hardwell3458 Posted 17 hours ago Posted 17 hours ago Hi, I need a smart and dynamic offset Lisp when drawing electrical projects. polyline will follow the wall. Like in the video. ScreenRecording_01-20-2026 22-20-40_1.mov Quote
ScottMC Posted 15 hours ago Posted 15 hours ago (edited) Here's a useful Lee.Mac Power.tool TotalLengthPolylineV1-0.lsp Edited 1 hour ago by SLW210 Removed Code Not placed in Code Tags as already attached the file!!! 1 1 Quote
BIGAL Posted 14 hours ago Posted 14 hours ago (edited) I did something for water pipes or electric cables in a road, it just allows you to follow line segments, with a predefined offset. I am not sure though in your last bit of Video if you want to enter the length of the last leg, can you clarify that. The code I have draws a full last length. @ScottMC not sure that overall length is required. Just a ps did you mean to post the actual code as you have the lisp file to download. Edited 14 hours ago by BIGAL 1 Quote
hardwell3458 Posted 7 hours ago Author Posted 7 hours ago Thank you for your answers. The Lisp code you described might be useful, but as you said, when traversing areas like walls or columns, it offsets the line by 6 units, and if there's a pre-drawn, offset line, it follows it all the way to the end. Could you share your code? @BÜYÜK Quote
hardwell3458 Posted 7 hours ago Author Posted 7 hours ago I've included another video as an example. smart offset.mp4 Quote
