AI suggestion not working - saved it to my menu
^C^C$M=$(if,$(==,$(getenv,ShowTabs),"0"),_setenv ShowTabs 1,_setenv ShowTabs 0)
my acad replies:
Command: setenv Unknown command "SETENV".  Press F1 for help.
Command: ShowTabs Unknown command "SHOWTABS".  Press F1 for help.
Command: 0 Unknown command "0".  Press F1 for help.
Really the concern is if system set/getenv can be used in a macro, and using it for visibility as with:
ID_BouReg      [$(if,$(and,$(getvar,hpbound),1),!.)Polyline BOundary    ]$M=$(if,$(and,$(getvar,hpbound),1), setvar hpbound 0, setvar hpbound 1) regenall
which is the switch (the $if..,!.) for poly/region of boundary which shows with a 'check when set to polyline.
'Showtabs" does not exist in my AutoCAD 2027. Are these the variables you're after?
FILETAB: Type this into the command line to instantly display the file tabs.
FILETABCLOSE: Type this into the command line to hide the file tabs.
FILETABSTATE: The system variable used to check or set their status (1 for on, 0 for off)
What exactly are you trying to do?
Are you using AutoCAD 2000? I only have Tilemode and CTAB in my AutoCAD 2000i at home for dealing with the Tabs.
Why Diesel?
You posted this in the LISP forum.
  • 2 months later...
1) Unlike setvar, setenv is not a command but a lisp function that's the reason AutoCAD is returning:
So you would have to begin it with open parenthesis and end it with close parenthesis.
An example would be:
(setenv"MaxArray""200000")
2) There's no SHOWTABS environment variable unless this is set elsewhere.
3) For a list of AutoCAD environment variables open Windows Registry: Regedit and browse to:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\<Version>\<ProductID>\FixedProfile\General
