VicoWang Posted August 28 Posted August 28 It is widely known that DCL has its native limitations, and to create beautiful and elegant UIs, it's not only about simplifying the underlying logic but also about DCL's presentation. Please share those DCL interface designs that are worth sharing! Here are the DCL interface designs for my two plugins. In the end, it was the image control that took on everything!!! Quote
Paul Li Posted Thursday at 10:26 PM Posted Thursday at 10:26 PM Not sure if this is considered elegant but sure takes advantage of the number of image tiles that can be spread onto a giant custom dialog to preview slide files. This is a screen capture of SMV (SMVslide) which is one of the commands included in my free Script Magician App: 2 Quote
BIGAL Posted Saturday at 04:27 AM Posted Saturday at 04:27 AM (edited) If you go old fashioned this is built into a pop menu. If you can use Notepad then you can make one. Note the Next and Previous inbuilt options. But I also have 2x2, 3x3, 4x4 and so on dcl's they are used when relevant to limited choices in code via an image pick. Edited Saturday at 04:28 AM by BIGAL 4 Quote
CivilTechSource Posted 56 minutes ago Posted 56 minutes ago @BIGAL this is beautiful, probably this is where AutoDesk got inspiration for the Block Library Pallette. Do you mind sharing the DCL code? Quote
