leonucadom Posted March 10 Posted March 10 hello: I've heard about the command OOPS Unfortunately, the AutoCAD I use at work is version 2013 Does anyone know if there is an LSP routine command for that? IT WOULD BE GREAT TO INCORPORATE IT Any advice is welcome. thanks Quote
marko_ribar Posted March 10 Posted March 10 In this link, it's written that OOPS command exist : In AutoCAD since version ≤ R12... 1 Quote
Lee Mac Posted March 10 Posted March 10 You created this thread before even trying it in your AutoCAD? 1 Quote
leonucadom Posted March 10 Author Posted March 10 master LEE I tried the command, but nothing appeared on the command line, so I doubted I could do it. Quote
CAD_Noob Posted March 11 Posted March 11 That's because you need to do something before issuing the oops command. I think there is a thread here differentiating oops and undo command. 1 Quote
SLW210 Posted March 11 Posted March 11 You need to use ERASE to remove items in order for OOPS to actually restore it. Quote The OOPS command in AutoCAD restores the last object or set of objects that were deleted using the ERASE command, without affecting any work done since the deletion. It is a one-time recovery option, meaning it only retrieves the most recently erased items. You cannot use OOPS to restore objects on a layer that has been removed with the PURGE command. 1 Quote
mhupp Posted March 12 Posted March 12 19 hours ago, CAD_Noob said: That's because you need to do something before issuing the oops command. I think there is a thread here differentiating oops and undo command. OOPS only restores objects that were erased by the last ERASE command. Quote
