Hi again.
There's something I can't seem to find a clear answer to.
Maybe someone here can give me that answer.
I'm experimenting with the use of dynamic variables, created in real-time.
However, there's something that often makes me doubt whether it's advisable to use them.
And that's where my question lies:
If my code creates thousands of variables to avoid having to store data in a structure (lists or arrays)... when at the end of the code I cancel each of those variables with (set 'v nil), do the names of those variables really disappear from AutoCAD's symbol table, or only their content?
I know about the atoms-family function and that it returns the value of a symbol if it exists.
But the AI says that a negative response from atoms-family is not a guarantee that the symbol no longer exists in AutoCAD's internal symbol table.
Thanks in advance.
Edited by PGia
A couple of points to make:
  • The need to create thousands of variables on-the-fly typically points to poor program design; in almost every case, a list is more suitable.
  • Setting all such variables to nil at the end of the program does clear them from the document namespace, but consider that you are essentially creating & clearing global variables that are not local to the scope of your program, and as such, the variable names could potentially clash with identically named variables in the document namespace - this is generally considered bad practice.
Edited by Lee Mac
  • Like 5
  • Thanks 1
  • SLW210 changed the title to Dynamic variables
Thanks for your answer, @Lee Mac.
I've tried creating a list with the coordinates of almost 20,000 objects and managing it on the fly with assoc and subst.
However, the processing speed is quite slow.
For this reason, it occurred to me to try dynamic variables.
You're probably right.
But in your answer, you seem to concede a small possibility that using them might actually be worthwhile.
What do you mean by that?
@PGia
While it's very possible to create variables on the fly. I agree with Lee that it should not be a method to use, especially in the way you are wanting to use it.
That being said, I wrote the following many years ago, but hardly have ever used it for anything. It accepts an assoc. list of strings representing variables and the corresponding values, then creates a variable for each with the value.
The core of it is very simple (set (read "StrVar") value)
  Function Name: (pjk-dynsetvar)
  Arguments:
             assoclst = List of cons; an assoc list on the format:
                        (list (cons "<var name1>" <value1>) ... (cons "<Var namN>" <valueN>))
  Usage: (pjk-dynsetvar <Assoc. List>)
         Ex: (pjk-dynsetvar (list (cons "Cenpt" (list 1.0 1.0 0.0)) (cons "Radius" 0.25)))
  Returns:
     The results of the read list. You can verify the variables with the ! prefix:
     Command line Example:
     Command: (pjk-dynsetvar (list (cons "Cenpt" (list 1.0 1.0 0.0)) (cons "Radius" 0.25)))
     ((1.0 1.0 0.0) 0.25)
     Command: !Cenpt
     (1.0 1.0 0.0)
     Command: !Radius
     0.25
   Description:
      This function dynamically sets AutoLISP variables based on an association list of strings
      and values. The string keys represent the names of the variables that the values
      will be assigned to.
(defun pjk-DynSetVar (assoclst)
   (mapcar (function (lambda (x)(set (read (car x)) (cdr x)))) assoclst)
) ;; End Function (pjk-dynsetvar)
  • Thanks 1
I Agree with Lee I'm interested in what your actually doing. take this for example. different approaches lisps that have a large range of run times. all basically doing the same thing.
mine still took over a min to run, but ronjonp came in with 4.07 sec.
  • theirs built an main list
  • processed that list into smaller lists.
  • once processed removed the items from each lists. (speeds up search)
4 hours ago, pkenewell said:
@PGia
  Arguments:
  Returns:
     Command: !Cenpt
     (1.0 1.0 0.0)
     Command: !Radius
     0.25
   Description:
Thank you very much, @pkenewell
I will try to make use of your code in my experiments.
However, I'm not sure whether I should consider my question answered: can AutoCAD's internal symbol table really be controlled from atoms-family?
Or is it possible that any symbol created during an AutoCAD session survives for as long as the session lasts, even if its value is nil?
