Viewport Inset Generator
I have a Key Plan Viewport showing the wider site plan and I have multiple viewports showing specific areas of the wider site plan (Insets). Has it been done or attempted to create a lisp that will prompt the user to select the Key Plan Viewport, and then select the other Insets and show the Inset extents on the Key Plan Viewport as Rectangles?+
The Architecture system has a mechanism for creating Views, which you can then assign to viewports. I assume (but don't know) that you can show those Views in other viewports, such as the key plan you describe, and label them.
All of that would be really handy in my job, but Civil doesn't include that mechanism for some reason.
I guess you'd have to create a new object type, View. It would include the name, the bounds, and the UCS for one sheet. You'd have the ability to create a viewport, capture the bounds, and annotate it with the name and the scale. You could also apply one view to another, as with the insets on the key map. To be even more helpful, there'd be a new category in the Prospector so you could manage all those views. And maybe a layer state for the viewports.
Here is my code which draws mspace rectangles for viewport extents. It's missing subroutines prefixed with XYZ, but the main code for the coordinates can be used.
;;; Draw rectangle inside viewport limits
(defun c:RTV (/ pt1 pt2 dy dx vcx vcy pt3x pt3y pt4x pt4y)
  (XYZ-ERROR-INIT (list (list "clayer" (getvar "clayer") "cmdecho" 0) T))	;do list of variables to be set/reset
  (if (not XYZ_LAY_VPORT) (setq XYZ_LAY_VPORT (getvar "clayer")))
  (if (not (tblsearch "LAYER" XYZ_LAY_VPORT))
    (command "-layer" "make" XYZ_LAY_VPORT "color" "7" "" "plot" "no" "")	;make layer if it doesn't exist
  (command "-layer" "thaw" XYZ_LAY_VPORT "on" XYZ_LAY_VPORT "set" XYZ_LAY_VPORT "")	;thaw layer whether it exists or not
  (if (or (= 1 (caar (Vports)))					;determine if in mspace vport
          (= 1 (getvar "tilemode")))
      (XYZ_rectangle nil (getvar "vsmin") (getvar "vsmax"))
      (command "scale" (entlast) ""
               (getvar "viewctr")
               (/ (getvar "viewsize") (- (cadr (getvar "vsmax")) (cadr (getvar "vsmin"))))
    (progn									;if in mspace vport
      (setq pt1  (cadr (car (vports)))				;vport corners
            pt2  (caddr (car (vports)))
            dy   (distance pt1 (list (car pt1) (cadr pt2)))	;height of vport
            dx   (distance pt2 (list (car pt1) (cadr pt2)))	;width of vport
            vcx  (car (getvar "viewctr"))				;x pt of vport center
            vcy  (cadr (getvar "viewctr"))			;y pt
            sclf (/ (getvar "viewsize") dy)			;vport scale factor
            pt3x (- vcx (* 0.5 dx sclf))				;points of vport extent
            pt3y (- vcy (* 0.5 dy sclf))
            pt4x (+ vcx (* 0.5 dx sclf))
            pt4y (+ vcy (* 0.5 dy sclf))
      (XYZ_rectangle nil (list pt3x pt3y) (list pt4x pt4y))	;if not in mspace use virtual viewport limits
  (princ "\nPline rectangle drawn to viewport limits")
  (XYZ-ERROR-RESTORE)
Like @dan20047 I make rectangs and then make a layout matching that rectang. Where I worked our title block was fixed, so the viewport in a layout was based on the matching rectang at a scale. The rectangs can be rotated and the viewport will be Twisted to match.
You can pick a Viewport and get its info then draw a rectang that matches in paperspace then do a simple CHSPACE, all done. Look at these 3 values. Just take 1/2 the 40 and 41 can work out the corners.
(defun c:vp2model ( / vp cp d1 d2 p1 p2 lay)
  (command "pspace")
  (setq vp (entget (car (entsel "\nPick the viewport "))))
  (setq cp  (assoc 10 vp))
  (setq cp (list (cadr cp)(caddr cp)))
  (setq lay (cdr (assoc 8 vp)))
  (setq d1 (/ (cdr (assoc 40 vp)) 2.0))
  (setq d2 (/ (cdr (assoc 41 vp)) 2.0))
  (setq p1 (mapcar '+ cp (list (- d1) (- d2) 0.0)))
  (setq p2 (mapcar '+ cp (list d1 d2 0.0)))
  (setvar 'clayer lay)
  (command "Rectang" p1 p2)
  (command "chspace" (entlast) "" )
  (command "pspace")
A question will the layouts have more than one viewport as you need to identify which viewport has been selected.
@BIGAL So in principal I agree with your approach draw rectangles along the selected viewports, send to model space and then select the key plan to bring them back to paperspace. The problem I faced I stumbled across is that you can not define which viewport to CHspace without the user selecting the viewports.
