwgs then yes can load a lisp and then run it. The lisp can be very extensive a few lines or even hundreds.
Open dwg1
(load "updatelisp")
(c:updatelisp)
close Y
Open dwg2
(load "updatelisp")
(c:updatelisp)
close Y
Open dwg3
(load "updatelisp")
(c:updatelisp)
close Y
Hi BIGAL,
I appreciate your script lines example. Thankfully as part of the customization project, our developer created a BricsCAD-based batch scripting application that allows user selection of multiple files. So, I would simply save the script file to include the following lines:
(load "updatelisp")
(c:updatelisp)
Best regards,
Clint Hill
BricsCAD V26 can run PyRx Python, makes Batch processing a bit easier sometimes. If you’re interested
