;;; QSS - Quick String Search Rlx 5/'26
;;; Just a basic string search engine, primarily meant for text based files like lsp & txt files + dwg files (dbx)
;;; Some files are read as stream so maybe it also works for other file types ... bucketlist material.
;;; On my home computer text search in total commander stopt working so decided to do it myself.
;;; Also Total commander was removed from my work computer. I allready lispify some other
;;; Total Commander functions like copy, move & rename but those live in my batch program.
;;; Main use for me is sometimes I remember making a lisp but not remembering how I named it or where I saved it.
;;; At moment of writing this app is still in beta.
(defun C:QSS
        ;;; globals
        OldErr regkey regvar sysvar-names sysvar-old-values total-file-list hit-list
        qss-open-dwg-on-your-way-out fn
        ;;; object dbx / RegExp
        actApp actDoc actDocs actLay actDbx AllOpen RegExp
        ;;; Excel
        xlApp xlWorkbooks xlWorkbook xlSheets
        ;;; registry
        QSS-Search-Folder					;;; String - Folder where lisp files are placed
        QSS-Include-Subfolders					;;; Toggle - "0" scan only search folder, "1" also scan subfolders
        QSS-Filename-Extension-Filter				;;; String - delimited by , like "lsp,txt"
        QSS-Search-String-Filter				;;; String - delimited by | like "Rlx|Dragon"
        QSS-Case-Sensitive					;;; Toggle - "0" don't care, "1" case sensitive search
        QSS-Whole-Words-Only					;;; Toggle - "0" find every part, "1" only find whole words
        ;;; dialog
        QSS-Main-Dialog-fn QSS-Main-Dialog-fp QSS-Main-Dialog-id
	MainDialog-tl MainDialog-rd
  (QSS_init)
  (QSS_exit)
  (if (and qss-open-dwg-on-your-way-out (setq fn (findfile qss-open-dwg-on-your-way-out)))(_ShellOpen fn))
;--- Init ------------------------------------------------- Begin Init Section --------------------------------------------------- Init ---
(defun QSS_Init ()
  ; initialize error handling
  (setq OldErr *error* *error* QSS_Err)
  ; backup & set system variables (not realy used here, just added for template purposes)
  (setq sysvar-names (list (cons 'cmdecho 0))
        sysvar-old-values (mapcar '(lambda (x)(getvar (car x))) sysvar-names))
  (mapcar '(lambda (x)(setvar (car x) (cdr x))) sysvar-names)
  ;;; init registry variables
  (InitDefaultRegistrySettings)(ReadSettingsFromRegistry)
  ;;; lets go girls
  (QSS_Main_Dialog_Start)
(defun QSS_Err ($s) (princ $s)(QSS_Exit)(setq *error* OldErr)(princ))
(defun QSS_Exit ()
  ; cleanup dialog(s) (I use list for future use in case of more dialogs)
  (mapcar '(lambda (x) (if (not (null x)) (unload_dialog x)))
	   (list QSS-Main-Dialog-fn))
  (mapcar '(lambda (x) (if (not (null x)) (close x)))
	   (list QSS-Main-Dialog-fp))
  (mapcar '(lambda (x) (if (and (not (null x)) (findfile x)) (vl-file-delete x)))
  ; reset system variables (not realy used here just for future / template purposes)
  (mapcar '(lambda (x y)(setvar (car x) y)) sysvar-names sysvar-old-values)
  (term_dialog) (gc) (princ "\nDone") (terpri) (princ)
  ; release actDbx & RegExp
  (foreach obj (list actDbx RegExp) (vl-catch-all-apply 'vlax-release-object (list obj)))
  ;;; release Excel
  (Exit_Excel)
;;; ------------------------------------------------------ End of Init Section ------------------------------------------------------------
;;; --- Registry Settings ------------------------------- Begin Registry Settings ------------------------------- Registry Settings --- ;;;
(defun InitDefaultRegistrySettings ()
  (setq regkey "HKEY_CURRENT_USER\\SOFTWARE\\QSS\\")
  ;;; regkeys must be strings ("variable name" "default value")
  (setq regvar
     (list
       '("QSS-Search-Folder" "")				;;; String - Folder where lisp files are placed
       '("QSS-Include-Subfolders" "0")				;;; Toggle - "0" scan only search folder, "1" also scan subfolders
       '("QSS-Filename-Extension-Filter" "lsp,txt,dwg")		;;; String - delimited by , (comma) like "lsp,dwg"
       '("QSS-Search-String-Filter" "")				;;; String - delimited by | (Pipe) like "Rlx|Dragon"
       '("QSS-Case-Sensitive" "0")				;;; Toggle - "0" don't care, "1" case sensitive search
       '("QSS-Whole-Words-Only" "0")				;;; Toggle - "0" nope , "1" jip
  (mapcar '(lambda (x)(set (read (car x)) (cadr x))) regVar)
(defun ReadSettingsFromRegistry ()
  (mapcar '(lambda (x / n v)
    (if (setq v (vl-registry-read regkey (setq n (car x)))) (set (read n) v) (vl-registry-write regkey n (cadr x)))) regvar))
(defun WriteSettingsToRegistry ()
  (mapcar '(lambda (x) (vl-registry-write regkey (car x) (eval (read (car x))))) regvar))
;;; --- Registry Settings -------------------------------- End Registry Settings -------------------------------- Registry Settings --- ;;;
;;; --- dialog section ----------------------------------- begin dialog section ------------------------------------ dialog section --- ;;;
; SaveDialogData evaluates all vars from %tl and returns them as a list, reset does the opposite
(defun Save_Dialog_Data      (%tl) (mapcar '(lambda (x) (eval (car x))) %tl))
