Hi everyone,
Ankit here.
I’m currently looking for a reliable solution to generate 2D outer boundaries for complex drawings in AutoCAD. The solution should be:
Highly accurate (able to capture minute details)
Efficient in terms of performance (handling large/complex drawings smoothly)
Capable of working with imperfect geometry (small gaps, overlaps, etc.)
I’ve used tools like TotalBoundary earlier, but since it’s no longer purchasable/accessible, I’m exploring alternatives.
Does anyone know of any plugin, LISP, or workflow that can achieve similar or better results?
Any recommendations would be really helpful. Thanks in advance!
Here is something simple I threw together a while ago. Not everything you want, but should help.
I started a more extreme version with more options back when people were posting they couldn't get TotalBoundary and SuperBoundary any longer.
I'll try to get back on it this week, in the mean time, if you could post a drawing with some before and after it would help.
I have no idea what all TotalBoundary and SuperBoundary does, it may help to explain exactly how you need to select and exactly what should be a boundary in your drawing it might might it easier.
Hopefully a better LISPer will jump in.
;;; Select objects that define outlines. Works on LINE/ARC/CIRCLE/SPLINE/LWPOLYLINE.
;;; https://www.cadtutor.net/forum/topic/99063-need-a-tool-for-creating-2d-outlines-for-complex-2d-drawings/#findComment-678789
;;; By SLW210 (a.k.a. Steve Wilson)
;;; MakeOut.lsp
(defun c:MakeOut (/ ss i ent lst pts plines regions pp)
  (vl-load-com)
  (if (setq ss (ssget '((0 . "LINE,ARC,CIRCLE,SPLINE,LWPOLYLINE"))))
      (setq i 0)
      (while (< i (sslength ss))
        (setq ent (ssname ss i))
        (setq i (1+ i))
      (command "_.-boundary" ss "")
      (command "_.pedit" ss "" "J" "" "Y")
      (setq i 0)
        (if (= (cdr (assoc 0 (entget ent))) "LWPOLYLINE")
            (command "_.pedit" ent "" "S" "0.01" "")
            (command "_.pedit" ent "" "C" "")
        (setq i (1+ i))
      (princ "\nOutline created.")
    (princ "\nNo valid entities selected.")
  • Like 2
;;; MakeOut.lsp
  (vl-load-com)
      (setq i 0)
        (setq i (1+ i))
      (setq i 0)
        (setq i (1+ i))
Thanks for sharing this, really appreciate it.
I gave your LISP a try on a few drawings — it works quite well on cleaner geometry, so that was helpful.
In my case, I’m mostly dealing with drawings that have small gaps or slightly messy geometry, and that’s where I’m still seeing some inconsistencies with boundary creation.
Your point about sharing an example makes sense — I’ll put together a sample with before/after to better explain the issue.
I’ve also been experimenting with a slightly different approach for handling these kinds of cases, especially for more complex drawings. I’ll share a quick example once I clean it up a
bit.
I updated something that makes multiple boundaries but cant find the post right now. doesn't work with gaps so idk if its something you could use.
lee mac has an outline but also don't think it works with gaps. https://lee-mac.com/outlineobjects.html
  • Like 2
Thanks for pointing that out, that’s really helpful.
I’ve noticed similar behavior as well.
I took a look at the Lee Mac outline routine, and it seems to work fine for cleaner cases, but like you mentioned, it still struggles when there are small gaps or slightly messy geometry.
That’s been the main challenge on my end — most approaches seem to rely on boundary detection underneath, so they tend to break in those situations.
I’ll put together a sample to better show the kind of cases I’m dealing with and what I’ve been testing.
Here’s a sample of the kind of drawing I’m working with.
It has dense geometry with small gaps and overlapping elements, and in cases like this, standard boundary methods don’t always produce consistent results.
This is the type of scenario I’ve been trying to handle more reliably.
I tried this on one of my actual project drawings.
