LIU Posted October 2 Posted October 2 (edited) hi to all , i created a 100 ft wide rectangle, and applied zoom extents, saved and closed drawing. when i reopened drawing , green line was not collinear to y-axis. zoom previous did not worked. any solution to that ? Edited October 2 by LIU Quote
SLW210 Posted October 2 Posted October 2 What's the "green line"? Hard to tell anything from an image. Please explain better or post the .dwg. Quote
Paul Li Posted October 2 Posted October 2 See if it makes a difference if you completely docked the command prompt instead of having it floating at the bottom Quote
LIU Posted October 2 Author Posted October 2 green line is line of y-axis of ucs , it is not a separate object. i have to bring this view in a form as that of new drawing, where green line ( of ucs ) is normal, Quote
LIU Posted October 2 Author Posted October 2 that is green line , after zoom Extents application , this shows away from ucs ( y-axis ). what to do to solve it ? Quote
Paul Li Posted October 2 Posted October 2 Looks like your 1st dwg might not be in plan and 2d wire view. Try this sequence of command: _.VSCURRENT 2 _.Plan _W Quote
BIGAL Posted October 3 Posted October 3 Maybe this UCSORG set origin point to say a object point. UCSICON ON will display corner icon for current UCS. Quote
CyberAngel Posted October 5 Posted October 5 If that green line is the Y axis, it's not part of your drawing, it's part of the environment. Where and how it appears will depend on the local settings. That's probably why it looks different when you reopen the drawing. If you need that axis as part of your drawing, consider drawing a line there. At least then it will become part of the extents. Quote