(defun Reset_Dialog_Data (%tl %rd) (mapcar '(lambda (x y) (set (car x) y)) %tl %rd))
(defun Set_Dialog_Tiles      (%tl) (mapcar '(lambda (x / v) (if (eq 'str (type (setq v (eval (car x))))) (set_tile (cadr x) v))) %tl))
(defun Main_Dialog_Cancel       () (Reset_Dialog_Data MainDialog-tl MainDialog-rd) (WriteSettingsToRegistry))
(defun QSS_Main_Dialog_Create ()
  (if (and (setq main-dialog-fn (vl-filename-mktemp "Main.dcl")) (setq main-dialog-fp (open main-dialog-fn "w")))
    (mapcar
      '(lambda (x)(write-line x main-dialog-fp))
       (list "QSS : dialog {label=\"QSS - Quick String Search (RLX May 2026)\";"
             ":boxed_column {label=\"Search folder :\";"
               ":row {:edit_box {key=\"eb_search_folder\";}"
                     ":button {fixed_width=true;width=12;key=\"bt_select_search_folder\";label=\"Select\";}}"
               ":toggle {label=\"Include subfolders\";key=\"tg_include_subfolders\";}}"
             ":boxed_row {label=\"Filename Extension Filter [ , ]\"; :edit_box {key=\"eb_filename_extension_filter\";}}"
	     ":boxed_column {label=\"Search string filter [ | ]\";"
               ":edit_box {key=\"eb_search_string_filter\";}"
               ":row {:toggle {label=\"Case sensitive\";key=\"tg_case_sensitive\";}"
               "      :toggle {label=\"Whole words only\";key=\"tg_whole_words_only\";}}}"
             "spacer;"
             ":concatenation {gap; :image {height=1.5;width=91;key=\"the_bar\";color=dialog_background;}gap;}"
             "spacer;ok_cancel;spacer;"
             "gap:image {fixed_width=true;width=0.001;color=dialog_background;}"
  (if main-dialog-fp (close main-dialog-fp))(gc)
(defun QSS_Main_Dialog_Start ( / drv )
  (if (null main-dialog-fn)(QSS_Main_Dialog_Create))
  (if (and (setq main-dialog-dcl (load_dialog main-dialog-fn)) (new_dialog "QSS" main-dialog-dcl))
      (QSS_Main_Dialog_Update)
      (QSS_Main_Dialog_Action)
      (setq drv (start_dialog))
      (cond
	((= drv  0)(Main_Dialog_Cancel))
	((= drv  1)(WriteSettingsToRegistry)(QSS_DoIt))
        ((= drv  2)(WriteSettingsToRegistry)(Show_Hit_List))
  (if main-dialog-fn (vl-file-delete main-dialog-fn))
  (setq main-dialog-fn nil)
(defun QSS_Main_Dialog_Update ()
  (setq MainDialog-tl
	 '((QSS-Search-Folder "eb_search_folder")
           (QSS-Include-Subfolders "tg_include_subfolders")
           (QSS-Filename-Extension-Filter "eb_filename_extension_filter")
           (QSS-Search-String-Filter "eb_search_string_filter")
           (QSS-Case-Sensitive "tg_case_sensitive")
           (QSS-Whole-Words-Only "tg_whole_words_only")
  ;;; rd = reset data (val1 val2 ...) , in case of a cancel store original values before start of dialog
  (if (null MainDialog-rd) (setq MainDialog-rd (Save_Dialog_Data MainDialog-tl)))
  ;;; set edit boxes and toggle values
  (Set_Dialog_Tiles MainDialog-tl)
(defun QSS_Main_Dialog_Action ()
  (mapcar '(lambda (x)(action_tile (car x) (cadr x)))
    '(("cancel" "(done_dialog 0)") ;("accept" "(done_dialog 1)")
      ("accept" "(QSS_Pre_Scan)")
      ("eb_search_folder" "(setq QSS-Search-Folder $value)")
      ("bt_select_search_folder" "(QSS_select_search_folder)")
      ("tg_include_subfolders" "(setq QSS-Include-Subfolders $value)")
      ("eb_filename_extension_filter" "(setq QSS-Filename-Extension-Filter $value)")
      ("eb_search_string_filter" "(setq QSS-Search-String-Filter $value)")
      ("tg_case_sensitive" "(setq QSS-Case-Sensitive $value)")
      ("tg_whole_words_only" "(setq QSS-Whole-Words-Only $value)")
(defun QSS_select_search_folder ( / f)
  (if (setq f (GetShellFolder "Select search folder"))(set_tile "eb_search_folder" (setq QSS-Search-Folder f))))
;;; first handle the file & folder stuf side of things
(defun QSS_Pre_Scan ( / subfolder-flag case-flag filename-extension-filter-list search-string-filter-list folder-list tmp-l)
  ;;; make sure include subfolders and case-sensitive flags are either T or nil
  (if (not (eq QSS-Include-Subfolders "1")) (setq subfolder-flag nil) (setq subfolder-flag T))
  (if (not (eq QSS-Case-Sensitive "1")) (setq case-flag nil) (setq case-flag T))
  ;;; check all parameters
  (cond
    ;;; verify search folder
    ((not (folder-p QSS-Search-Folder))
     (alert (strcat "Invalid search folder : " (vl-princ-to-string QSS-Search-Folder))))
    ;;; verify filename filter (like "lsp,dwg") -> pimpext -> ("*.lsp" "*.dwg")
    ((or (void QSS-Filename-Extension-Filter)
         (not (vl-consp (setq tmp-l (SplitStr QSS-Filename-Extension-Filter ","))))
         (not (vl-every '(lambda (s) (wcmatch s "*`.*")) (setq filename-extension-filter-list (pimpex tmp-l)))))
     (alert (strcat "Bad filename filter : " (vl-princ-to-string QSS-Filename-Extension-Filter))))
    ;;; verify search string filter
    ((or (void QSS-Search-String-Filter)
         (not (vl-consp (setq search-string-filter-list (SplitStr QSS-Search-String-Filter "|")))))
     (alert (strcat "Invalid search string : " (vl-princ-to-string QSS-Search-String-Filter))))
    ;;; maybe do file list check here
    (t
     ;;; show something wonderfull is about to happen
     (clear_bar)(set_tile "the_bar" " working...")
