masao_8 Posted June 14 Posted June 14 (edited) Is it possible to use the grread function to deselect objects by holding down the SHIFT key+left click? Edited June 14 by masao_8 Quote
Steven P Posted June 14 Posted June 14 I think you would need to test for 'shift' being pressed and the test for a left mouse entity selection. Do a 'princ' on your grread loop to display what you are doing, shift and select something - which should give you what you want to test for. 2 Quote
mhupp Posted June 15 Posted June 15 Isn't that how CAD works already? you select something either by mouse clicke or window it will be highlighted hold shift to deselect it the same way. I know if you have to many things selected they are no longer highlighted. 1 1 Quote
SLW210 Posted June 15 Posted June 15 1 hour ago, mhupp said: Isn't that how CAD works already? you select something either by mouse clicke or window it will be highlighted hold shift to deselect it the same way. I know if you have to many things selected they are no longer highlighted. Doesn't that depend on PICKADD value? I do believe the default is select to add and shift select to deselect from selection set. To that end, it needs to be clarified from OP what they need, my WAG is something being already done with grread and need to deselect. AFAIK (and that's very little, mostly from my previous thread ) The left click is doable with grread, but it would ignore the SHIFT (also CTRL, etc.), so probably would need something else to show the SHIFT key is pressed. Which reminds me I need to get back to work on that and the centerline on rivers, roads, etc. problem when I get regular work caught up. 1 Quote
pkenewell Posted June 15 Posted June 15 Perhaps you could use the undocumented (acet-sys-shift-down) express tools function within the grread loop? Then you would have to manipulate highlighting with (redraw [3/4]) and use (ssadd) and (ssdel) to update the selection set. 2 Quote
pkenewell Posted June 16 Posted June 16 (edited) @masao_8 Here is a solution for a simple single selection add and SHIFT-Select to remove. Perhaps this will give you a basis for starting: ;; Function to do a simple Select/Deselect using grread. ;; By PJK - 6/16/2026 (defun pjk-grread-Select (/ done en grl grc grv ss) (if acet-load-expresstools (acet-load-expresstools)) (setq ss (ssadd)) (princ "\nSelect to add objects or SHIFT+Select to remove from selection set: ") (while (not done) (setq grl (grread T 15 2) grc (car grl) grv (cadr grl) ) (cond ((= grc 3) (if (setq en (car (nentselp grv))) (if (acet-sys-shift-down) (progn (if (ssmemb en ss)(ssdel en ss)) (redraw en 4) ) (progn (ssadd en ss) (redraw en 3) ) ) ) ) ((= grc 2) (setq done (if (vl-position grv '(13 32)) T nil)) ) ((= grc 25)(setq done T)) ) ) (if (> (sslength ss) 0) (progn (foreach i (mapcar 'cadr (ssnamex ss))(redraw i 4)) ss ) nil ) ) Edited June 16 by pkenewell 1) Added right-click completion to the loop. 2) added redraw of selection set on completion of the routine and returns nil if the selection set is empty. 4 Quote
