X11start Posted May 7 Posted May 7 I Working with AutoCAD LT 2026, after about 1 hour the saving becomes very slow. I use the 'Purge' command and also 'Audit', but the only way to continue is (after the long wait for saving), to exit and re-enter AutoCAD. Quote
mhupp Posted May 7 Posted May 7 (edited) I don't know if your using lisp in the save process. 2026 and newer has a bug that if command is used inside of loops it balloons the run time. something that took 0.5 sec at the most could take 200+ sec. or it might be a new different bug! https://forums.autodesk.com/t5/autocad-forum/autocad-2026-slow-vs-2023/td-p/13649249 Quote Until now, I've been using AutoCAD 2023, everything's fine, no issues at all. I decided to update to version 2026, and everything is running very slowly, barely able to work. As a reference, I'm using a DWG file that takes up 48MB. It has multiple 3D blocks. Once opened in 2023, it takes up 1.5GB of RAM, but in 2026, it takes up 14GB!!! 10 times more. What could be happening? I know windows 11 takes about 6-10 gigs to run so if you only have 32 gigs of ram. This might be why its run really slow. -edit Ctrl + Shift + Esc to open task manager. then click on preformance to see Memory, CPU, GPU Usage. Edited May 7 by mhupp Quote
X11start Posted May 8 Author Posted May 8 It is slow with any DWG file. It seemed to have improved a bit after giving the 'Wblock' command, to export the drawing to a new file... but then continuing to work on it for half a day, everything becomes slow again as before. I checked: memory usage is 40% on a 3 MB file. Quote
X11start Posted May 8 Author Posted May 8 I tried to check which versions of .Net are installed: it seems unusual to me that the latest is 4.0.3 (the version 10 came out in April!). My colleagues with the same versions have no problems. It might be advisable to install more recent versions: I'm afraid of causing damage! Quote
mhupp Posted May 11 Posted May 11 Haven't been on AutoCAD for a while. maybe try GC command to free up memory might help. use mem at the start when its nice and fast and when it is starting to slow down. https://help.autodesk.com/view/ACDLT/2026/ENU/?caas=caas/documentation/ACD/2014/ENU/files/GUID-F4AEB953-2117-4BF2-8056-EA1384AC3FFF-htm.html 1 Quote
X11start Posted May 13 Author Posted May 13 Incredible: it seems that (GC) works! I think I last used this command on a 486! Thank you very much! 1 Quote
BIGAL Posted May 14 Posted May 14 Not sure why moderators missed this, which is the correct version your using, 2012 or 2026. A good idea is to update version if it's different to what is showing. Quote
SLW210 Posted May 14 Posted May 14 8 hours ago, BIGAL said: Not sure why moderators missed this, which is the correct version your using, 2012 or 2026. A good idea is to update version if it's different to what is showing. The OP mentioned the version they were inquiring about in the thread title and the first post as well as posted in the AutoCAD LT Forum. Some people may use more than one version. Quote
X11start Posted May 19 Author Posted May 19 In fact, I haven't updated my profile: I no longer use the 2012 version but I use Gstarcad 2023 and sometimes Autocad LT 2026 (subject of the question). I apologize to all of you for not having read the new posts anymore. Quote
BIGAL Posted May 20 Posted May 20 Good to know about "Gstarcad 2023" some of the other CAD programs do have little hidden issues that pop up now and then. But to Cadtutor's credit it is not a one platform forum. Quote
X11start Posted May 28 Author Posted May 28 Actually, the problem reported in this post is about Autocad LT. However, it's true: GstarCAD 2023 has some little problems, but I have already learned to get to know it... for example, when I close an unsaved dwg it tells me: Do you want to save (YES - NO - CANCEL). Well, if I select CANCEL ... it exits without saving! Quote
mhupp Posted June 1 Posted June 1 On 5/28/2026 at 5:37 AM, X11start said: Actually, the problem reported in this post is about Autocad LT. However, it's true: GstarCAD 2023 has some little problems, but I have already learned to get to know it... for example, when I close an unsaved dwg it tells me: Do you want to save (YES - NO - CANCEL). Well, if I select CANCEL ... it exits without saving! Ouch. See what it does if you hit esc. or hitting the X instead of cancel. Quote
BIGAL Posted June 2 Posted June 2 LT slow, have you looked at doing saves say every 15 minutes as a test, your undo may be coming an excessive size. What is your auto save set to ? We had like 15 minutes as the default. Another where is your "Temp directory" pointing to I have a SSD and normal drive and the ssd is so much faster when saving. Quote
X11start Posted 2 hours ago Author Posted 2 hours ago Actually I set the autosave every 5 minutes. At this point the only annoying element of this "bug" is that... it can happen that you don't remember what things have been changed in the last few minutes, so you run the risk of skipping some of them. It happens when I have to retouch a drawing in various areas... but as I say it's a rare case: by now I know about this "bug" and I'm careful! Quote
SLW210 Posted 44 minutes ago Posted 44 minutes ago I wouldn't rely on AutoCAD's Autosave feature, see this recently revived old thread... I have some links where you can "Autosave" without Autodesk's version. I know for AutoCAD LT the VBA solution will not work, but maybe the others are worth a shot. As I mention, get into the habit of Ctrl+S often. From the other link I posting in that thread explaining Autosave, etc.... Quote Automatic saves are only done if a drawing has been modified after the last save. An automatic save will not save to the current drawing. Instead, a temporary file with the extension .sv$ is generated. After a successful automatic save, the command line will display a message similar to the following, with the complete path of the .sv$ file created: Automatic save to C:\Users\<user>\AppData\Local\Temp\Drawing1_1_26996_d94606ea.sv$ … QSAVE, SAVE, and SAVEAS will delete the current .sv$ file and halt the automatic save timer until an edit is made to the drawing. Closing a drawing and electing to not save it will delete the autosave file. Quote