     (if (eq QSS-Include-Subfolders "1")
       (setq folder-list (QSS_FindSubfolders QSS-Search-Folder)) (setq folder-list (list QSS-Search-Folder)))
     ;;; just a little delay to enjoy the view, exterminate when it gets anoying
     (wait 1.5)
     (setq total-file-list (QSS_FindFiles folder-list filename-extension-filter-list))
     (wait 1.5)
     (if (not (vl-consp total-file-list))
       (alert (strcat "no files found :\nFolder : " (vl-princ-to-string QSS-Search-Folder)
                      "\nFilter : " (vl-princ-to-string filename-extension-filter-list)))
       (QSS_Process_Total_File_List)
    );;; end t
  );;; end cond
);;; end defun
;;; clear previous status
(defun clear_bar () (start_image "the_bar")(fill_image 0 0 (dimx_tile "the_bar") (dimy_tile "the_bar") 141)(end_image))
(defun Show_Hit_List () (if (vl-consp hit-list)
  (dplm+ hit-list (strcat "Number of files found : " (itoa (length hit-list)))) (alert "Sorry search returned no results")))
(defun QSS_Process_Total_File_List ( / stream pattern file-count n l hit)
  (set_tile "the_bar" (strcat "Number of files to search : " (setq n (itoa (length total-file-list)))))
  (setq file-count 0 pattern QSS-Search-String-Filter)
  (if (eq QSS-Case-Sensitive "1")(setq ignoreCase nil)(setq ignoreCase T))
  (foreach fn total-file-list
    ;;; split here for different types of extensions
    ;;; lisp & text files can be read by stream , dwg by odbx
    ;;; (strcase (last (fnsplitl "c:\\temp\lisp\acad.dwg")) t) -> ".dwg"
    (setq ext (strcase (last (fnsplitl fn)) t))
    ;;; for now only *.lsp, *.txt & *.dwg,
    ;;; bucketlist xls/xlsx & pdf but they may need different approach or 3rd party software, so low priority
    (cond
      ((wcmatch ext "*`.lsp,*`.txt")
       (if (and (setq stream (_ReadStream fn 0))
                (setq rtn (= (vlax-invoke (InitRegExp pattern ignoreCase nil) 'Test stream) -1))
                (not (member fn hit-list))) (setq hit-list (cons fn hit-list))))
      ;;; regex_string_search last parameter is for return as list
      ;;; if T -> return all strings in doc as list, if nil -> return nil or filename if pattern is found
      ((wcmatch ext "*`.dwg")
       (if (and (setq dbx-doc (odbx_open fn)) (setq hit (regex_string_search dbx-doc pattern nil)))
      ;;; excel : Scan_Excel returns T or nil if regex pattern is found
      ((wcmatch ext "*`.xls,*`.xlsx")
       (if (and (Scan_Excel fn) (not (member fn hit-list))) (setq hit-list (cons fn hit-list))))
    ;;; length of hit-list
    (setq l (itoa (length hit-list)))
    (clear_bar)
    ;;; update status message
    (set_tile "the_bar" (strcat "   ( " (setq *spin* (Spinbar *spin*)) " ) Scanning files [" (itoa file-count) " of " n "] - found " l))
    ;;; increase file counter
    (setq file-count (1+ file-count))
  (done_dialog 2)
;;; --- dialog section ------------------------------------ end dialog section ------------------------------------- dialog section --- ;;;
;--- + + + --------------------------------------------- Begin of tiny lisp section --------------------------------------------- + + + ---
(defun void (x) (or (not x) (= "" x) (and (eq 'STR (type x)) (not (vl-remove 32 (vl-string->list x))))))
(defun wait (sec / stop)(setq stop (+ (getvar "DATE") (/ sec 86400.0)))(while (> stop (getvar "DATE"))))
(defun string-p (s) (if (= (type s) 'str) t nil))
(defun folder-p (f) (if (and (= (type f) 'str) (vl-file-directory-p f)) t nil))
;;; (Dos_Path (strcat (getvar "dwgprefix") (getvar "dwgname"))) -> "C:\\USERS\\ROB\\DOCUMENTS\\ACAD\\QUICKSTRINGSEARCH.DWG\\"
(defun Dos_Path ($p)
  (if (= (type $p) 'STR) (strcase (strcat (vl-string-right-trim "\\" (vl-string-translate "/" "\\" $p)) "\\")) ""))
;;; (vl_path (strcat (getvar "dwgprefix") (getvar "dwgname"))) -> "c:/users/rob/documents/acad/quickstringsearch.dwg/"
(defun vl_path ($p)(if (= (type $p) 'str)
   (strcat (vl-string-right-trim "\\/" (strcase (vl-string-translate "\\" "/" $p) t)) "/") ""))
; generic getfolder routine with possibility to create a new subfolder (GetShellFolder "select path")
(defun GetShellFolder ( m / f s) (if (and (setq s (vlax-create-object "Shell.Application"))
  (setq f (vlax-invoke s 'browseforfolder 0 m 0 "")))(setq f (vlax-get-property (vlax-get-property f 'self) 'path))
     (setq f nil))(vl-catch-all-apply 'vlax-release-object (list s))
  (if f (strcat (vl-string-right-trim "\\" (vl-string-translate "/" "\\" f)) "\\")))
; returns T if no errors occurred during program execution
(defun _ShellOpen ( $f / it sh )
  (if (and (not (void $f)) (setq $f (findfile $f)) (setq sh (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application")))