The image shows the input geometry and the output generated using the suggested approach (blue lines indicate the generated boundaries).
It works quite well in simpler cases, but for this type of geometry I’m still seeing partial or inconsistent boundaries being created — it’s not forming a single clean outer boundary for the full shape.
This is the kind of scenario I’ve been struggling with, especially where there are small gaps or more complex connections.
  • Thanks 1
I had to stop on the newer version yesterday due to my "paid" for work, still debugging it.
Can you post an actual .dwg of that example for testing?
Also, what version of AutoCAD are you using?
  • Thanks 1
I think I have a solution but would need a test drawing.
  • Thanks 1
@SLW210 CIV3D has Shrinkwrap also. Pity they did not include for plain Acad. If you can work out which dll or ARX may be able to copy correct files to plain Acad.
As "TotalBoundary " is no longer available there was a post for a similar product may have been here or at Forums/Autodesk. I remember asking how much but did not get an answer. Try googling.
  • Thanks 1
Thanks for all the suggestions, really appreciate you taking the time to look into this.
I tried a few of the approaches mentioned — they seem to work quite well on cleaner geometry, but in cases like mine with small gaps and more complex connections, I’m still seeing partial or inconsistent boundaries being generated.
I’ve attached a simplified sample from one of my project drawings. This represents the kind of geometry I’m dealing with, where standard methods haven’t been giving consistent results.
Curious to see how your approaches handle this case.
Engine Part Assembly.dwg
4 hours ago, Dahzee said:
I think this is the product BIGAL was referring to.https://engenext.com/pages/egboundary.html I have no affiliation to this product, I just remember seeing it discussed on the Bricscad forum.
$119 USD, you get 15 day free trial.
Most examples didn't show gaps, but looks like the user guide claims Auto Tolerance and Auto island detection.
Could you link the discussion on Bricscad for the OP?
  • Thanks 1
You have to purchase Civil 3D, Architecture is free with AutoCAD.
OP still hasn't stated what CAD they are using.
  • Thanks 1
Thanks for pointing that out — I gave it a try on the same drawing.
It actually handled the case surprisingly well and produced a clean outer boundary for the full shape, even with the gaps and more complex areas where the other approaches were struggling.
Sharing the result here.
11 hours ago, SLW210 said:
Here is the result of the AECLINEWORKSHRINKWRAP in Archtecture.
Thanks for sharing that and testing it.
I’m currently using AutoCAD 2026 (standard), and from what I can see, the AECLINEWORKSHRINKWRAP functionality isn’t available in this version.
It looks like it’s part of the Architecture/Civil toolsets, so accessing it would mean moving to something like Civil 3D or the AEC Collection, which is quite a big upgrade just to use this specific functionality.
Really appreciate you taking the time to test it though.
As I mentioned already, AutoCAD Architecture is FREE with the Toolset. All you need to do is download it.
Architecture Toolset in Autodesk AutoCAD | Features
Quote
The Architecture toolset is included with AutoCAD 2026
This looks like something Bricscad should incorporate as well.
That's the reason I stopped working on the LISP, but I will probably try to get it finished up anyway.
  • Thanks 1
Ah got it — thanks for clarifying that, I wasn’t aware the Architecture toolset was included.
That makes sense.
I also had a chance to try the shrinkwrap command on a different setup (a friend using Civil), and saw similar behavior in the more detailed regions.
From the result you shared, it does get quite close, but I’m still seeing some irregularities around the boundary in those complex areas, especially in some of my other projects.
That’s been the tricky part in my case — getting a consistently clean outer boundary across the full shape.
I’ve been testing EGBoundary across different setups — it’s been working consistently for me in AutoCAD and BricsCAD so far. I haven’t personally tried it yet in GstarCAD or ZWCAD, though I’ve seen them mentioned as compatible with GstarCAD and ZWCAD on their official website.
Really appreciate you taking the time to test and share that. Thank you !!
Edited by Ankit Pandit