masao_8 Posted Sunday at 05:01 PM Author Posted Sunday at 05:01 PM thanks all!! @pkenewell thanks you. this is good. but i want to use "ssget" has "quick iniget". use express tools can do it,but not express tools how to do it. (defun _redrawss (ss mode / i) (if (and ss (= (type ss) 'PICKSET) (> (sslength ss) 0)) (repeat (setq i (sslength ss)) (redraw (ssname ss (setq i (1- i))) mode) ) ) ) (defun _getwindowselection (msg p1 filter flag / gr p3 p2 p4 col winflag) (princ msg) (setq p3 nil) (while (/= 3 (car (setq gr (grread t 13 0)))) (if (= 5 (car gr)) (progn (redraw) (setq p3 (cadr gr)) (if (and p1 p3) (progn (setq p2 (list (car p3) (cadr p1) (caddr p3)) p4 (list (car p1) (cadr p3) (caddr p3)) col (if (or (eq flag "_C") (minusp (- (car p3) (car p1)))) -256 256) ) (grvecs (list col p1 p2 p1 p4 p2 p3 p3 p4)) ) ) ) ) ) (redraw) (if (and p1 p3) (progn (setq winflag (cond (flag) ((minusp (- (car p3) (car p1))) "_C") (t "_W") ) ) (if filter (ssget winflag p1 p3 (list filter)) (ssget winflag p1 p3) ) ) nil ) ) ;;BYLAYER (defun get-real-linetype (ed / lt lay layed) (setq lt (assoc 6 ed)) (if (or (null lt) (= (cdr lt) "BYLAYER")) (progn (setq lay (cdr (assoc 8 ed))) (if (setq layed (tblsearch "LAYER" lay)) (cdr (assoc 6 layed)) "CONTINUOUS" ) ) (cdr lt) ) ) ;;BYLAYER (defun get-real-color (ed / col lay layed) (setq col (assoc 62 ed)) (if (or (null col) (= (cdr (assoc 62 ed)) 256)) ; 256 = BYLAYER (progn (setq lay (cdr (assoc 8 ed))) (if (setq layed (tblsearch "LAYER" lay)) (cdr (assoc 62 layed)) 7 ) ) (cdr col) ) ) ;; (defun c:CDIA (/ base-ent base-ed base-ltype base-color ss express gr g1 g2 p1 pick filt i e) ;; select circle (princ "\n-> select circle...") (if (null (setq base-ent (entsel))) (progn (princ "\n-> not select。") (princ)) (progn (setq base-ed (entget (car base-ent))) (if (/= (cdr (assoc 0 base-ed)) "CIRCLE") (progn (princ "\n-> not circle。") (princ)) (progn (setq base-ltype (get-real-linetype base-ed)) (setq base-color (get-real-color base-ed)) (princ (strcat "\n->linetype: " base-ltype ",color: " (itoa base-color))) ;; Express Tools "SHIFT" (setq express (and (vl-position "acetutil.arx" (arx)) (not (vl-catch-all-error-p (vl-catch-all-apply 'acet-sys-shift-down nil))) ) ) ;; (setq ss (ssadd)) ;; (setq filt (list (cons 0 "CIRCLE") (cons 6 base-ltype) (cons 62 base-color) ) ) (princ "\nSelect objects: ") ;; (while (/= 2 (car (setq gr (grread t 13 2)))) (setq g1 (car gr) g2 (cadr gr)) (_redrawss ss 3) (cond ((= g1 5) nil) ; ((= g1 3) ; ;; click (if (setq pick (ssget g2 filt)) (progn (setq pick (ssname pick 0)) (cond ((and express (acet-sys-shift-down)) ; SHIFT remove (if (ssmemb pick ss) (progn (ssdel pick ss) (redraw pick 4)) ) ) (t (if (not (ssmemb pick ss)) (ssadd pick ss) ) ) ) ) ;; (if (setq pick (_getwindowselection "\nSpecify Opposite Corner: " g2 nil nil)) (cond ((and express (acet-sys-shift-down)) ; SHIFT + remove (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (ssmemb e ss) (wcmatch (cdr (assoc 0 (entget e))) "CIRCLE")) (progn (ssdel e ss) (redraw e 4)) ) ) ) (t ; (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (= (cdr (assoc 0 (entget e))) "CIRCLE") (= (get-real-linetype (entget e)) base-ltype) (= (get-real-color (entget e)) base-color) (not (ssmemb e ss)) ) (ssadd e ss) ) ) ) ) ) ) (princ "\nSelect objects: ") ) ) ) ;; (setq g2 (cadr gr)) (cond ((wcmatch (strcase (chr g2)) "W") (if (setq p1 (getpoint "\nSpecify First Corner for Window: ")) (if (setq pick (_getwindowselection "\nSpecify Opposite Corner: " p1 nil "_W")) (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (= (cdr (assoc 0 (entget e))) "CIRCLE") (= (get-real-linetype (entget e)) base-ltype) (= (get-real-color (entget e)) base-color) (not (ssmemb e ss)) ) (ssadd e ss) ) ) ) ) ) ((wcmatch (strcase (chr g2)) "C") (if (setq p1 (getpoint "\nSpecify First Corner for Crossing: ")) (if (setq pick (_getwindowselection "\nSpecify Opposite Corner: " p1 nil "_C")) (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (= (cdr (assoc 0 (entget e))) "CIRCLE") (= (get-real-linetype (entget e)) base-ltype) (= (get-real-color (entget e)) base-color) (not (ssmemb e ss)) ) (ssadd e ss) ) ) ) ) ) ((wcmatch (strcase (chr g2)) "B") (if (setq p1 (getpoint "\nSpecify First Corner for Box: ")) (if (setq pick (_getwindowselection "\nSpecify Opposite Corner: " p1 nil nil)) (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (= (cdr (assoc 0 (entget e))) "CIRCLE") (= (get-real-linetype (entget e)) base-ltype) (= (get-real-color (entget e)) base-color) (not (ssmemb e ss)) ) (ssadd e ss) ) ) ) ) ) ) (_redrawss ss 4) ; ;; (if (> (sslength ss) 0) (progn (princ (strcat "\n->total " (itoa (sslength ss)) " circles,add textmark...")) (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (setq ed (entget ent)) (setq center (cdr (assoc 10 ed))) (setq radius (cdr (assoc 40 ed))) (entmake (list '(0 . "TEXT") (cons 8 (cdr (assoc 8 ed))) ; (cons 10 center) ; (cons 11 center) ; '(40 . 2.5) ; (cons 1 (strcat "%%C" (rtos (* radius 2) 2 2))) '(7 . "STANDARD") '(71 . 0) '(72 . 1) ; '(73 . 2) ; ) ) (setq i (1+ i)) ) (princ "\n-> Finish!") ) (princ "\n-> not circle。") ) ) ) ) ) (princ) ) ;; (princ "\n CDIA。") (princ) Quote
masao_8 Posted yesterday at 06:57 AM Author Posted yesterday at 06:57 AM 13 hours ago, masao_8 said: thanks all!! @pkenewell thanks you. this is good. but i want to use "ssget" has "quick iniget". use express tools can do it,but CAD not express tools how to use this code. (defun _redrawss (ss mode / i) (if (and ss (= (type ss) 'PICKSET) (> (sslength ss) 0)) (repeat (setq i (sslength ss)) (redraw (ssname ss (setq i (1- i))) mode) ) ) ) (defun _getwindowselection (msg p1 filter flag / gr p3 p2 p4 col winflag) (princ msg) (setq p3 nil) (while (/= 3 (car (setq gr (grread t 13 0)))) (if (= 5 (car gr)) (progn (redraw) (setq p3 (cadr gr)) (if (and p1 p3) (progn (setq p2 (list (car p3) (cadr p1) (caddr p3)) p4 (list (car p1) (cadr p3) (caddr p3)) col (if (or (eq flag "_C") (minusp (- (car p3) (car p1)))) -256 256) ) (grvecs (list col p1 p2 p1 p4 p2 p3 p3 p4)) ) ) ) ) ) (redraw) (if (and p1 p3) (progn (setq winflag (cond (flag) ((minusp (- (car p3) (car p1))) "_C") (t "_W") ) ) (if filter (ssget winflag p1 p3 (list filter)) (ssget winflag p1 p3) ) ) nil ) ) ;;BYLAYER (defun get-real-linetype (ed / lt lay layed) (setq lt (assoc 6 ed)) (if (or (null lt) (= (cdr lt) "BYLAYER")) (progn (setq lay (cdr (assoc 8 ed))) (if (setq layed (tblsearch "LAYER" lay)) (cdr (assoc 6 layed)) "CONTINUOUS" ) ) (cdr lt) ) ) ;;BYLAYER (defun get-real-color (ed / col lay layed) (setq col (assoc 62 ed)) (if (or (null col) (= (cdr (assoc 62 ed)) 256)) ; 256 = BYLAYER (progn (setq lay (cdr (assoc 8 ed))) (if (setq layed (tblsearch "LAYER" lay)) (cdr (assoc 62 layed)) 7 ) ) (cdr col) ) ) ;; (defun c:CDIA (/ base-ent base-ed base-ltype base-color ss express gr g1 g2 p1 pick filt i e) ;; select circle (princ "\n-> select circle...") (if (null (setq base-ent (entsel))) (progn (princ "\n-> not select。") (princ)) (progn (setq base-ed (entget (car base-ent))) (if (/= (cdr (assoc 0 base-ed)) "CIRCLE") (progn (princ "\n-> not circle。") (princ)) (progn (setq base-ltype (get-real-linetype base-ed)) (setq base-color (get-real-color base-ed)) (princ (strcat "\n->linetype: " base-ltype ",color: " (itoa base-color))) ;; Express Tools "SHIFT" (setq express (and (vl-position "acetutil.arx" (arx)) (not (vl-catch-all-error-p (vl-catch-all-apply 'acet-sys-shift-down nil))) ) ) ;; (setq ss (ssadd)) ;; (setq filt (list (cons 0 "CIRCLE") (cons 6 base-ltype) (cons 62 base-color) ) ) (princ "\nSelect objects: ") ;; (while (/= 2 (car (setq gr (grread t 13 2)))) (setq g1 (car gr) g2 (cadr gr)) (_redrawss ss 3) (cond ((= g1 5) nil) ; ((= g1 3) ; ;; click (if (setq pick (ssget g2 filt)) (progn (setq pick (ssname pick 0)) (cond ((and express (acet-sys-shift-down)) ; SHIFT remove (if (ssmemb pick ss) (progn (ssdel pick ss) (redraw pick 4)) ) ) (t (if (not (ssmemb pick ss)) (ssadd pick ss) ) ) ) ) ;; (if (setq pick (_getwindowselection "\nSpecify Opposite Corner: " g2 nil nil)) (cond ((and express (acet-sys-shift-down)) ; SHIFT + remove (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (ssmemb e ss) (wcmatch (cdr (assoc 0 (entget e))) "CIRCLE")) (progn (ssdel e ss) (redraw e 4)) ) ) ) (t ; (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (= (cdr (assoc 0 (entget e))) "CIRCLE") (= (get-real-linetype (entget e)) base-ltype) (= (get-real-color (entget e)) base-color) (not (ssmemb e ss)) ) (ssadd e ss) ) ) ) ) ) ) (princ "\nSelect objects: ") ) ) ) ;; (setq g2 (cadr gr)) (cond ((wcmatch (strcase (chr g2)) "W") (if (setq p1 (getpoint "\nSpecify First Corner for Window: ")) (if (setq pick (_getwindowselection "\nSpecify Opposite Corner: " p1 nil "_W")) (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (= (cdr (assoc 0 (entget e))) "CIRCLE") (= (get-real-linetype (entget e)) base-ltype) (= (get-real-color (entget e)) base-color) (not (ssmemb e ss)) ) (ssadd e ss) ) ) ) ) ) ((wcmatch (strcase (chr g2)) "C") (if (setq p1 (getpoint "\nSpecify First Corner for Crossing: ")) (if (setq pick (_getwindowselection "\nSpecify Opposite Corner: " p1 nil "_C")) (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (= (cdr (assoc 0 (entget e))) "CIRCLE") (= (get-real-linetype (entget e)) base-ltype) (= (get-real-color (entget e)) base-color) (not (ssmemb e ss)) ) (ssadd e ss) ) ) ) ) ) ((wcmatch (strcase (chr g2)) "B") (if (setq p1 (getpoint "\nSpecify First Corner for Box: ")) (if (setq pick (_getwindowselection "\nSpecify Opposite Corner: " p1 nil nil)) (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (= (cdr (assoc 0 (entget e))) "CIRCLE") (= (get-real-linetype (entget e)) base-ltype) (= (get-real-color (entget e)) base-color) (not (ssmemb e ss)) ) (ssadd e ss) ) ) ) ) ) ) (_redrawss ss 4) ; ;; (if (> (sslength ss) 0) (progn (princ (strcat "\n->total " (itoa (sslength ss)) " circles,add textmark...")) (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (setq ed (entget ent)) (setq center (cdr (assoc 10 ed))) (setq radius (cdr (assoc 40 ed))) (entmake (list '(0 . "TEXT") (cons 8 (cdr (assoc 8 ed))) ; (cons 10 center) ; (cons 11 center) ; '(40 . 2.5) ; (cons 1 (strcat "%%C" (rtos (* radius 2) 2 2))) '(7 . "STANDARD") '(71 . 0) '(72 . 1) ; '(73 . 2) ; ) ) (setq i (1+ i)) ) (princ "\n-> Finish!") ) (princ "\n-> not circle。") ) ) ) ) ) (princ) ) ;; (princ "\n CDIA。") (princ) Quote
Tsuky Posted yesterday at 03:42 PM Posted yesterday at 03:42 PM I don't know if I understood exactly what the need was, but here is my proposal. Moving the cursor over entities adds to the selection if the mode is active (left-click) and pressing + or - toggles to add or remove. (defun C:AutoSel ( / oldpcka key_mod ss tmp key_sel e_sel) (setq oldpcka (getvar "PICKADD") key_mod 'ssadd) (setvar "PICKADD" 2) (or (setq ss (ssget "_I")) (setq ss (ssget "_P")) ) (if ss (sssetfirst nil ss) (setq ss (ssadd))) (princ "\n[+/-]: AutoSelect ADD/REMOVE [Left-Click]: AutoSelect ON/OFF [Right-Click]: Quit AutoSelect ") (princ "\nAutoSelect <<OFF>>") (while (or (= 5 (car (setq tmp (grread t 5 2)))) (= 3 (car tmp)) (member tmp '((2 43) (2 45)))) (cond ((= 2 (car tmp)) (cond ((eq (cadr tmp) 43) (setq key_mod 'ssadd) (princ "\nMode add select") ) ((eq (cadr tmp) 45) (setq key_mod 'ssdel) (princ "\nMode remove select") ) ) ) ((= 3 (car tmp)) (if (null key_sel) (progn (setq key_sel T) (princ "\nAutoSelect <<ON>>") ) (progn (setq key_sel nil) (princ "\nAutoSelect <<OFF>>") ) ) ) ((= 5 (car tmp)) (cond ((and key_sel (setq e_sel (nentselp (cadr tmp)))) (cond ((eq 'ENAME (type (car (last e_sel)))) ((eval key_mod) (car (last e_sel)) ss) ) ((eq "VERTEX" (cdr (assoc 0 (entget (car e_sel))))) ((eval key_mod) (cdr (assoc 330 (entget (car e_sel)))) ss) ) (T ((eval key_mod) (car e_sel) ss)) ) (sssetfirst nil ss) ) (T nil) ) ) (T (princ "\nAbnormal command shutdown ")) ) ) (setvar "PICKADD" oldpcka) (princ "\nEnd of command. ") (prin1) ) 1 Quote
masao_8 Posted yesterday at 06:10 PM Author Posted yesterday at 06:10 PM If Express Tools isn't installed in AutoCAD, how can I load it while this code is running? I want to achieve a functionality similar to "ssget", but with shortcut key support. @Tsuky thanks you so much. 11 hours ago, masao_8 said: Quote