    (progn (setq it (vl-catch-all-apply 'vlax-invoke (list sh 'open $f)))(vlax-release-object sh)(not (vl-catch-all-error-p it)))
      (progn (prompt "\nShell application was unable to open file")(setq it nil))))
;;; d = directory , e = extension like "*.dwg" , f = flag include subfolders (any value or nil)
;;; test : (length (alf "d:/temp/lisp" "*.dwg" t))  (length (alf "d:/temp/lisp" "*.dwg" nil))
;;; (setq l (alf "c:/temp/lisp" "*.xlsx" t)) (setq l (alf "c:\\temp\\lisp\\" "*.txt" t))
(defun alf (d e f) (setq d (vl-string-right-trim "/" (vl-string-translate "\\" "/" d)))
  (if f (apply 'append (cons (if (vl-directory-files d e)(mapcar '(lambda (x) (strcat d "/" x)) (vl-directory-files d e)))
    (mapcar '(lambda (x) (alf (strcat d "/" x) e f))(vl-remove ".." (vl-remove "." (vl-directory-files d nil -1))))))
      (mapcar '(lambda (x) (strcat d "/" x))(vl-directory-files d e 1))))
;;; (SplitStr "a,b,c" ",") -> ("a" "b" "c")
(defun SplitStr (s d / p)
  (if (setq p (vl-string-search d s))(cons (substr s 1 p)(SplitStr (substr s (+ p 1 (strlen d))) d))(list s)))
;;; (lst->csv '("a" "b" "c") "|") -> "a|b|c"
(defun lst->csv (%l $s)
  (apply 'strcat (cdr (apply 'append (mapcar (function (lambda (x) (list $s x))) %l)))))
;;; (sandwich '("a" "b" "c") "*") -> '("*a*" "*b*" "*c*")
;;; for whole word search each string in regex string has to begin and end with \\b
(defun sandwich (%l %c) (mapcar '(lambda (s)(strcat %c s %c)) %l))
;;; make sure each extension begin with *. (pimpex (splitstr "lsp,dwg" ",")) -> ("*.lsp" "*.dwg")
(defun pimpex (%l) (mapcar '(lambda (s)(strcat "*." (vl-string-trim "*." s))) %l))
; choose from list (cfl '("1" "2" "3"))
(defun cfl (l / f p d r) (and (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w"))
 (princ "cfl:dialog{label=\"Choose\";:list_box{key=\"lb\";width=40;}ok_cancel;}" p)
  (not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "cfl" d)
   (progn (start_list "lb")(mapcar 'add_list l)(end_list)(action_tile "lb" "(setq r (nth (atoi $value) l))(done_dialog 1)")
    (action_tile "accept" "(setq r (get_tile \"lb\"))(done_dialog 1)")(action_tile "cancel" "(setq r nil)(done_dialog 0)")
     (start_dialog)(unload_dialog d)(vl-file-delete f))) (cond ((= r "") nil)(r r)(t nil)))
;;; display list (plus message)
(defun dplm (l m / f p d w) (and (vl-consp l) (setq l (mapcar 'vl-princ-to-string l)) (setq w (+ 5 (apply 'max (mapcar 'strlen l))))
  (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w")) (princ (strcat "cfl:dialog{label=\"" m "\";:list_box {key=\"lb\";"
   "width="(itoa w)";}ok_only;}") p)(not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "cfl" d)(progn (start_list "lb")
     (mapcar 'add_list l)(end_list)(action_tile "accept" "(done_dialog)")(start_dialog)(unload_dialog d)(vl-file-delete f))))
;;; possibility to load / save the list and ShellOpen selection
(defun dplm+ (l m / load_list save_list open_item f p d w pick)
  (defun load_list ()(alert "Under construction : Load List"))  (defun save_list ()(alert "Under construction : Save List"))
  (defun open_item ( / i f)(if (and (vl-consp l)(not (null pick))(setq i (atoi pick))(setq f (nth i l))(setq f (findfile f)))
    (cond ((wcmatch (strcase (last (fnsplitl f)) t) "*.dwg")(setq qss-open-dwg-on-your-way-out f)(done_dialog))(t (_ShellOpen f)))))
  (if (not (vl-consp l)) (setq l (list "No results")) (setq l (mapcar 'vl-princ-to-string l)))
  ;;; make width dialog based on longest string in list
  (write-line (strcat "cfl:dialog{label=\"" m "\";") p)
  (write-line (strcat ":list_box {key=\"lb\";width=" (itoa w) ";height=25;}") p)
  (write-line (strcat ":column {:row {fixed_width=true;alignment=centered; :button {key=\"bt_load\";label=\"Load\";}"
                          ":button {key=\"bt_save\";label=\"Save\";} :button {key=\"bt_open\";label=\"Open\";}}}") p)
  (write-line "ok_only;}" p)
  (if p (close p))
  (if (and (< 0 (setq d (load_dialog f))) (new_dialog "cfl" d))
      (action_tile "accept" "(done_dialog)") (action_tile "lb" "(setq pick $value)") (action_tile "bt_load" "(load_list)")
      (action_tile "bt_save" "(save_list)")  (action_tile "bt_open" "(open_item)") (start_dialog) (unload_dialog d) (vl-file-delete f)
;--- + + + ---------------------------------------------- End of tiny lisp section ---------------------------------------------- + + + ---
;;; --- Odbx ---------------------------------------------- Begin Odbx Section ----------------------------------------------- Odbx --- ;;;
(defun GetAllOpenDocs ()
  (or actApp (setq actApp (vlax-get-acad-object))) (or actDoc (setq actDoc (vla-get-ActiveDocument actApp)))
    (or actDocs (setq actDocs (vla-get-documents actApp)))
  (vlax-for doc actDocs (if (= 1 (vlax-variant-value (vla-getvariable doc "DWGTITLED"))); no nameless drawings