I apologize if my question seems awkward or absurd, but I would really like someone to give me a clear answer about this.
@mhupp: in principle, my goal is to make a comparison between processing speed when the information to be looked up is stored in a very large list versus when it is stored in variables.
I suppose that, as Lee or Pkenewell say, it is risky.
But I think that if atoms-family allows complete control of AutoCAD's symbol table, it is worth trying to test this coding method.
There may be ways to speed up using a list of 20,000 points, the first is if your points are  numbered then make the list that way you have to but pt number 0 as 1st item then a (nth x lst) is a simple task and does not need the (- x 1). Re find a point depending how the list is made there is a way of quickly finding the point based on a sorted list a 10,000 list takes 13 tries to find the correct answer, it uses a 1/2 algorithm, look at 5000 item is it before or after look at say 2500 is it before or after so very fast.
Can you explain what it is your doing and maybe some people here can provide faster code. I know something I did took 34 minutes 1st go, it now takes 2 minutes including user input.
  • Like 2
I get that  @PGia but it almost be harder to recall the correct random variable. associated list might not be what you need with the large data set your working with. as assoc looks at all 20000 records every time.
look into Dictionary before going the other route. alot faster searching because you can only have unique keys tho that might be a deal breaker for you.
  • Like 2
AutoCAD session, you need to use vl-bb-set vl-bb-ref right?
  • Like 2
@Danielm103
Interesting.
I didn't know about those functions or that a parallel namespace existed.
I'll look into that. Maybe it will minimize the drawbacks of using dynamic variables.
@BIGAL Suppose we're dealing with elements that are scattered over a large area and you need to sort only a part of them and get a list. It might seem that the vl-sort function could be useful for this; however, it has a drawback: sometimes it deletes repeated elements from the list based on the filters.
So I'm trying to do it without using vl-sort.
Note: There are some objects that match exactly in location with others.
@mhupp: Dictionary? What dictionary?
@PGia there are other ways to sort lists other than inbuilt Vl-sort. You can use a Lisp version of Bubble sort and other sort algorithms.
I sort up to 5 items deep in a list and as far as I can tell none are lost. Yes have seen that with some lists using VL-sort.
So you can sort on say X & Y.
; sorts on 1st two items
(vl-sort lst
	 '(lambda (a b)
	    (cond
	      ((< (car a) (car b)))
	      ((= (car a) (car b))
	      (< (cadr a) (cadr b)))
  • Like 2
It mentions this in the help file that "Duplicate elements may be eliminated from the list."
This was created by Copilot, limited testing. and only sorts on single item.
(defun BubblePass (lst / a b)
  (cond
    ((or (null lst) (null (cdr lst))) lst)
    ((> (car lst) (cadr lst))
     (cons (cadr lst)
           (BubblePass
             (cons (car lst) (cddr lst)))))
    (t
     (cons (car lst)
           (BubblePass (cdr lst))))
(defun BubbleSort (lst / i)
  (repeat (length lst)
    (setq lst (BubblePass lst))
  lst
Asked about sort on 1st 2 items in list
(defun QSORT2 (lst / pivot)
  (defun _less (a b)
    (or (< (car a) (car b))
        (and (= (car a) (car b))
             (< (cadr a) (cadr b)))))
  (if (cdr lst)
      (setq pivot (car lst))
      (append
        (QSORT2
          (vl-remove-if-not
            '(lambda (x) (_less x pivot))
            (cdr lst)))
        (list pivot)
        (QSORT2
          (vl-remove-if-not
            '(lambda (x) (not (_less x pivot)))
            (cdr lst)))
    lst
Limited testing.
  • Thanks 1
If you're worried about the removal of duplicated elements when using (vl-sort), just use (vl-sort-i) to obtain the sorted indices and use them to order the original list - this has been solved/demonstrated many times over and is also typically far more performant when sorting lists for which the sort function would otherwise perform some manipulation of the list elements.