pkenewell Posted yesterday at 07:21 PM Posted yesterday at 07:21 PM 1 hour ago, masao_8 said: If Express Tools isn't installed in AutoCAD, how can I load it while this code is running? I want to achieve a functionality similar to "ssget", but with shortcut key support. @Tsuky thanks you so much. @masao_8 The Express tools must be installed with AutoCAD. If you mean just loading it, it's in my code above: (if acet-load-expresstools (acet-load-expresstools)) To make a grread loop work exactly like ssget. it's a huge ask. There is a ton of options to emulate. Could you explain EXACTLY what you want the function to do? What you're asking for has seemed to shift, or you weren't explaining it well enough. Below is an update to my code to add just the auto window and crossing selection: ;; Function to do a simple Select/Deselect using grread. ;; By PJK - 6/16/2026 ;; Updated 6/29/2026 to add window selection emulation (defun pjk-grread-Select (/ done en grl grc grv ss ss->elst sx wp1 wp2) (defun ss->elst (ss / i r) (if ss (repeat (setq i (sslength ss))(setq r (cons (ssname ss (setq i (1- i))) r))) ) ) (if acet-load-expresstools (acet-load-expresstools)) (setq ss (ssadd)) (princ "\nSelect to add objects or SHIFT+Select to remove from selection set: ") (while (not done) (setq grl (grread T 15 (if wp1 0 2)) grc (car grl) grv (cadr grl) ) (cond ((= grc 5) (redraw) (if wp1 (progn (grdraw wp1 (list (car grv) (cadr wp1) (caddr wp1)) -1 (if (< (car grv) (car wp1)) 1 0)) (grdraw wp1 (list (car wp1) (cadr grv) (caddr wp1)) -1 (if (< (car grv) (car wp1)) 1 0)) ) ) ) ((= grc 3) (if (acet-sys-shift-down) (if (setq en (car (nentselp grv))) (progn (if (ssmemb en ss)(ssdel en ss)) (redraw en 4) ) (if (not wp1) (progn (setq wp1 grv) (princ "\rSelect opp corner: ") ) (progn (redraw) (setq wp2 grv) (if (< (car wp2) (car wp1)) (mapcar '(lambda (a)(ssdel a ss)(redraw a 4)) (setq sx (ss->elst (ssget "C" wp1 wp2))) ) (mapcar '(lambda (a)(ssdel a ss)(redraw a 4)) (setq sx (ss->elst (ssget "W" wp1 wp2))) ) ) (princ (strcat "\n(" (itoa (length sx) ) ") Objects found and Removed from selection. " ) ) (setq wp1 nil wp2 nil) ) ) ) (if (setq en (car (nentselp grv))) (progn (ssadd en ss) (redraw en 3) ) (if (not wp1) (progn (setq wp1 grv) (princ "\rSelect opp corner: ") ) (progn (redraw) (setq wp2 grv) (if (< (car wp2) (car wp1)) (mapcar '(lambda (a)(ssadd a ss)(redraw a 3)) (setq sx (ss->elst (ssget "C" wp1 wp2))) ) (mapcar '(lambda (a)(ssadd a ss)(redraw a 3)) (setq sx (ss->elst (ssget "W" wp1 wp2))) ) ) (princ (strcat "\n(" (itoa (length sx)) ") Objects found and added to selection. " ) ) (setq wp1 nil wp2 nil) ) ) ) ) ) ((= grc 2) (setq done (if (vl-position kcode '(13 32)) T nil)) ) ((= grc 25)(setq done T)) ) ) (if (> (sslength ss) 0) (progn (foreach i (mapcar 'cadr (ssnamex ss))(redraw i 4)) ss ) nil ) ) 2 Quote
masao_8 Posted 7 hours ago Author Posted 7 hours ago @pkenewell I found an issue with the spacebar when using 'GRREAD' in CAD 2016. Like the code below, but using ARX files won't work across different versions.(CAD 2012 or 2016) ;;------------------=={ CDIA - Short English Version with TxtH }==-----------------;; (defun _redrawss (ss mode / i) (if (and ss (= (type ss) 'PICKSET) (> (sslength ss) 0)) (repeat (setq i (sslength ss)) (redraw (ssname ss (setq i (1- i))) mode) ) ) ) (defun _getwindowselection (msg p1 filter flag / gr p3 p2 p4 col winflag) (princ msg) (setq p3 nil) (while (/= 3 (car (setq gr (grread t 13 0)))) (if (= 5 (car gr)) (progn (redraw) (setq p3 (cadr gr)) (if (and p1 p3) (progn (setq p2 (list (car p3) (cadr