Danielm103 Posted Wednesday at 12:25 AM Posted Wednesday at 12:25 AM (edited) I posted this at the swamp, this is pretty cool Proof of concept (V25, V26, V27Beta) - appload BrxBlockManXX.brx - type blockman at the prompt - select a drawing from the directory control - double click or drag a block from the List control to the current drawing - double click the main preview to insert the whole drawing - click the open folder button to add your favorite folder(s) - use the dropdown to navigate to a favorite folder - right click on a dwg to open it let me know if it crashes lol edit, posted the source and binaries here https://github.com/CEXT-Dan/BrxBlockMan Edited Thursday at 04:46 AM by Danielm103 1 Quote
BIGAL Posted Wednesday at 12:56 AM Posted Wednesday at 12:56 AM (edited) downloaded zip copied v25.brx and src to a known support path Appload D:\Alan\LISP\BrxBlockMan25.brx successfully loaded. Type blockman and nothing happens ? Any ideas, running twin screens ?? Edited Wednesday at 12:58 AM by BIGAL Quote
Danielm103 Posted Wednesday at 01:20 AM Author Posted Wednesday at 01:20 AM (edited) You should see a version number on the command line. It’s a panel, it should sit next to the properties panel, right click on Bricscads task bar and look for the new panel Edited Wednesday at 05:49 AM by Danielm103 Quote
Danielm103 Posted Wednesday at 01:24 AM Author Posted Wednesday at 01:24 AM Also, make sure the xrc file is in the same folder, if you moved the BRX Quote
BIGAL Posted Thursday at 12:23 AM Posted Thursday at 12:23 AM (edited) My Bricscad after appload, yes brx and xrc are in a support path. I moved that path to top of support path list. Then appload. Version V25.2.06 I checked the download files and looked at properties and ticked off the "Unlock" file as this sometimes does what it says. I have tried unloading and that fails not sure why. Sent you a pm with my email. Edited Thursday at 12:39 AM by BIGAL Quote
BIGAL Posted 4 hours ago Posted 4 hours ago @Danielm103 has updated the code and its running under Bricscad and is very impressive, I am sure the updated code will be posted here soon. 1 Quote
Danielm103 Posted 3 hours ago Author Posted 3 hours ago Wonderful! Thanks for testing and for your valuable feedback! I'll add the carriage return after Insertion Point: I’m also considering making the rotation and scale options on screen, I’m still on the fence about that Quote
