hello:
I've heard about the command OOPS
Unfortunately, the AutoCAD I use at work is version 2013
Does anyone know if there is an LSP routine command for that?
IT WOULD BE GREAT TO INCORPORATE IT
Any advice is welcome.
thanks
In this link, it's written that OOPS command exist : In AutoCAD since version ≤ R12...
  • Thanks 1
THANK YOU SO MUCH, I DIDN'T KNOW I HAD IT
You created this thread before even trying it in your AutoCAD?
  • Thanks 1
master LEE
I tried the command, but nothing appeared on the command line, so I doubted I could do it.
That's because you need to do something before issuing the oops command.  I think there is a thread here differentiating oops and undo command.
  • Agree 1
You need to use ERASE to remove items in order for OOPS to actually restore it.
Quote
The OOPS command in AutoCAD restores the last object or set of objects that were deleted using the ERASE command, without affecting any work done since the deletion. It is a one-time recovery option, meaning it only retrieves the most recently erased items. You cannot use OOPS to restore objects on a layer that has been removed with the PURGE command.
  • Agree 1
OOPS only restores objects that were erased by the last ERASE command.