p1) (caddr p3)) p4 (list (car p1) (cadr p3) (caddr p3)) col (if (or (eq flag "_C") (minusp (- (car p3) (car p1)))) -256 256) ) (grvecs (list col p1 p2 p1 p4 p2 p3 p3 p4)) ) ) ) ) ) (redraw) (if (and p1 p3) (progn (setq winflag (cond (flag) ((minusp (- (car p3) (car p1))) "_C") (t "_W"))) (if filter (ssget winflag p1 p3 (list filter)) (ssget winflag p1 p3)) ) nil ) ) (defun get-real-linetype (ed / lt lay layed) (setq lt (assoc 6 ed)) (if (or (null lt) (= (cdr lt) "BYLAYER")) (progn (setq lay (cdr (assoc 8 ed))) (if (setq layed (tblsearch "LAYER" lay)) (cdr (assoc 6 layed)) "CONTINUOUS") ) (cdr lt) ) ) (defun get-real-color (ed / col lay layed) (setq col (assoc 62 ed)) (if (or (null col) (= (cdr (assoc 62 ed)) 256)) (progn (setq lay (cdr (assoc 8 ed))) (if (setq layed (tblsearch "LAYER" lay)) (cdr (assoc 62 layed)) 7) ) (cdr col) ) ) (defun c:CDIA (/ old-error start-time loop_base base-ent base-ed base-ltype base-color ss express gr g1 g2 p1 pick filt i e root_path ver_name target_arx target_fas ent ed center radius loop_main pick_obj txt_h tmp _printmenu) (vl-load-com) (setq old-error *error*) (defun *error* (msg) (setvar "CMDECHO" 1) (setq *error* old-error) (princ "\n[Exit] Command ended by ESC.") (princ) ) (setvar "CMDECHO" 0) (setq txt_h 2.5) (if (not (vl-position "acetutil.arx" (arx))) (progn (if (findfile "CDIA.lsp") (setq root_path (strcat (vl-filename-directory (findfile "CDIA.lsp")) "\\")) (setq root_path (strcat (vl-filename-directory (getvar "DWGPREFIX")) "\\")) ) (if (or (null root_path) (= root_path "\\")) (setq root_path "")) (setq ver_name (strcat "R" (substr (getvar "ACADVER") 1 4))) (setq target_arx (strcat root_path "ExpressARX\\" ver_name "\\acetutil.arx")) (if (not (findfile target_arx)) (cond ((findfile (strcat root_path "ExpressARX\\R20.1\\acetutil.arx")) (setq target_arx (strcat root_path "ExpressARX\\R20.1\\acetutil.arx")) ) ((findfile (strcat root_path "ExpressARX\\R18.2\\acetutil.arx")) (setq target_arx (strcat root_path "ExpressARX\\R18.2\\acetutil.arx")) ) ) ) (setq target_fas (strcat root_path "acetutil.fas")) (if (findfile target_arx) (progn (arxload target_arx) (if (findfile target_fas) (vl-catch-all-apply 'load (list target_fas))) ) ) ) ) (setq express (and (vl-position "acetutil.arx" (arx)) (boundp 'acet-sys-shift-down) (not (null acet-sys-shift-down)))) (while t (setq start-time (getvar "DATE")) (setq loop_base t) (while loop_base (setq base-ent (entsel "\nSelect base circle (or ESC to exit)...")) (cond ((and (null base-ent) (= (getvar "ERRNO") 52)) (if (< (* 86400.0 (- (getvar "DATE") start-time)) 0.40) (progn (setvar "ERRNO" 0) (setq start-time (getvar "DATE")) ) (princ "\n[Tip] Select a circle, or press ESC to exit.") ) ) (t (setq loop_base nil)) ) ) (if (and base-ent (car base-ent)) (progn (setq base-ed (entget (car base-ent))) (if (/= (cdr (assoc 0 base-ed)) "CIRCLE") (princ "\n[Error] Object is not a circle.") (progn (setq base-ltype (get-real-linetype base-ed)) (setq base-color (get-real-color base-ed)) (setq ss (ssadd)) (setq filt (list (cons 0 "CIRCLE") (cons 6 base-ltype) (cons 62 base-color))) (defun _printmenu () (princ (strcat "\nBase -> LType: " base-ltype ", Color: " (itoa base-color) ", TxtH: " (rtos txt_h 2 2))) (princ "\n[H]:TxtH | [Space/Enter]:Done & Next Loop...") (princ "\nSelect objects: ") (princ) ) (_printmenu) (setq loop_main t) (while loop_main (setq gr (grread t 13 2) g1 (car gr) g2 (cadr gr)) (_redrawss ss 3) (cond ((= g1 5) nil) ((= g1 2) (cond ((member g2 '(13 32)) (setq loop_main nil) ) ((wcmatch (strcase (chr g2)) "H") (initget 6) (if (setq tmp (getreal (strcat "\nNew text height <" (rtos txt_h 2 2) ">: "))) (setq txt_h tmp) ) (_printmenu) ) (t nil) ) ) ((= g1 3) (if (and (setq pick_obj (nentselp g2)) (setq pick (car pick_obj)) (= (cdr (assoc 0 (entget pick))) "CIRCLE") (= (get-real-linetype (entget pick)) base-ltype) (= (get-real-color (entget pick)) base-color) ) (progn (if (and express (acet-sys-shift-down)) (if (ssmemb pick ss) (progn (ssdel pick ss) (redraw pick 4))) (if (not (ssmemb pick ss)) (ssadd pick ss)) ) ) (if (setq pick (_getwindowselection "\nSpecify Opposite Corner: " g2 nil nil)) (cond ((and express (acet-sys-shift-down)) (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (ssmemb e ss) (wcmatch (cdr (assoc 0 (entget e))) "CIRCLE")) (progn (ssdel e ss) (redraw e 4)) ) ) ) (t (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (= (cdr (assoc 0 (entget e))) "CIRCLE") (= (get-real-linetype (entget e)) base-ltype) (= (get-real-color (entget e)) base-color) (not (ssmemb e ss)) ) (ssadd e ss) ) ) ) ) ) ) (princ "\nSelect objects: ") ) ) ) (_redrawss ss 4) (if (> (sslength ss) 0) (progn (princ (strcat "\nSelected " (itoa (sslength ss)) " circles. Creating text...")) (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (setq ed (entget ent)) (setq center (cdr (assoc 10 ed))) (setq radius (cdr (assoc 40 ed))) (entmake (list '(0 . "TEXT") (cons 8 (cdr (assoc 8 ed))) (cons 10 center) (cons 11 center) (cons 40 txt_h) (cons 1 (strcat "%%C" (rtos (* radius 2) 2 2))) '(7 . "STANDARD") '(71 . 0) '(72 . 1) '(73 . 2) ) ) (setq i (1+ i)) ) (princ "\n[OK] Finished!") ) (princ "\n[Tip] No circles selected.") ) ) ) ) ) ) (setvar "CMDECHO" 1) (setq *error* old-error) (princ) ) (princ "\nCommand CDIA loaded.") (princ) Quote
pkenewell Posted 7 hours ago Posted 7 hours ago (edited) @masao_8 Before i try this code, could you please explain what is does and/or provide a sample drawing to test it on? It would save me time trying to determine what you are doing. You didn't put any comments in your code explaining it. EDIT: So I tried your code and it seems to work OK for me. It appears that it adds text for circles with the dia. and copies properties from the base circle? I kind of understand what you are going for; to be able to change option (Text height) during selection. I don't have AutoCAD 2012 or AutoCAD 2016 to test what your issue is, but I think you will have to research how express tools have changed since those versions, and if the loading is different? TIP: during your window selection, you could add the filter for CIRCLES (it's already in your "_getwindowselection" function), then you wouldn't need to pick them out while processing the selection set. Edited 7 hours ago by pkenewell Quote