    (setq AllOpen (cons (cons (strcase (vla-get-fullname doc)) doc) AllOpen))))
(defun _ReleaseAll ()
  (mapcar '(lambda(x) (if (and (= 'vla-object (type x)) (not (vlax-object-released-p x)))
    (vlax-release-object x))(set (quote x) nil)) (list actLay actDoc actDocs actApp actDbx))(gc))
    (vlax-release-object x))(set x nil)) (list 'doc 'actLay 'actDoc 'actDocs 'actApp 'actDbx))(gc))
(defun _InitObjectDBX ()(or actApp (setq actApp (vlax-get-acad-object)))
  (or actDoc (setq actDoc (vla-get-ActiveDocument actApp)))(or AllOpen (setq AllOpen (GetAllOpenDocs)))
  (setq actDbx (vl-catch-all-apply 'vla-getinterfaceobject (list actApp (dbx_ver))))
  (if (or (null actDbx)(vl-catch-all-error-p actDbx))(progn (princ "\nObjectDbx not available")(setq actDbx nil)))
  actDbx
(defun odbx_open ( $dwg / _pimp doc) (or AllOpen (GetAllOpenDocs))
  (defun _pimp (s) (strcase (vl-string-trim " ;\\" (vl-string-translate "/" "\\" s))))
  (cond ((or (void $dwg) (not (findfile $dwg)))(princ "\nInvalid drawing")(setq doc nil))
	((not (or actDbx (_InitObjectDBX)))(princ "\nObjectDbx not available")(setq doc nil))
        ((setq doc (cdr (assoc (_pimp $dwg) AllOpen))))
	((vl-catch-all-error-p (vl-catch-all-apply 'vla-Open (list actDbx (findfile $dwg))))
	 (princ "\nUnable to open drawing.")(setq doc nil))
	(t (setq doc actDbx)))
  doc
(defun odbx_close ( %doc ) (if (and (= 'vla-object (type %doc))
  (not (vlax-object-released-p %doc)))(progn (vlax-release-object %doc))(setq %doc nil)))
(defun dbx_ver ( / v)
  (strcat "objectdbx.axdbdocument" (if (< (setq v (atoi (getvar 'acadver))) 16) "" (strcat "." (itoa v)))))
;;; little test function to find all strings (txt/att etc) in all drawings in a folder
(defun c:test1 ( / actDoc actDocs actApp actDbx RegExp dbx-doc write_result show_result
                 search-folder dwg-list rtn result-list search-pattern result-list-fn)
  ;;; init vl functions, odbx & regexp
  (vl-load-com) (_InitObjectDBX) (or RegExp (setq RegExp (vlax-create-object "VBScript.RegExp")))
  (defun write_result (lst fn / fp)
    (cond
      ((not (vl-consp lst))
       (alert "Computer says no : empty result list, nothing to write"))
      ((or (not (= (type fn) 'STR)) (not (setq fp (open fn "w"))))
       (alert (strcat "unable to write to : " (vl-princ-to-string fn))))
      ;;; format lst : ( ("dwgname1" . ("str1" "str2" ...)) ...)
      (t
       (write-line (strcat "Scanned " (itoa (length lst)) " drawings\n") fp)
       (foreach item lst
         (write-line (car item) fp)
         (foreach str (cdr item) (write-line (vl-princ-to-string str) fp))
         (write-line "\n--\n" fp)
    (if fp (progn (close fp)(gc)(gc)))
  (defun show_result (fn)
    (if (and fn (setq fn (findfile fn)))
      (startapp "notepad" fn)
      (alert (strcat "Computer says no : unable to read from : " (vl-princ-to-string fn)))
  (setq search-pattern "*" result-list-fn "C:\\Temp\\QuickStringSearchResult.txt")
  (cond
    ;;; hard coded for test, could be replaced with something like :
    ;;; ((not (or (vl-file-directory-p (setq search-folder "C:\\Temp\\Lisp\\"))
    ;;;           (setq search-folder (getfolder "Folder for string search"))))"
    ;;;  (alert (strcat "computer says no : invalid folder : " search-folder)))
    ((not (vl-file-directory-p (setq search-folder "C:\\Temp\\Lisp\\")))
     (alert (strcat "Folder " search-folder " does not exist - change folder")))
    ((not (vl-consp (setq dwg-list (vl-directory-files search-folder "*.dwg"))))
     (alert (strcat "No dwg files in " search-folder)))
    (t
     ;;; if return-as-list is T regex_string_search returns all strings else T or nil if pattern is found
     (setq return-as-list T)
     (foreach dwg dwg-list
       (if (setq dbx-doc (odbx_open dwg))
         (if (vl-consp (setq rtn (regex_string_search dbx-doc search-pattern return-as-list)))
           (setq result-list (cons (cons dwg rtn) result-list)))
         (princ (strcat "\nUnable to open " dwg))
     (_ReleaseAll)
  ;;; release RegExp
  (if (= 'vla-object (type RegExp))(vlax-release-object RegExp))
  (if (vl-consp result-list)
    (progn (write_result result-list result-list-fn) (show_result result-list-fn))
    (princ (strcat "\nNo text was found in dwg files in " (vl-princ-to-string search-folder)))
;;; doc = duh , pat = duh , ral = return as list , if T return all strings , if nil test for pattern and return nil or T
(defun regex_string_search (doc pat ral / pat-p pattern ingnoreCase global
                            blocks objName textStr atts result s tableRow tableCol)
  ;;; not realy needed because als called in test function
  ;;; *** still to do create regex version, not sure pat-p is working as intended
