As @VicoWang mentioned I've been running some major tests implementing this new VedaCAD system of deploying 3rd party add-ons in my case specifically to AutoCAD users.
@VicoWang has been really responsive with all my feedback. I'm fairly impressed with how this provides a software developer like myself another platform to push out my apps to end users to implement on their AutoCAD system.
Along with AutoCAD users, I'm hoping AutoCAD LT 2024 and higher version users will also try installing and running these apps.
Since currently the Autodesk App Store (now known as the Design & Make Marketplace) do not support AutoCAD LT, this VCID deployment method provides an excellent solution to have AutoLISP coded apps load & run on LT.
The following is a list of my VCIDs:
[DDCalc] VCID: B-NN9XC
DDCalc is an on screen graphical calculator within Autodesk® AutoCAD® that supports feet, inch & fractional numeric entries.
[DDList] VCID: B-NLR04
DDList is Autodesk® AutoCAD® basic list command but on steroids.
[DwgSetup] VCID: B-4K6UL
DwgSetup App offers two user friendly graphic user interface commands to make drawing setup changes: (1) DDSetup and (2) DDDwgunits
[VpScale App] VCID: B-31VQK
VpScale Apps offers two very useful Viewport Scaling Applications: DDZmVpSc & DDSetVpSc
[VTN] VCID: B-0Z8Q6
Virtual Tablet Navigator (VTN) is an add-on AutoLISP application using DCL to bring Autodesk® AutoCAD® physical Tablet Menu commands virtually onto the graphics screen.
[XOM] VCID: B-09NQD
Xref Object Manager (XOM) is an AutoLISP application using a dynamic dialog box to present built-in & added operations to manage External Reference Objects displayed both in a Tree and a List view.
Edited by Paul Li
@VicoWang has been really response with all my feedback. I'm fairly impressed with how this provides a software developer like myself another platform to push out my apps to end users to implement on their AutoCAD system.
The following is a list of my VCIDs.
[VTN] VCID: B-0Z8Q6
[XOM] VCID: B-09NQD
After installing the above bundle, everything works as expected. (To install these bundle, a free vedacad account is sufficient.)
After nearly 40 emails of intense communication with @Paul Li, I saw the professionalism and rigor of the senior developer, and this real feedback after actual use has taken VedaCAD a big step forward.
Thank you @Paul Li
Just a reminder: the early-bird discount for PRO ends on October 31st. What capabilities will be unlocked by upgrading to PRO? (FREE is already sufficient for most users; PRO is designed for those with more advanced needs.)
1. Update the asset version of a published VCID without changing the VCID itself.
2. Configurable donation links, such as PayPal.
3. Both ARX and DLL, two advanced plugin formats, are supported, and the maximum file size has been increased from 3MB to 15 MB.
4. PRO is the minimum requirement for mounting and joining the VedaCAD-based General contracting and subcontracting network ark visa.
Early bird event details: https://www.vedacad.com/journal?post=the-pioneer-challenge
Edited by VicoWang
