Hi...... Im trying (using AI too) to make a program to remove wipeouts from selected (or all ) blocks picked from screen....  some are nested blocks, some dynamic blocks exploded...
The code does not come out correctly, either it blanket delets all wipeouts in the drawing, or ramdom wipeouts, or.... it doesnt work at all. Im not smart enough to review the VLisp code to identify or fix it...
RemWipeout.lsp
Did you check if anything in this thread helps?
Delete all Wipeouts within a Drawing including Blocks - Page 2 - AutoLISP, Visual LISP & DCL - AutoCAD Forums
Are they actually Wipeouts or could some be text masks, dimension background masks, Hatches, etc.?
Could you post an example drawing of exactly what objects you need removed?
When I get time, I'll try a shot at what you have already, but an example drawing would help a lot as I don't use Wipeouts a whole lot.
