Hello,
I'm back here once again to bring up a very interesting topic:
How can AutoCAD (installed on a Windows 10 tablet with an integrated GNSS receiver) be made to display its real-time UTM position (or latitude/longitude), for example through a block?
Is this possible?
Are there any Lisp routines capable of achieving this?
Not sure, can the GNSS write / overwrite or updated a text file continuously? Reading a text file is easy with CAD, copy that to a block and the rest is all possible -  not sure the interface yet.
BigAl might know something later today.
  • Like 2
I don’t really understand how a GNSS receiver works.
It seems that most of them operate by sending data to a port.
The receiver is a u-blox device.
Would need a Reactor and connect to some type of database.
Edited by mhupp
  • Thanks 1
Like @mhupp may need to run an external program that writes current location to a file, then you can read that file and update say text. Depending on the program may run a BAT file or run the program or use powershell to run. I think can look at a file date has changed via reactor but manual much easier.
I did a Google and did start to find hints of save to a txt or csv file but that is as far as I went. It is something you need to do, yje googling.  Talk to who you bought the device from they may have something.
  • Thanks 1
I think you would need Python, .NET, or ObjectARX as Autolisp does not have an on idle event that I can see.
According to AI, you can read the input stream in a background thread, then use AutoCAD’s on idle event to update geometry in AutoCAD. I asked AI about using PyRx and it spit out a bunch of code converting $GPGGA $GNGGA to Lat/Log and stuff, I attached it.
scratch.txt
  • Thanks 1
Thanks for the replies.
It seems that, despite the passage of time, this is still a very rarely discussed topic. I have only found one very old thread dealing with this issue, but it approaches it from VBA and does not appear to reach a solution:
https://forums.autodesk.com/t5/autocad-map-3d-developer-forum/reading-gps-output-on-a-serial-port-with-vba/td-p/624634&ved=2ahUKEwif9v7MqpqVAxWuHDQIHXXNAncQFnoECCQQAQ&usg=AOvVaw2qjyYBboSx0JnXyKbmPsbU⁠�
I suppose this is not something that is easy to achieve from Lisp.
I’m not sure I fully understand the @BIGAL idea of using an external program: do you mean a program that does all the work from outside AutoCAD?
(I may not have understood correctly.)
Thanks, @Danielm103. I’ve never used Python with AutoCAD before. Perhaps this is the right time to start doing so
I really think this topic deserves a thread that finally results in the solution that nobody has managed to find so far.
Your trying to talk to an external device, something that Autocad was never really designed  to do out of the box.. Other than say a Digitiser. Yes in survey software including CIV3D there are programs that talk to survey instruments, but some one has writen say a .NET interface to do the talking part. So you need a external program Python may do it for you, Lisp is a pretty low level language when it comes to interfaces. You need functions that do that and they are probably not built into the Lisp interpreter. Bricscad has added lisp functions to its software they are not available to say Acad as improvements.
In the case of mobile phone photos I used a 3rd part program to read the details from the jpg images so could get the lat and long and insert in a dwg at correct location. Using lisp could call the other external program. look at Startapp can call a bat file.
"Need a thread" then why not talk to hand held distance measures, I am sure others would come up with other devices also that they would like plug and play.
Yeah, my thought would be to use an external app to talk to the receiver, save the coordinates to a text file somewhere continuously - probably by overwriting a simple text file 'X-Coord Y-Coord Z-Coord Description' - same format all the time - all done outside of CAD.
Have CAD running and using a delay (https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/using-delay-command-in-scripts/td-p/5497881 for an example) get CAD to read this file as necessary, plot the point
An external application?
Wich one?
Is there any software available that can do this?
In real time? I think is saw one for like $300 will post later tonight.
-edit
I can't find it was like dtool or something
Edited by mhupp
  • Agree 1
Some suggestions. Go back to who you bought the device from, they may have something. If it was say Amazon not sure. Look on the manufacturers web site for more info contact them.
Brand, model etc ?
  • Agree 1
As I mentioned, it is an integrated u-blox M8N receiver built into the motherboard of a Unistrong UT50 tablet PC running Windows 10.
It is a tablet that is about 10 years old, so it has already been discontinued.
Are you able to dive into Windows itself a little - been a while since I needed to do anything similar though so this might not be possible. Close everything and set the receiver going, record some data, say 5 mins or something. Windows of old let you search the whole system for every file... might be able to limit that to 'modified in last hour' (or whatever). This might bring up the saved data, might be able to open in notepad and see if it is encrypted / compressed (all the weird characters) or raw data. If is is raw data then you are away and running able to read and modify as you want.
Think you would need to show hidden and system files to get the best chance of finding the data. Might work.
Like @Steven P How do you look at the data now ?
Is it just displayed when you run a program ? If so what is the program ? Some one must have written it.
Edited by BIGAL
  • Agree 1
Applications that use location services include Windows Maps and Google Earth, for example.
There are probably more specialized applications, but I suppose those two are the best known and the best documented.
Hello.
You might have to code a listener on COM or TCP/IP to read nmea stream (depending how you cast your GNSS stream).
It is possible with .net to code a plugin that read a com port or TCP/IP stream and then follow the GNSS position in many ways.
Inserting Block to the last position
Drawing any entities following the GNSS position.
Soeren Le Berre
Perhaps it's easier than it seems.
If it is an integrated receiver and Windows is able to obtain location data from it, then you should be able to access that data through the 'Windows Location API'.
In that case, it should be possible to write a script to be executed from PowerShell that creates a loop to poll the receiver and write the data to a file. That loop would run in parallel with AutoCAD, allowing Lisp to read the new data as it is written.
This method would be "intrusive", since it would occupy AutoCAD's command stream for as long as the command is running.
However, there is another, less intrusive option that could operate in the "background": write the data to a system variable ('USERS#') and create a reactor that responds to changes in that variable: 'vlr-sysvar-reactor'.
If the script is executed in a background PowerShell instance, you would also need to write a Lisp command capable of closing that instance when necessary.
Once the script has been debugged, it could be incorporated into the Lisp code itself, making the whole solution completely self-contained.
I haven't had much free time lately, but I'll try to investigate all of this a bit further.
I wouldn't be too concerned about taking up AutoCAD processing, if you are out surveying then you probably aren't drawing?
I'd do the LISP on demand though, say 'c:GNSS' whenever you want to plot the point, if you are wanting to use CAD while surveying - that way you are grabbing the point at the location you are at. LISP would probably work best by: Copy data file to say temp folder, read copied file, close copied file to avoid conflicts... so long as the receiver saves the data regularly and not just on closing the application. Might be the better option - can add in a DCL pop up to add data about the point recorded (what it is, and so on)
