hi to all ,
i created a 100 ft wide rectangle,
and applied zoom extents,
saved and closed drawing.
when i reopened drawing ,
green line was not collinear to y-axis.
zoom previous did not worked.
any solution to that ?
Edited by LIU
What's the "green line"?
Hard to tell anything from an image.
Please explain better or post the .dwg.
See if it makes a difference if you completely docked the command prompt instead of having it floating at the bottom
green line is line of y-axis of ucs ,
it is not a separate object.
i have to bring this view in a form as that of new drawing, where green line ( of ucs )
is normal,
that is green line ,
after zoom Extents application , this shows away from ucs  ( y-axis ).
what to do to solve it ?
Looks like your 1st dwg might not be in plan and 2d wire view.
Try this sequence of command:
_.VSCURRENT
2
_.Plan
_W
Maybe this UCSORG set origin point to say a object point. UCSICON ON will display corner icon for current UCS.
