Using ACAD 2010. All drafting is done in model space. Individual drawings are set up in paperspace. When I go to the first tab in paperspace, I put my engineers seal/signature on the finished drawing. I then CTRL-C my engineers seal/signature and go to the next tab and CTRL-V my engineers seal/signature on that drawing. Every time I go to a new tab, I have to purge the drawing because there will be hundreds of blocks in the drawing called *A#####.  If I do not purge the drawing at every tab, I can CTRL-V my engineers seal/signature onto maybe 2-3 tabs then my computer runs out of memory. I them have to purge the drawing, save it, close it and reopen it.
This only happens when I am inserting an object into paperspace. I can work with the drawing for a week and I never get all these *A#### blocks. But as soon as I insert my seal/signature in paperspace I get all these #A#### blocks. FYI, my seal block is 54kB and my signature block is 84kB. It is irritating having to purge the drawing everytime I switch to a new tab .Any suggestions.
*A#### is an anonymous GROUP, so you seem to have these as groups, not blocks.
Quote
*U### = anonymous blocks
*E### = anonymous non-uniformly scaled blocks
*X### = anonymous hatches
*D### = anonymous dimensions
*A### = anonymous groups
Post a drawing that does this, no need to share the actual stamp and signature just something anonymous (no pun intended), but has the same results.
You can take one object out of say a title block in a layout and copy it to all other layouts via lisp, I use this to fill in the basics of a title block then use the current layout to copy to other layouts, another version copies certain attributes to all other layouts. Say client changes name. Yes I had a insert signature lisp it inserted the signature into all layouts. A simple insert an external block.
Sounds like your seal/signature is lots of objects as previously suggested by @SLW210 so have a hard look at it. Maybe explode all and wblock the 2 blocks to new temporary  dwgs then remove old and rename to correct name.
Another way to handle this issue is to define your title block as an AutoCAD block. That way the seal is already included. You put the seal on its own separate layer and turn that layer on when necessary. Another option is to use visibility states, so you only tap on a button to show the seal.
But first, as the other answers suggest, clean up the seal block. That may take care of it.
