I Working with AutoCAD LT 2026, after about 1 hour the saving becomes very slow.
I use the 'Purge' command and also 'Audit', but the only way to continue is (after the long wait for saving), to exit and re-enter AutoCAD.
Is it a problem with only one drawing or multiple drawings?
I don't know if your using lisp in the save process. 2026 and newer has a bug that if command is used inside of loops it balloons the run time. something that took 0.5 sec at the most could take 200+ sec. or it might be a new different bug!
https://forums.autodesk.com/t5/autocad-forum/autocad-2026-slow-vs-2023/td-p/13649249
Quote
Until now, I've been using AutoCAD 2023, everything's fine, no issues at all.
I decided to update to version 2026, and everything is running very slowly, barely able to work.
As a reference, I'm using a DWG file that takes up 48MB. It has multiple 3D blocks.
Once opened in 2023, it takes up 1.5GB of RAM, but in 2026, it takes up 14GB!!! 10 times more.
What could be happening?
I know windows 11 takes about 6-10 gigs to run so if you only have 32 gigs of ram. This might be why its run really slow.
-edit
Ctrl + Shift + Esc to open task manager.
then click on preformance to see Memory, CPU, GPU Usage.
Edited by mhupp
It is slow with any DWG file. It seemed to have improved a bit after giving the 'Wblock' command, to export the drawing to a new file... but then continuing to work on it for half a day, everything becomes slow again as before. I checked: memory usage is 40% on a 3 MB file.
I tried to check which versions of .Net are installed: it seems unusual to me that the latest is 4.0.3 (the version 10 came out in April!). My colleagues with the same versions have no problems.
It might be advisable to install more recent versions: I'm afraid of causing damage!
Incredible: it seems that (GC) works! I think I last used this command on a 486! Thank you very much!
  • Funny 1
Not sure why moderators missed this, which is the correct version your using, 2012 or 2026. A good idea is to update version if it's different to what is showing.
The OP mentioned the version they were inquiring about in the thread title and the first post as well as posted in the  AutoCAD LT Forum. Some people may use more than one version.
In fact, I haven't updated my profile: I no longer use the 2012 version but I use Gstarcad 2023 and sometimes Autocad LT 2026 (subject of the question). I apologize to all of you for not having read the new posts anymore.
Good to know about "Gstarcad 2023" some of the other CAD programs do have little hidden issues that pop up now and then. But to Cadtutor's credit it is not a one platform forum.
  • 2 weeks later...
Actually, the problem reported in this post is about Autocad LT.
However, it's true: GstarCAD 2023 has some little problems, but I have already learned to get to know it... for example, when I close an unsaved dwg it tells me: Do you want to save (YES - NO - CANCEL). Well, if I select CANCEL ... it exits without saving!
Ouch. See what it does if you hit esc. or hitting the X instead of cancel.
LT slow, have you looked at doing saves say every 15 minutes as a test, your undo may be coming an excessive size. What is your auto save set to ? We had like 15 minutes as the default. Another where is your "Temp directory" pointing to I have a SSD and normal drive and the ssd is so much faster when saving.
