Automated tool for converting unreferenced AutoCAD DWGs to georeferenced GIS Shapefiles in 12s
Hello CADTutor community,
As someone working with civil engineering infrastructure datasets, one of the most frustrating bottlenecks has always been data migration from AutoCAD into GIS environments (QGIS, ArcGIS, PostGIS).
Often, drawings received from subcontractors sit at arbitrary (0,0) origins with zero projection metadata, line layers lack topology, and pipe invert tags are trapped as plain CAD text.
To tackle this, we developed a tool called GeoMorph AI (https://propertyrock.in) that automates the extraction and georeferencing pipeline in ~12 seconds:
Key Features:
- Direct Ingestion: Parses raw DWG/DXF layers, text tags, and invert levels using Python ezdxf.
- Autonomous Coordinate Alignment: Pattern-matches local CAD layout features to real-world WGS84/UTM coordinates without manual rubber-sheeting.
- Topology Rebuilding: Converts unjoined polylines into clean network topology for water/sewer/telecom lines while preserving diameters and depths.
- Multi-Format Export: ESRI Shapefile bundle (.shp, .shx, .dbf, .prj), GeoPackage (.gpkg), GeoJSON, and direct PostGIS 3.4 database sync.
- 3D WebGL Map: Interactive browser viewer for instant visual quality control.
▶️ 1-Minute Video Demonstration:
https://youtu.be/V9LtA6QLPz0
We would genuinely appreciate thoughts and critique from draftsmen and CAD managers:
- What edge cases (e.g. 3D solids, complex dynamic blocks, splines) usually break your exports into GIS?
- How does your current workflow handle local grid to national projection transformations?
If anyone has a sample tricky DWG they would like to test, feel free to share or test it directly on the platform!
Best regards,
Pramod Kumar
Is this for AutoCAD, Civil 3D, Map 3D or all of them?
As stated on another thread, if a subcontractor submitted incomplete drawings, they would be sent back or not paid.
Thanks for the question and the sharp reality check, @SLW210!
To answer your first question: It works for standard AutoCAD (.DWG / .DXF), Civil 3D, and Map 3D drawings. The parser extracts 2D/3D polylines, pipe network linework, layer hierarchies, and block attributes directly without requiring an active Autodesk Map 3D / Civil 3D seat on the client machine.
Regarding subcontractors submitting incomplete drawings: You are 100% right on contract protocol. On new builds under active contract, non-compliant CAD files should definitely be rejected and kicked back to the sub.
Where our users run into the real headache is in scenarios where "sending it back" is no longer an option:
1. Legacy archives & brownfield utility assets: Decades-old municipal or plant drawings where the original drafter/firm is long gone, drawn in local 0,0 plant coordinates with zero projection metadata.
2. Cross-team handoffs: When civil drafters (who only work in 2D AutoCAD LT) hand off files to municipal GIS teams who need instant OGC Shapefiles or PostGIS layers with invert depths and pipe diameters intact.
3. Rapid feasibility & bidding: When estimating contractors receive messy tender CAD files and need to overlay them onto Google Earth KMZ or GIS parcel boundaries in minutes rather than spending half a day rubber-sheeting.
We're trying to eliminate that tedious manual linework cleaning and coordinate mapping when teams are stuck with what they have.
Would love your thoughts on what edge cases you see break Map 3D exports most frequently!