  ;;; test if pattern is found in list of strings (RegExp needs to be initialized)
  (defun pat-p (p l) (vl-some (function (lambda (s)(= (vlax-invoke-method RegExp 'Test s) :vlax-true))) l))
  ;;; *** still to do : apply ignore case / whole words only to pattern
  ;;; alternative : (lwcmatch "M-16427" '("As built K-16886.pdf" "As built M-16427.pdf" "As built N-16260.pdf"))
  (defun lwcmatch ( p l / r ) (foreach x l (if (vl-string-search p x)(setq r (cons x r)))) r)
  ;;; (re)init regex pattern (QSS-Search-String-Filter) is something like "Fikkie|Rlx"
  (setq pattern QSS-Search-String-Filter global T)
  (InitRegExp pattern ignoreCase global)
  ;;; go through all document objects and retrieve textstring, return as list or test with regex (pat-p)
  (setq blocks (vla-get-blocks doc))
  (if (/= pat "")
      (vlax-for block blocks
        (vlax-for obj block
          (setq objName (vlax-get-property obj 'ObjectName))
          (setq textStr nil)
          ;;; Filter objects & get textString
          (cond
            ;; Text en MText
            ((vl-position objName '("AcDbText" "AcDbMText"))
             (setq textStr (vlax-get-property obj 'TextString)))
            ;; Old Leaders & Dimensions
            ((vl-position objName '("AcDbLeader" "AcDbDimension" "AcDbRotatedDimension" "AcDbAlignedDimension"))
             (if (vlax-property-available-p obj 'TextOverride)
               (setq textStr (vlax-get-property obj 'TextOverride))))
            ;; Modern MultiLeaders (MLeader)
            ((= objName "AcDbMLeader")
             (if (= (vlax-get-property obj 'ContentType) 2) ; 2 = acMTextContent
               (setq textStr (vlax-get-property obj 'TextString))))
            ;; Block Reference with Attributes
            ((= objName "AcDbBlockReference")
             (if (= (vlax-get-property obj 'HasAttributes) :vlax-true)
                 (setq atts (vlax-invoke obj 'GetAttributes))
                 (foreach attObj atts
                   (setq s (vlax-get-property attObj 'TextString))
                   (if (and s (/= s "")) ;(= (vlax-invoke-method RegExp 'Test pat) :vlax-true))
                     (progn (setq textStr (cons  (strcat "Block " (vlax-get-property obj 'Name)
                         ", Tag : " (vlax-get-property attObj 'TagString) ", Text : " s) textStr))))
            ;; Tabellen (Scant elke cel afzonderlijk)
            ((= objName "AcDbTable")
             (setq tableRow 0)
             (while (< tableRow (vlax-get-property obj 'Rows))
               (setq tableCol 0)
               (while (< tableCol (vlax-get-property obj 'Columns))
                 (setq s (vlax-invoke obj 'GetText tableRow tableCol))
                 (if (and s (/= s "")); (= (vlax-invoke-method regex 'Test textStr) :vlax-true))
                   (setq textStr (cons  (strcat "Table [Row " (itoa tableRow) ", Col " (itoa tableCol) "]: " s) textStr)))
                 (setq tableCol (1+ tableCol))
               (setq tableRow (1+ tableRow))
          ) ;;; end cond
          ;;; put result in list
          (cond
            ((null textStr))
            ((vl-consp textStr) (foreach x textStr (setq result (cons x result))))
            (t (setq result (cons textStr result)))
        ) ;;; vlax-for block
      ) ;;; vlax-for blocks
    ) ;;; end progn
  ) ;;; end if (/= pat "")
  ;;; if ral = T return all strings as list else only return T if pattern is found in result list
  ;;; *** still to do replace lwcmatch with regex version (pat-p)
  ;(if ral result (lwcmatch pat result))
  (if ral result (pat-p pattern result))
;;; --- Odbx ---------------------------------------------- End Odbx Section ------------------------------------------------- Odbx --- ;;;
;;; --- RegExp -------------------------------------------------- RegExp --------------------------------------------------- RegExp --- ;;;
;;; Separate multiple patterns by pipe-operator |
;;; (vlax-put-property regexp "Pattern" "Rlx|CadTutor|Visual Lisp")
;;; Whole words only (not "Rlxie" when searching for "Rlx"):
;;; (vlax-put-property regexp "Pattern" "\\bRlx\\b|\\bCadTutor\\b|\\bVisual Lisp\\b")
;;; pattern	: Pattern to search.
;;; ignoreCase	: If non nil, the search is done ignoring the case.
;;; global	: If non nil, search all occurences of the pattern, if nil, only searches the first occurence.
(defun InitRegExp (pattern ignoreCase global)
  (vlax-put RegExp 'Pattern pattern)
  (if ignoreCase (vlax-put RegExp 'IgnoreCase acTrue)(vlax-put RegExp 'IgnoreCase acFalse))
  (if global (vlax-put RegExp 'Global acTrue)(vlax-put RegExp 'Global acFalse))
  RegExp
;;; len :  Number of bytes to read. If non numeric, < 1 or greater than the number of bytes in file everything is returned.
