M07 Posted May 13 Posted May 13 Hello everyone, I need your help. I have a preset dynamic block for a pipe that I can stretch and adjust in size, along with several fittings like elbows, tees, reducers, etc. I want to know if there is a way, or a lisp, or any AutoCAD command, that I can use to automatically place these dynamic pipes and fittings on a previously drawn line or polyline routing, simply by selecting the routing so that AutoCAD can automatically position these fittings without me having to redraw them, matching and following the existing routing. Quote
SLW210 Posted May 14 Posted May 14 I have moved your thread to the AutoLISP, Visual LISP & DCL Forum, please post in the most appropriate forum. Please only post once for the same inquiry, I deleted your other threads. Quote
BIGAL Posted May 14 Posted May 14 Welcome aboard M07, did you do a google re this task ? I have seen posts in various forums for this task. There may also be something overt at the Autodesk Apps Store. Do you have access to Autodesk "Plant" that should do what you want. Quote
mhupp Posted May 15 Posted May 15 (edited) 13 hours ago, nod684 said: See if this program by @Tharwat is suitable for you... Need a link https://autolispprograms.wordpress.com/water-supply-2/ Edited May 15 by mhupp 1 Quote
