Attached is code SlbShow.lsp that ChatGpt help me generate which would run on AutoCAD on Windows OS.
It'll first open a file window to select an existing slide library file like acad.slb
Then run a vbscript to extract the names of the slides inside the selected slide library and place this into a text file.
Next, the slides inside the selected slide library will be displayed in a custom dcl made up of a row of 4 x 5 column image buttons.
Finally, when an Image button is clicked another window appears showing the slide in a larger image button view.
I would like to know when vbscript or wscript is restricted does the code handle this and exit properly.
Any other feedback is welcome.
image.png.af28da94549348cbfa933e2ae8b3ee57.pngimage.thumb.png.f193bdffc29ccdc01fa7272803f4c5af.png
SlbShow.lsp