_$ (setq mylist '(5 3 6 4 5 3 7 5))
(5 3 6 4 5 3 7 5)
_$ (vl-sort mylist '<)
(3 4 5 6 7)
_$ (mapcar '(lambda ( n ) (nth n mylist)) (vl-sort-i mylist '<))
(3 3 4 5 5 5 6 7)
Edited by Lee Mac
  • Like 2
  • Thanks 1
A contrived exercise to demonstrate the performance considerations:
(defun foo1 ( lst )
    (vl-sort lst
        (function
            (lambda ( s1 s2 )
                (compare (splitstr s1) (splitstr s2))
(defun foo2 ( lst )
    (mapcar '(lambda ( n ) (nth n lst))
        (vl-sort-i (mapcar 'splitstr lst) 'compare)
(defun compare ( l1 l2 / x y )
    (while (and l1 l2 (= (setq x (car l1)) (setq y (car l2))))
        (setq l1 (cdr l1)
              l2 (cdr l2)
    (cond
        (   (null l1))
        (   (null l2) nil)
        (   (and (numberp x) (numberp y))
            (< x y)
        (   (numberp x))
        (   (numberp y) nil)
        (   (< (strcase x) (strcase y)))
(defun splitstr ( str )
    (read
        (strcat "("
            (vl-list->string
                (apply 'append
                    (mapcar
                        (function
                            (lambda ( a )
                                (if (< 47 a 58)
                                    (list a)
                                    (list 34 a 34)
                        (vl-string->list str)
_$ (setq mylist (makelist 100))
("byo547swd" "niq983ocu" "aca823vdk" "wtq568rur" "phi902niq" "bjh526uzd" "rji359jxn" "qqv937rwf" "tug083pja" "gad189ena" "lte537pir" "laa124lqe" "pjd997nvz" "opt105nif" "lbg559zsq" "tpj226ohq" "jdo941odr" "pyl665lro" "hoi547oxb" "tke599mge" "tqm797yrt" "dlm480ido" "jlt529gio" "dtl751rtz" "lpi310zks" "rit617cpr" "qdf999kec" "lkz260ohj" "xlg106fuk" "dqj592rbs" "rza409lss" "phx280fll" "rft924rac" "xrt327nir" "mil320zdh" "sec951fzz" "hng963son" "bhm360nws" "whv768vre" "sub738cgn" "udp152qpy" "bfv499vpg" "bef375dxu" "sne299abt" "jwg218naf" "kul046lji" "opm274fep" "xqb135wrk" "vug239ccx" "yvk063bnl" "cca701lfg" "upy690bri" "nsj806ovt" "igt413wky" "ftw622pra" "jsm813cre" "fnd378khc" "utk011unn" "hkm488zlv" "naw752kdp" "gze062nrv" "ytt910gzi" "eeq942uez" "rbm719yzv" "adu204kgv" "voo553bzq" "qah335lvg" "oky453mna" "bye070dci" "uwt849qig" "nkg662cbj" "koy546cve" "fgp548fhm" "hxm087okh" "atb056yvr" "jxz680bdn" "ofc383clx" "ran801jgt" "dai951aut" "muc372eji" "dmv843wdj" "mwl251acq" "skn266edb" "stz033eih" "qbm300sjp" "tax196nfk" "uix079eqf" "evl716cui" "tjl236dov" "mod149kqp" "cai814mxb" "yyf245cfk" "occ503uit" "csd182gul" "jgs728fmy" "hga698aqi" "hfk752ize" "vra872olq" "bjm266zaq" "zva674kji")
_$ (foo1 mylist)