;;; iomode : 1 = read, 2 = write, 8 = append , format : 0 = ascii, -1 = unicode, -2 = system default
(defun _ReadStream ( path len / fso file stream result )
  (vl-catch-all-apply
    '(lambda ( / iomode format size )
       (setq iomode 1 format 0 fso (vlax-create-object "Scripting.FileSystemObject") file (vlax-invoke fso 'GetFile path)
	     stream (vlax-invoke fso 'OpenTextFile path iomode format) size (vlax-get file 'Size)
	     len (if (and (numberp len) (< 0 len size)) (fix len) size) result (vlax-invoke stream 'read len))
       (vlax-invoke stream 'Close)
  (if stream (vlax-release-object stream))(if file (vlax-release-object file))(if fso (vlax-release-object fso))
  result
;;; T if pattern is found else nil
(defun c:test2 ( / fn pattern stream ignoreCase rtn)
  (setq fn "C:\\Temp\\Lisp\\RlxBatch.lsp")
  (setq ignoreCase T)
  (setq pattern "-publish")
  ;(setq pattern "dragon")
  (and
    (= (type fn) 'STR)
  rtn
;;; --- Excel ---------------------------------------------------- Excel ---------------------------------------------------- Excel --- ;;;
(defun Init_Excel ()
  (or xlApp (setq xlApp (vlax-get-or-create-object "Excel.Application")))
  (vla-put-visible xlApp :vlax-false)
(defun Exit_Excel ()
  (if xlApp
      (vl-catch-all-apply 'vlax-invoke-method (list xlWorkbook 'Close :vlax-false))
      ;(vlax-invoke-method xlWorkbook 'Close :vlax-false)	;;; close workbook without saving
      ;(vlax-invoke-method xlApp 'Quit)				;;; may want to skip this because it closes all workbooks
      (vlax-release-object xlSheets)				;;; ok to release
      (vlax-release-object xlWorkbook)				;;; ok to release
      (vlax-release-object xlApp)				;;; ok to release
;;; create range letters "A1:" + Letter & number like "A1:Z10"
(defun _cl (i / n) (if (< i 27)(chr (+ 64 i))(if (= 0 (setq n (rem i 26)))
     (strcat (_cl (1- (/ i 26))) "Z")(strcat (_cl (/ i 26))(chr (+ 64 n))))))
;;; retrieve all values from Excel workbook
(defun Scan_Excel (fn / f xlUsedRange rows xlValue _safearray tmp-lst result excel-range excel-used-range excel-max-row excel-max-column
                        excel-max-range excel-variant excel-value excel-to-list l2 l3 pattern ignoreCase global)
  ;;; just to make sure regex is up and running
  (if (and fn (string-p fn) (setq f (findfile fn)))
      (Init_Excel)
      (setq xlWorkbooks (vlax-get-property xlApp 'Workbooks))
      (setq xlWorkbook (vlax-invoke-method xlWorkbooks 'Open f))
      (setq xlSheets (vlax-get-property xlWorkbook 'Sheets))
      (vlax-for xlSheet xlSheets
        (setq xlUsedRange (vlax-get-property xlSheet 'UsedRange))
        ;;; Set limits on number of rows, not sure what size would be to much for AutoCad to handle
        (setq rows (vlax-get-property (vlax-get-property xlUsedRange 'Rows) 'Count))
        (if (< rows 500000)
            ;(setq xlValue (vlax-get-property xlUsedRange 'Value))
            ;(setq _safearray nil tmp-lst nil)
            ;(if (= (type xlValue) 'variant) (setq _safearray (vlax-variant-value xlValue)))
	    ;(if (= (type _safearray) 'safearray) (setq tmp-lst (vlax-safearray->list _safearray)))
	    (and
              (setq excel-variant (vlax-get-property xlUsedRange 'Value))
	      (setq excel-value (vlax-variant-value excel-variant))
              (setq excel-to-list (vlax-safearray->list excel-value))
	      (setq tmp-lst
                     (vl-remove nil
                                  (vl-remove nil
                                    (mapcar '(lambda (y / val)
                                               (setq val (vl-catch-all-apply 'vlax-variant-value (list y)))
                                               (if (vl-catch-all-error-p val) nil val)
                                             x)
                                excel-to-list
              (setq result (append result tmp-lst))
          (princ
            (strcat
              "\nSkipped " (vl-filename-base fn) " Tab '"
                         (vlax-get-property xlSheet 'Name) "' : to many rows (" (itoa rows) ")."))
        (vlax-release-object xlUsedRange)
        (vlax-release-object xlSheet)
  ;;; merge list of lists ( (...) (...) ...) -> (... ... ...) -> (setq l2 (apply 'append result))
  ;;; make sure all elements are string -> (setq l3 (mapcar 'vl-princ-to-string l2))
  ;;; test if pattern is found in result list , returns T or nil
  (if (vl-consp result) (pat-p pattern (mapcar 'vl-princ-to-string (apply 'append result))))
;(setq l2 (apply 'append (mapcar '(lambda (x)(mapcar '(lambda (y)(append x y)) a)) b)))
(defun c:test3 () (if (Scan_Excel "c:/temp/test.xlsx")
    (alert "Pattern found in c:/temp/test.xlsx") (alert "Pattern found in c:/temp/test.xlsx")))
;;; -------------------------------------------------- Begin of Progress Bar Section ------------------------------------------------------
; (setq lst (acad_strlsort (QSS_FindSubfolders "c:/temp/lisp")))
(defun QSS_FindSubfolders ( d / l r s msg ) (setq l (list d))
  (while l (setq s nil)(foreach d l (setq s (append s (mapcar (function (lambda ( x ) (strcat d "/" x)))
    (vl-remove-if (function (lambda (x)(member x '("." ".."))))(vl-directory-files d nil -1))))))(setq r (append s r) l s)
      (start_image "the_bar")(fill_image 0 0 (dimx_tile "the_bar") (dimy_tile "the_bar") 131)(end_image)
      (setq msg (strcat "   ( " (setq *spin* (Spinbar *spin*))" ) Scanning for subfolders : " (itoa (length r))))
      (set_tile "the_bar" msg)
  ;;; make sure sourcefolder is part of result
  (cons d r)
;;; (setq rtn (QSS_FindFiles '("c:/temp/lisp") '("*.lsp" "*.txt")))
(defun QSS_FindFiles (folder-list extension-list / folder result result-list status)
  ;;; folder-list is list of all (sub)folders to scan , make sure all folders end with "/"
  (setq folder-list (acad_strlsort (mapcar 'vl_path folder-list)))
  (foreach folder folder-list
    (foreach ext extension-list
      (if (vl-consp (setq result (mapcar '(lambda (x) (strcat folder x))(vl-directory-files folder ext 1))))
        (setq result-list (append result-list result))
    (setq status (strcat "   ( " (setq *spin* (Spinbar *spin*)) " ) Scanning for files : " (itoa (length result-list))))
    (set_tile "the_bar" status)
  result-list
; funny little indicator found in StripMtext.lsp
;(princ (strcat "\r (" (setq s (Spinbar s)) ") Files : " (itoa (setq i (1+ i))) "\t\t"))
(defun SpinBar (spin) (cond ((= spin "\\") "|") ((= spin "|") "/") ((= spin "/") "-") (t "\\")))
;;; ---------------------------------------------------- End of Progress Bar Section -------------------------------------------------- ;;;
(princ "\nRlx May'26 - Type QSS for main function or test1 for test function (all text from all dwgs in c:/temp/lisp/")
Most info included in lisp file. Just a quick string search for lsp, txt & dwg files.
