mataeux Posted May 8 Posted May 8 (edited) I no longer have AutoCAD or any ability to support them but I wanted to share the greatest accomplishments of my career The ability to open and parse binary files, demonstrated in esrishp.lsp and read-bin.lsp make beautiful maps from esri shp data and SHADOWING.lsp (use refe and refc to edit a block in place a lot) I don’t claim to be the ONLY person to entmake a 3dsolid demonstrated in the su command, but where else can you find out about the sat format from Spatial Technologies before it became proprietary information? An old manual i got off their website at the right time Trace over the client’s/engineer’s sketch easily digitizing it with smoothtrace.lsp Scalable stipple so concrete surfaces appear at the same density regardless of the scale Control joints that disappear on the site plan Use clipped block instead of hatch pattern for asphalt surface Linetypes where the lineweights of the actual line are independent of embedded symbol Symbols a new block that scales automatically without the overhead of dynamic blocks Posable mannequin using act command GET THE LIBRARY HERE: form Also, make a donation Edited May 8 by mataeux Quote
