Discus84 Posted Wednesday at 02:39 PM Posted Wednesday at 02:39 PM Hi, I'm using PURGE and OVERKILL to clean up. Any other options? Quote
ReMark Posted Wednesday at 05:06 PM Posted Wednesday at 05:06 PM One I can think of is to WBLOCK the entire drawing out to a new file name (temporarily) then compare the file sizes. Quote
CyberAngel Posted Wednesday at 07:54 PM Posted Wednesday at 07:54 PM The worst waste of storage I've seen is inserting another drawing as a block (either as copy&paste or xref), using it for whatever, then freezing the layer it's on. Sometimes they'll insert it once, forget it's there, and explode the second copy, so it's there twice. Or three times or more. The usual tools don't work on these duplicates. There are ways to find them, but most are clunky. For instance, thaw all the layers. See if anything looks suspicious. Select areas of the screen to see if there are outrageous numbers of objects. Another strategy is to look through your blocks. One may have an odd name or a thumbnail that looks like a plan. Look through your layers for groups that don't belong. Go through your layouts. Needless to say, don't save the drawing while you're tracking down the problem. Once you do find it, quit the file, reload it, fix it, and then save. Quote
SLW210 Posted Wednesday at 08:48 PM Posted Wednesday at 08:48 PM Are you using AutoCAD 2010? Along with previous suggestions and to add, you can do a lot of cleaning with the WBLOCK @ReMark, best method for true cleaning is to WBLOCK just the selected/visible objects you need, that way some of the things mentioned by @CyberAngel are hopefully not carried to the new drawing. I always start with -EXPORTTOAUTOCAD to clean up objects left by verticals, etc. Quote
BIGAL Posted Thursday at 12:14 AM Posted Thursday at 12:14 AM Using a CIV3D dwg a lot of info is not purged as its locked by CIV3D, need to use PURGESYLEANDSETTINGS before Purge. The dwg will drop in size quickly. Quote
SLW210 Posted Thursday at 11:48 AM Posted Thursday at 11:48 AM 11 hours ago, BIGAL said: Using a CIV3D dwg a lot of info is not purged as its locked by CIV3D, need to use PURGESYLEANDSETTINGS before Purge. The dwg will drop in size quickly. That is only available in Civil 3D AFAIK, not much use for someone with AutoCAD 2010. Quote
CyberAngel Posted Thursday at 01:10 PM Posted Thursday at 01:10 PM 1 hour ago, SLW210 said: That is only available in Civil 3D AFAIK, not much use for someone with AutoCAD 2010. But just in case you are using Civil, try to prune out as many points as you can. They take up approximately 1K apiece. One thousand points = 1MB of space. It adds up. Quote
SLW210 Posted 13 hours ago Posted 13 hours ago There are some free and paid apps in the Autodesk Appstore that really do a super job. Not sure if they work on AutoCAD 2010 though and OP refuses to respond to my question on what CAD they use. Quote
BIGAL Posted 2 hours ago Posted 2 hours ago I have seen a dwg with a complete project inside the current dwg which had nothing to do with the dwg being worked on. Look for $AC.... blocks these can be very extensive in size. You need to insert explode erase then can purge. Do you get a blank screen with Zoom Extents ? This is indicating that something is way out there normally in a corner and can be a complete dwg. The only real way to fix is to look at the dwg, understand company copy right problem but you can PM or email via a PM to people here who will look at the dwg and let you know what they find. Quote
