LIU Posted 1 hour ago Posted 1 hour ago (edited) hi to all , i created a 100 ft wide rectangle, and applied zoom extents, saved and closed drawing. when i reopened drawing , green line was not collinear to y-axis. zoom previous did not worked. any solution to that ? Edited 1 hour ago by LIU Quote
SLW210 Posted 1 hour ago Posted 1 hour ago What's the "green line"? Hard to tell anything from an image. Please explain better or post the .dwg. Quote
Paul Li Posted 1 hour ago Posted 1 hour ago See if it makes a difference if you completely docked the command prompt instead of having it floating at the bottom Quote
