Hi all,
I kept running into drawings that had ballooned to tens of MB, slow to open and painful to share. So I put together a small routine, DWGCLEAN, that runs the full cleanup in one command. Sharing it here in case it saves someone else the hassle.
What it does, in order:
  • Purges orphaned RegApp records (the hidden junk third-party and exported objects leave behind)
  • Runs a full PURGE several times, to catch nested items that only become purgeable after their parent is gone
  • Runs AUDIT with fix, to repair database errors
  • WBLOCKs the whole drawing into a fresh file, which is the step that actually rebuilds and shrinks it
It writes a new file with a _clean suffix and never touches your original. It also prints the before/after size and the percent saved when it finishes.
Here is the code:
(vl-load-com)
;; ---- helper: bytes -> whole-KB string ------------------------------------
(defun ea:kb (bytes) (itoa (fix (/ (float bytes) 1024.0))))
(defun c:DWGCLEAN ( / *error* old-cmdecho old-filedia old-expert
                      src-dir src-name src-path base target n pass
                      size-before size-after saved pct )
  ;; ---- error handler: always restore system variables --------------------
  (defun *error* (msg)
    (if old-cmdecho (setvar "CMDECHO" old-cmdecho))
    (if old-filedia (setvar "FILEDIA" old-filedia))
    (if old-expert  (setvar "EXPERT"  old-expert))
    (if (and msg (not (member msg '("Function cancelled" "quit / exit abort"))))
      (princ (strcat "\nDWGCLEAN error: " msg)))
  ;; ---- make sure the drawing is saved to disk ----------------------------
  (setq src-dir  (getvar "DWGPREFIX")
        src-name (getvar "DWGNAME"))
  (setq src-path (strcat src-dir src-name))
  (if (or (= src-dir "")
          (not (wcmatch (strcase src-name) "*.DWG"))
          (not (findfile src-path)))
      (princ "\n*** Save the drawing to a folder first, then run DWGCLEAN again. ***")
      (exit))
  (setq size-before (vl-file-size src-path))
  ;; ---- save current sysvars, then set a clean automation state -----------
  (setq old-cmdecho (getvar "CMDECHO")
        old-filedia (getvar "FILEDIA")
        old-expert  (getvar "EXPERT"))
  (setvar "CMDECHO" 0)
  (setvar "FILEDIA" 0)
  (setvar "EXPERT"  5)   ; suppress overwrite / confirmation prompts
  (princ "\n================ Engineer Atlas :: DWGCLEAN ================")
  ;; ---- STEP 1: remove RegApps -------------------------------------------
  (princ "\n[1/4] Removing RegApps ...")
  (command "_.-PURGE" "_Regapps" "*" "_No")
  ;; ---- STEP 2: purge all unused, several passes for nested items --------
  (princ "\n[2/4] Purging unused layers, blocks, linetypes, styles ...")
  (setq pass 0)
  (while (< pass 4)
    (command "_.-PURGE" "_All" "*" "_No")
    (setq pass (1+ pass)))
  ;; ---- STEP 3: audit and fix --------------------------------------------
  (princ "\n[3/4] Auditing and fixing database errors ...")
  (command "_.AUDIT" "_Yes")
  ;; ---- STEP 4: WBLOCK the entire drawing into a fresh file ---------------
  (setq base   (vl-filename-base src-path))
  (setq target (strcat src-dir base "_clean.dwg"))
  (setq n 1)
  (while (findfile target)                    ; never overwrite an existing file
    (setq target (strcat src-dir base "_clean_" (itoa n) ".dwg"))
    (setq n (1+ n)))
  (princ (strcat "\n[4/4] Writing clean file: " (vl-filename-base target) ".dwg ..."))
  (command "_.-WBLOCK" target "*")
  ;; ---- restore sysvars ---------------------------------------------------
  ;; ---- report before / after --------------------------------------------
  (setq size-after (if (findfile target) (vl-file-size target) nil))
  (princ "\n-----------------------------------------------------------")
  (if (and size-before size-after (> size-before 0))
      (setq saved (- size-before size-after))
      (setq pct   (fix (* 100.0 (/ (float saved) size-before))))
      (princ (strcat "\nOriginal : " (ea:kb size-before) " KB"))
      (princ (strcat "\nCleaned  : " (ea:kb size-after)  " KB"))
      (princ (strcat "\nSaved    : " (ea:kb saved) " KB  (" (itoa pct) "%)")))
    (princ "\nClean file written."))
