Danielm103 Posted July 29 Posted July 29 (edited) I posted this at the swamp, this is pretty cool Proof of concept (V25, V26, V27Beta) - appload BrxBlockManXX.brx - type blockman at the prompt - select a drawing from the directory control - double click or drag a block from the List control to the current drawing - double click the main preview to insert the whole drawing - click the open folder button to add your favorite folder(s) - use the dropdown to navigate to a favorite folder - right click on a dwg to open it let me know if it crashes lol edit, posted the source and binaries here https://github.com/CEXT-Dan/BrxBlockMan Edited July 30 by Danielm103 1 Quote
BIGAL Posted July 29 Posted July 29 (edited) downloaded zip copied v25.brx and src to a known support path Appload D:\Alan\LISP\BrxBlockMan25.brx successfully loaded. Type blockman and nothing happens ? Any ideas, running twin screens ?? Edited July 29 by BIGAL Quote
Danielm103 Posted July 29 Author Posted July 29 (edited) You should see a version number on the command line. It’s a panel, it should sit next to the properties panel, right click on Bricscads task bar and look for the new panel Edited July 29 by Danielm103 Quote
Danielm103 Posted July 29 Author Posted July 29 Also, make sure the xrc file is in the same folder, if you moved the BRX Quote
BIGAL Posted July 30 Posted July 30 (edited) My Bricscad after appload, yes brx and xrc are in a support path. I moved that path to top of support path list. Then appload. Version V25.2.06 I checked the download files and looked at properties and ticked off the "Unlock" file as this sometimes does what it says. I have tried unloading and that fails not sure why. Sent you a pm with my email. Edited July 30 by BIGAL Quote
BIGAL Posted August 2 Posted August 2 @Danielm103 has updated the code and its running under Bricscad and is very impressive, I am sure the updated code will be posted here soon. 1 Quote
Danielm103 Posted August 3 Author Posted August 3 Wonderful! Thanks for testing and for your valuable feedback! I'll add the carriage return after Insertion Point: I’m also considering making the rotation and scale options on screen, I’m still on the fence about that Quote