So my idea of the optimal workflow/lisp would look something like this:
1. Select Key Plan Viewport
2. Select Insert Viewports
3. Draw Rectangle on all Inset viewports
4. Send Rectangles to ModelSpace of each Inset viewport (So they are at the right scale).
5. Bring all rectangles to PaperSpace through the Key Plan Viewport.
If you have multiple viewports in a layout, then using chspace have to nominate which viewport you are looking at. Will see if can edit code bit busy at moment.
For Key maps, I use two routines:
1. Lee's Viewport outline
https://lee-mac.com/vpoutline.html
2. Change Space Copy
(defun c:CHSpaceCopy (/ ss2 ss i)
  (vl-load-com)
  (if (setq ss2	(ssadd)
	    ss	(ssget "_:L")
	(ssadd
	  (vlax-vla-object->ename
	    (vla-copy
	      (vlax-ename->vla-object (ssname ss (setq i (1- i))))
	  ss2
      (vl-cmdf "_.chspace" ss2 "")
Hi @troggarf, Lee Mac's VPOutline is a great start! I am having difficulty understanding your lisp. ssget "_:L" will prompt the user to select items using window selection? Could we pass a filter to only select the latest created VPOutlines and just select the Key Plan Viewport? My aspiration is to combine Lee Mac VPOutline with your suggestion. But some further tweaking might be required.
  • 2 weeks later...
Lee's code  allows the user to automatically generate polylines in modelspace representing the outline of a selected paperspace viewport, all viewports in the active paperspace layout, or all viewports found in all paperspace layouts.
As long as the current layer is displayed in the Key Plan Viewport model space all those rectangles should display already.
troggarf's code puts a copy of selected objects in paperspace.
Have some time again so will try to have another go, hopefully your metric makes life easier. I would start with a layout with a title block and say some viewports at different sizes out side the title block. So have insets, and larger ones. Drag a viewport to location on title block. Go to modelspace in viewport and zoom to approx view required, can then display current scale as a 1:x so enter correct scale, viewport is corrected for scale and a Rectang drawn in Model with a label etc.
Does that sound helpful ? let me know.
@tombu Yes Lee Code is perfect, if you want to stop there. But I would like to take it a step further.
@BIGAL This is a different approach that might just work perfectly!
You should look at Lee Mac's Tutorials like Selection Mode Strings https://www.lee-mac.com/ssget.html for ssget options. For instance ssget "_:L" Rejects selection of objects residing on locked layers.
Give this a try you just make the viewports and zoom inside the viewport the model, you will be asked for a scale and the viewport is rescaled to suit, then the outline is drawn in model. Will fix later the yes no question into the DCL.
; https://www.cadtutor.net/forum/topic/98882-viewport-inset-generator/
; make rectangs from viewport
; By AlanH Jan 2026
; resets viewport scale then make outline
(defun c:vp2model ( / ent vp p1 p2 sc obj scvp )
(defun AH:domove ( / )
(command "chspace" (entlast) "")
(vla-put-activepviewport (vla-get-activedocument (vlax-get-acad-object)) obj)
(command "")
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
(alert "Have you zoomed in to viewport ? \n\nIf not then type N or no")
(initget "Yes No" 6)
(setq ans (getkword "\nContinue Yes or No. "))
(if (= ans "No") (exit))
(command "pspace")
(setq ent (car (entsel "\nPick the viewport ")))
(setq vp (cdr (assoc (cdr (assoc 69 (entget ent))) (vports))))
(setq p1 (car vp))
(setq p2 (cadr vp))
(setq obj (vlax-ename->vla-object ent))
(setq scvp (vlax-get obj 'customscale))
(setq sc (fix (/ 1000 scvp)))
(vlax-put obj 'displaylocked 0)
(setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w"))
  (write-line "ddgetvalAH : dialog {" fo)
  (write-line (strcat "	label = \"Set Scale\"  ;") fo)
  (write-line " : column {" fo)
  (write-line " width =25 ;" fo)
  (write-line ": edit_box {" fo)
  (write-line  " key =  \"Key1\"  ;" fo)
  (write-line (strcat " label = \"Enter scale\" ;") fo)
  (write-line (strcat "     edit_width =  10 ;") fo)
  (write-line (strcat "     edit_limit =  9 ;") fo)
  (write-line "   is_enabled = true ;" fo)
  (write-line "   allow_accept=true ;" fo)
  (write-line "    }" fo)
  (write-line "spacer_1 ;" fo)
  (write-line "ok_cancel;}" fo)
(close fo)
(setq dcl_id (load_dialog fname))
(if (not (new_dialog "ddgetvalAH" dcl_id))
    (exit)
(set_tile "Key1" (rtos sc 2 0))
(action_tile "accept" "(setq sc (get_tile \"Key1\"))(done_dialog)")
(action_tile "cancel" "(done_dialog)")
(start_dialog)
(unload_dialog dcl_id)
(vl-file-delete fname)
(vlax-put obj 'customscale (/ 1000 (atof sc)))
(vlax-put obj 'displaylocked -1)
(AH:domove)
(command "pspace")
(setvar 'osmode oldsnap)
(C:vp2model)
