Shri95 Posted July 22 Posted July 22 Hello everyone - I have attached block which I use as girt on project, I want to add text with length (Dynamic) and count if I do array of that block, would it be possible to use that text (length) and count to make the table with count and length Girt.dwg Quote
SLW210 Posted July 23 Posted July 23 I have moved your thread to the AutoCAD Drawing Management & Output Forum. I didn't see any text in your posted .dwg, can you post a before and after example of what you need? Quote
Shri95 Posted July 23 Author Posted July 23 Here is what I want, if not possible with table, I really want length and count for the girts Girt.dwg Quote
BIGAL Posted July 24 Posted July 24 Yes need a much better realistic sample dwg with say a couple of different scenarios, array,non array and so on, even different lengths. There is a way of getting array info, you read the 1st object for properties, then the numbers in the row and column values. 1 Quote
ketxu Posted July 31 Posted July 31 You have to make two Field, once for Distance of Block, then Once for Arrray Object (item or column * row). Cause an Array Object now is include all block, all Field of length in per Array is fixed 1 Quote