App is still in beta and hasn’t been field tested yet. Still working on the ignore case & whole word options.
IT killed my Total Commander so had to write my own search engine
Start with QSS , select folder , extension like lsp,dwg and search string like Rlx
Type in extensions like lsp,txt (with comma) and for text use pipe symbol like Rlx|Dragon
for now only lsp,txt and dwg are supported , haven't been able to make it work on pdf
Result is shown in list box. You can select item and open.
If item is lsp or txt , notepad will start.
If item is dwg , app stops and opens dwg (load and save buttons not working yet, not sure I need them.
Edited by rlx
added excel support + error catch retrieving excel value
  • Like 6
@RLX I use windows Findstr under CMD for search txt and lsp etc, just having  a play how to call a bat file from CAD.  I used ;
(startapp "D:\\acadtemp\\test.bat insert")
CMD option manually
Windows lower left CMD
Cd d:\alan\lisp
Findstr "insert" *.lsp
Bat file, I have one called fnd.bat
D:
Cd\alan\lisp
findstr %1 *.lsp
pause
Pretty sure Findstr supports search sub directories. You should also be able to redirect to a file > filename.
You are right use lisp to write the bat file, choose directory etc. It does not work with DWG files.
Edited by BIGAL
I also used to use theDOS thing , but its not nearly as sexy :
(sorry , <> has been disabled by my work , file upload as well and if I try to use a bat file admin locks me down)
Will post tonight
  • Agree 1
Have they locked Powershell also ? I use it at times.
Converting the lisp code to .net would speed up searching the txt & lsp files, in lisp directory I have 1500+ lsp files. But chances are your admin has that locked.
Nice work IT! 🫣
They got you to spend hours trying to circumvent the limitations they forced upon their employees just to make it workable.
  • Agree 1
Yeah , well , I'm afraid to tempt 'the Gods' how much worse it can get haha. Big reorganization on its way and we hope things can only get better , but that's maybe tempting fate :twisted:
In the mean while got it working (I think) for excel workbooks too , but gonna have to post that later when I get home tonight.
Clippy (the AI) told me without external programs like Adobe or pdf2text , its very unlikely I'm gonna be able to directly retrieve strings from a pdf. Since I cant install any software other than provided by the company that's not gonna happen. Only way would be pdfimport and pdfshx but that would defeat the purpose of this appie.
If the text is Searchable in the PDF. Windows Explorer will work. if the PDF is just an image then it wont work and have to use Adobe's OCR to convert them to be searchable.
-Edit
Tho not 100%  some stuff come in weird like fractions or text between white space and pictures.
Edited by mhupp
Before I used this :
(defun GetFolder ( m / f s) (if (and (setq s (vlax-create-object "Shell.Application"))
  (setq f (vlax-invoke s 'browseforfolder 0 m 65536 "")))(setq f (vlax-get-property (vlax-get-property f 'self) 'path))
     (setq f nil))(vl-catch-all-apply 'vlax-release-object (list s)) f)
(defun findstring ( / a b c d e)
  (setq a (GetFolder "Select folder for string search"))
  (setq b (getstring "\nEnter string to search for : " T))
  (setq c (getstring "\nFile extension (lsp) : ")) (if (eq c "") (setq c "lsp"))
  (setq d (strcat a "\\result.txt"))
  (setq e (strcat "findstr /i /s \"" b "\" " a "\\*." c " > " d))
  (command "shell" e)
  (gc)(gc)
  ;;; natural delay for system to clear cache and write file to disk
  (alert "search completed")
  (startapp "notepad" d)
(defun c:dfs ()(findstring))
(defun c:t1 ()(findstring)(princ))
This code only works for text based files.
Have updated code in my first post with Excel support. Valid extensions are now lsp , txt , dwg , xls and xlsx
I have a license for able2extract on my home computer and also written something that uses pdfattach and import for readable pdf's.
Though I can take that route, it's not like shoot & forget , often more than one step is needed.
But it is what it is... most pdf's I get are pretty poor quality , some by accident and some not because a 3rd party wants you as a returning client if you know what I mean.
Edited by rlx
  • Like 2
I know where your coming from where I worked last some 1000 pc's, we were lucky and had a good relationship with IT and could explain why we wanted something and most times they would go away and think about it, but approve and install, they would come to me to do the CAD installs, with the IT guy with me for user  permissions. Each new PC was a "Hope it works" as they came preinstalled with corporate software.
Edited by BIGAL
