LIU Posted 1 hour ago Posted 1 hour ago (edited) hi to all , i created a 100 ft wide rectangle, and applied zoom extents, saved and closed drawing. when i reopened drawing , green line was not collinear to y-axis. zoom previous did not worked. any solution to that ? Edited 1 hour ago by LIU Quote
SLW210 Posted 56 minutes ago Posted 56 minutes ago What's the "green line"? Hard to tell anything from an image. Please explain better or post the .dwg. Quote
Paul Li Posted 40 minutes ago Posted 40 minutes ago See if it makes a difference if you completely docked the command prompt instead of having it floating at the bottom Quote
