sd2006 Posted April 30 Posted April 30 (edited) I'm using LISP to calculate the hatch area, but it keeps giving me errors, and it only works when I copy the code to a different file. Could you please take a look? Thank you. Edited May 4 by sd2006 Quote
Tsuky Posted April 30 Posted April 30 You need to check if the text style has a set height because the options in the TEXT command are not the same. (defun C:ah () (hatcharea)) (defun hatcharea ( / ss area i eo pt) (setq ss (ssget '((0 . "hatch"))) area 0 i 0 ) (cond ((and(and ss) (> (sslength ss) 0)) (repeat (sslength ss) (setq eo (vlax-ename->vla-object (ssname ss i))) (setq area (+ area (vlax-get eo 'Area))) (setq i (+ i 1)) ) (while (not pt)(setq pt (getpoint "\nSelect area text insertion point >"))) (setq area (/ area 1000000.)) (if (zerop (cdr (assoc 40 (tblsearch "STYLE" (getvar "TEXTSTYLE"))))) (command "_.text" pt "" "" (strcat "" (rtos area 2 2) " m²")) (command "_.text" pt "" (strcat "" (rtos area 2 2) " m²")) ) ) ) (princ) ) 1 Quote
mhupp Posted April 30 Posted April 30 Can't remember but I think it might also error calculating the area of a self intersecting hatch. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/autocad-2023-a-lisp-file-that-can-identify-self-intersecting/td-p/11090485 Quote
