Pramod Kumar Posted 14 hours ago Posted 14 hours ago Hello CADTutor community, As someone working with civil engineering infrastructure datasets, one of the most frustrating bottlenecks has always been data migration from AutoCAD into GIS environments (QGIS, ArcGIS, PostGIS). Often, drawings received from subcontractors sit at arbitrary (0,0) origins with zero projection metadata, line layers lack topology, and pipe invert tags are trapped as plain CAD text. To tackle this, we developed a tool called GeoMorph AI (https://propertyrock.in) that automates the extraction and georeferencing pipeline in ~12 seconds: Key Features: - Direct Ingestion: Parses raw DWG/DXF layers, text tags, and invert levels using Python ezdxf. - Autonomous Coordinate Alignment: Pattern-matches local CAD layout features to real-world WGS84/UTM coordinates without manual rubber-sheeting. - Topology Rebuilding: Converts unjoined polylines into clean network topology for water/sewer/telecom lines while preserving diameters and depths. - Multi-Format Export: ESRI Shapefile bundle (.shp, .shx, .dbf, .prj), GeoPackage (.gpkg), GeoJSON, and direct PostGIS 3.4 database sync. - 3D WebGL Map: Interactive browser viewer for instant visual quality control. 1-Minute Video Demonstration: https://youtu.be/V9LtA6QLPz0 We would genuinely appreciate thoughts and critique from draftsmen and CAD managers: - What edge cases (e.g. 3D solids, complex dynamic blocks, splines) usually break your exports into GIS? - How does your current workflow handle local grid to national projection transformations? If anyone has a sample tricky DWG they would like to test, feel free to share or test it directly on the platform! Best regards, Pramod Kumar Quote
SLW210 Posted 12 minutes ago Posted 12 minutes ago Is this for AutoCAD, Civil 3D, Map 3D or all of them? As stated on another thread, if a subcontractor submitted incomplete drawings, they would be sent back or not paid. Quote