("aca823vdk" "adu204kgv" "atb056yvr" "bef375dxu" "bfv499vpg" "bhm360nws" "bjh526uzd" "bjm266zaq" "bye070dci" "byo547swd" "cai814mxb" "cca701lfg" "csd182gul" "dai951aut" "dlm480ido" "dmv843wdj" "dqj592rbs" "dtl751rtz" "eeq942uez" "evl716cui" "fgp548fhm" "fnd378khc" "ftw622pra" "gad189ena" "gze062nrv" "hfk752ize" "hga698aqi" "hkm488zlv" "hng963son" "hoi547oxb" "hxm087okh" "igt413wky" "jdo941odr" "jgs728fmy" "jlt529gio" "jsm813cre" "jwg218naf" "jxz680bdn" "koy546cve" "kul046lji" "laa124lqe" "lbg559zsq" "lkz260ohj" "lpi310zks" "lte537pir" "mil320zdh" "mod149kqp" "muc372eji" "mwl251acq" "naw752kdp" "niq983ocu" "nkg662cbj" "nsj806ovt" "occ503uit" "ofc383clx" "oky453mna" "opm274fep" "opt105nif" "phi902niq" "phx280fll" "pjd997nvz" "pyl665lro" "qah335lvg" "qbm300sjp" "qdf999kec" "qqv937rwf" "ran801jgt" "rbm719yzv" "rft924rac" "rit617cpr" "rji359jxn" "rza409lss" "sec951fzz" "skn266edb" "sne299abt" "stz033eih" "sub738cgn" "tax196nfk" "tjl236dov" "tke599mge" "tpj226ohq" "tqm797yrt" "tug083pja" "udp152qpy" "uix079eqf" "upy690bri" "utk011unn" "uwt849qig" "voo553bzq" "vra872olq" "vug239ccx" "whv768vre" "wtq568rur" "xlg106fuk" "xqb135wrk" "xrt327nir" "ytt910gzi" "yvk063bnl" "yyf245cfk" "zva674kji")
_$ (foo2 mylist)
_$ (equal (foo1 mylist) (foo2 mylist))
T
_$ (benchmark '((foo1 mylist) (foo2 mylist)))
Benchmarking ..........Elapsed milliseconds / relative speed for 128 iteration(s):
    (FOO2 MYLIST).....1953 / 4.84 <fastest>
    (FOO1 MYLIST).....9453 / 1.00 <slowest>
  • Like 4
  • Thanks 1
Dictionary is an object in the drawing file.
(setq mainDict (namedobjdict))
(dictadd mainDict "PART001" ;this is they unique key
  (entmakex
    '((0 . "XRECORD")  ;needed
      (100 . "AcDbXrecord") ;needed
      (1 . "Steel")
      (2 . "Description")
      (3 . "12.5")
      (4 . "24")
      (5 . "100")
      (6 . "Black")
(setq color (cdr (assoc 6 (dictsearch Maindict "PART001"))))
So the main "list" or Dictionary is mainDict you then need a key to store the sub list under "PART001" and then as many dotted pairs as you want.
dictsearch would be alot faster than assoc with 20,000 list.
  • Like 2
Stating the obvious: just consider that creating xrecords & dictionaries is modifying the drawing database and the data is stored in the drawing, whereas LISP data is obviously transient.
  • Like 2
  • Agree 1
Yes, could be a good thing or a bad thing depending on what PGia wants to do. like I wouldn't use the entity name as the key as they are generated when opening the drawing and would be invalid next time you open said drawing. Also I think you can only store strings in the dotted pair. was only bringing as another option for a faster search of a "list".
@BIGAL Thanks.
I've tried Bubblesort and it seems to work well. But won't the recursive call to Bubblepass be problematic with very long lists?
I've run into this problem a couple of times while doing my tests.
Thank you very much, @Lee Mac
I didn't know about vl-sort-i until now.
After trying it, I think it's the best solution.
The only drawback is that it always returns the full list of indices even though the user might only need a smaller number of elements.
However, it works very fast even with very large lists, so this isn't a problem.
By the way: my lists consist of lists of 5 numbers: 1 integer and 4 real numbers, which I need to sort from lowest to highest and with a preference order from left to right.