  (princ (strcat "\nNew file : " target))
  (princ "\nOpen the *_clean.dwg and verify it before replacing your original.")
(princ "\nDWGCLEAN loaded.  Type  DWGCLEAN  to reduce your DWG file size.  (Engineer Atlas)")
Load it with APPLOAD (or drag it into the drawing), then type DWGCLEAN. I have also attached the file if you would rather load the file directly, since forum copy-paste sometimes mangles the formatting.
If you would rather do it by hand without the LISP, here is the same workflow manually:
  1. Type -PURGE, choose Regapps, enter * for all, No to "verify each"
  2. Type -PURGE, choose All, * , No. Run this 3 or 4 times so nested blocks and styles clear out
  3. Type AUDIT, answer Yes to fix any errors
  4. Type WBLOCK, select the entire drawing, and save it to a new file name. Open that new file and check it
One safety note: always work on a copy of anything important, and open the _clean file to verify it before you replace the original. The routine is deliberately non-destructive (no OVERKILL, no xref detach, no exploding of objects), so it will not alter your geometry.
Hope it is useful. Feedback welcome if anyone spots an edge case.
DWGCLEAN.lsp
Welcome
You can try distributing plugins using the VedaCAD method, which supports LSP, FAS, VLX, ARX, and DLL format plugins. There's no need to configure paths or copy code anymore; on the user side, a 6-digit VCID = a certain plugin function, and it is directly available.
Those methods only address a small portion of what can cause file bloat, it's a good start, but sometimes more needs to be done to truly clean up a drawing.
In the other thread you posted in, there are other methods to clean drawings mentioned.
As always, thanks for posting your version, I am sure many will find it useful.
You could also add these 2, purgezerolangth and purgezerotxt, they will remove some entities but not generally make a massive change to size.
(defun PurgeZeroLengths ( / MySS Fuzz acount DelSS MyEnt EndA EndB) ;; for within blocks
  (setq MySS (ssget (list (cons 0 "LINE,SPLINE,LWPOLYLINE,POLYLINE,ARC,CIRCLE,ELLIPSE"))))
  (setq Fuzz 0.0001) ; Fuzz factor to delete very short entities
  (setq acount 0)
  (setq DelSS (ssadd))
  (while (< acount (sslength MySS))
    (setq MyEnt (ssname MySS acount))
    (if (equal (vlax-curve-getDistAtParam MyEnt (vlax-curve-getEndParam MyEnt)) 0)
        (setq DelSS (ssadd MyEnt DelSS))
    ) ; end if
;;If less then a length
    (if (< (vlax-curve-getDistAtParam MyEnt (vlax-curve-getEndParam MyEnt)) Fuzz)
    ) ; end if
    (setq acount (+ acount 1))
  ) ; end while
  (princ "\nDeleting ")(princ (sslength DelSS))(princ " lines")
  (command "erase" DelSS "")
(defun c:PurgeZeroTexts ( / MySS acount DelSS MyEnt MyText)
  (setq MySS (ssget (list (cons 0 "*TEXT")(cons 1 ""))))
  (setq acount 0)
  (if MySS
        (setq MyText (cdr (assoc 1 (entget MyEnt))))
        (if (equal MyText "")
        ) ; end if
      ) ; end while
    ) ; end progn
      (princ "No zero content texts found")
  ) ; end if
  • Like 2
Just a comment if a dwg has been made by CIV3D the purge command will not remove objects even un used, you need to run PURGESTYLESANDSETTINGS it can make a big difference. After run normal Purge. Also in CIV3D surfaces are inside a dwg. But you may need CIV3D to run purges&s or remove surfaces.
Similar for other CAD 3rd party add ons can have lots of proxy objects, you can use "ZOMBIE KILLER" to remove proxy objects, say in Bricscad the opening screen will show a message dwg has proxy objects.
In ARX you would use these for general cleanup
AcDbDatabase::eraseEmptyObjects(kAllEmptyObj)
AcDbDatabase::purge (AcDbObjectIdArray&) # may require multiple passes
AcDbDatabase::purge (AcDbObjectIdGraph&) # single pass
I made a python sample here.
https://www.theswamp.org/index.php?topic=60192
For something like overkill, AcGeCurveCurveInt3d is the go-to class. As it gives overlap information
Here’s another python sample for finding overlapping polylines
https://www.theswamp.org/index.php?topic=59828
Proxies, you can erase, or call swapid on a non-owned object. AutoCAD won’t save orphaned objects
Of course with these types of methods, you must let the end user confirm the operation, as BigAl mentions, they can be destructive
  • Like 2
