Shri95 Posted Wednesday at 08:32 PM Posted Wednesday at 08:32 PM Hello everyone - I have attached block which I use as girt on project, I want to add text with length (Dynamic) and count if I do array of that block, would it be possible to use that text (length) and count to make the table with count and length Girt.dwg Quote
SLW210 Posted yesterday at 10:27 AM Posted yesterday at 10:27 AM I have moved your thread to the AutoCAD Drawing Management & Output Forum. I didn't see any text in your posted .dwg, can you post a before and after example of what you need? Quote
Shri95 Posted 18 hours ago Author Posted 18 hours ago Here is what I want, if not possible with table, I really want length and count for the girts Girt.dwg Quote
BIGAL Posted 11 hours ago Posted 11 hours ago Yes need a much better realistic sample dwg with say a couple of different scenarios, array,non array and so on, even different lengths. There is a way of getting array info, you read the 1st object for properties, then the numbers in the row and column values. Quote
