Converting scanned engineering drawings into accurate editable CAD geometry
Legacy project drawings are often available only as scanned PDFs or raster images. Converting them into editable DWG geometry can be difficult because paper distortion, scanning errors, and inconsistent image scaling may affect dimensional accuracy.
Scaling the image using a single known dimension may not correct distortion across the entire drawing.
When converting old scanned drawings, how do you verify geometric accuracy across the full sheet? Do you use multiple control dimensions, image rectification, or manual reconstruction of critical geometry?
Edited by indiancad
Hopefully there are dimensions noted on the scan. That's what I would typically use to manually redraw it accurately in CAD from scratch.
I have used Raster Tools with some great success before.
For badly distorted drawings, I create blocks and scale in both directions, no matter the method used to create the linework.
If it is a critical part that needs to be  drawn very accurate or just a terrible plot, scan, etc., I just look at the drawing and totally redraw from scratch using the indicated dimensions or even better for small objects I just measure the object if available.
Raster images - Tiffs - complete redraw using whatever dimensions are available, what I don't know you can infer a lot (for example a wall thickness near a known dimension can infer another dimension) and after that it is down to experience and knowledge with the odd "go over there with a tape measure". Mapping websites are OK for buildings - use 2 or 3 and average out the distances can help if there are absolutely no known dimensions (again inferring distances from known things... including counting bricks from a street view), mapping I have a tool to draw perpendicular polylines off the first line angle which helps a lot. Small parts are often drawn to fractions of the scale (0.5mm, 1mm, 2.5mm etc.... 1/100th inch or whatever) - so once drawn can snap entities to a grid... gets close enough which is all you can do if you cannot be supplied with dimension or a part / site visit to work more accurately from
Used to have Paintshop Pro (7 I think) that had a tool to correct parallax errors somewhat.
