indiancad Posted Wednesday at 05:08 AM Posted Wednesday at 05:08 AM (edited) Legacy project drawings are often available only as scanned PDFs or raster images. Converting them into editable DWG geometry can be difficult because paper distortion, scanning errors, and inconsistent image scaling may affect dimensional accuracy. Scaling the image using a single known dimension may not correct distortion across the entire drawing. When converting old scanned drawings, how do you verify geometric accuracy across the full sheet? Do you use multiple control dimensions, image rectification, or manual reconstruction of critical geometry? Edited Wednesday at 05:09 AM by indiancad Quote
Paul Li Posted Wednesday at 05:42 AM Posted Wednesday at 05:42 AM Hopefully there are dimensions noted on the scan. That's what I would typically use to manually redraw it accurately in CAD from scratch. 2 Quote
SLW210 Posted Wednesday at 12:21 PM Posted Wednesday at 12:21 PM I have used Raster Tools with some great success before. For badly distorted drawings, I create blocks and scale in both directions, no matter the method used to create the linework. If it is a critical part that needs to be drawn very accurate or just a terrible plot, scan, etc., I just look at the drawing and totally redraw from scratch using the indicated dimensions or even better for small objects I just measure the object if available. 1 Quote
Steven P Posted Wednesday at 06:48 PM Posted Wednesday at 06:48 PM Raster images - Tiffs - complete redraw using whatever dimensions are available, what I don't know you can infer a lot (for example a wall thickness near a known dimension can infer another dimension) and after that it is down to experience and knowledge with the odd "go over there with a tape measure". Mapping websites are OK for buildings - use 2 or 3 and average out the distances can help if there are absolutely no known dimensions (again inferring distances from known things... including counting bricks from a street view), mapping I have a tool to draw perpendicular polylines off the first line angle which helps a lot. Small parts are often drawn to fractions of the scale (0.5mm, 1mm, 2.5mm etc.... 1/100th inch or whatever) - so once drawn can snap entities to a grid... gets close enough which is all you can do if you cannot be supplied with dimension or a part / site visit to work more accurately from Used to have Paintshop Pro (7 I think) that had a tool to correct parallax errors somewhat. 1 Quote
BIGAL Posted Wednesday at 11:44 PM Posted Wednesday at 11:44 PM Hire a casual, student, some one wanting experience drafting, raster to vector can be a hit or miss. Use Ortho a lot when tracing over, and like others read the dims, using ortho start point, drag then type dim value. A secret underlay is a pdf. 1 Quote
SLW210 Posted 18 hours ago Posted 18 hours ago We have sent old blueprints and microfiche out to a company to be put to digital at a previous company, they did a pretty good job, no telling the cost, this was quite a while ago. My boss did ask a few years ago about getting some paid interns to do some old blueprints that need scanned. Yes, if your company wants to spend the money, there are some pretty good software choices out there to make it easier. After a short learning curve I did very well with Raster Design and a few LISPs. I plan to see if my work will get this... HP AI Vectorization | HP® Official Site | HP® Official Site, at least see about a trial. Quote
indiancad Posted 16 minutes ago Author Posted 16 minutes ago On 11/18/2026 at 11:12 AM, Paul Li said: Hopefully there are dimensions noted on the scan. That's what I would typically use to manually redraw it accurately in CAD from scratch. Agreed. Redrawing from known dimensions is often the most reliable approach, especially when the scan itself is distorted. The challenge is when only a few dimensions are available and the rest of the geometry has to be reconstructed. 1 Quote
indiancad Posted 16 minutes ago Author Posted 16 minutes ago On 11/18/2026 at 5:51 PM, SLW210 said: I have used Raster Tools with some great success before. For badly distorted drawings, I create blocks and scale in both directions, no matter the method used to create the linework. BrowseArt Prints If it is a critical part that needs to be drawn very accurate or just a terrible plot, scan, etc., I just look at the drawing and totally redraw from scratch using the indicated dimensions or even better for small objects I just measure the object if available. Scaling in X and Y can correct some distortions, but it won't fix local warping across the sheet. For badly distorted scans, do you also check intermediate dimensions after scaling? Quote
indiancad Posted 15 minutes ago Author Posted 15 minutes ago On 11/19/2026 at 12:18 AM, Steven P said: Raster images - Tiffs - complete redraw using whatever dimensions are available, what I don't know you can infer a lot (for example a wall thickness near a known dimension can infer another dimension) and after that it is down to experience and knowledge with the odd "go over there with a tape measure". Mapping websites are OK for buildings - use 2 or 3 and average out the distances can help if there are absolutely no known dimensions (again inferring distances from known things... including counting bricks from a street view), mapping I have a tool to draw perpendicular polylines off the first line angle which helps a lot. Small parts are often drawn to fractions of the scale (0.5mm, 1mm, 2.5mm etc.... 1/100th inch or whatever) - so once drawn can snap entities to a grid... gets close enough which is all you can do if you cannot be supplied with dimension or a part / site visit to work more accurately from GetPhoto Storage Used to have Paintshop Pro (7 I think) that had a tool to correct parallax errors somewhat. Good point about using surrounding references to infer missing dimensions. Correcting parallax and distortion before tracing can make a significant difference, particularly with older scans. Reconstructing critical geometry from known dimensions still seems the safest option. Quote
indiancad Posted 14 minutes ago Author Posted 14 minutes ago 17 hours ago, SLW210 said: We have sent old blueprints and microfiche out to a company to be put to digital at a previous company, they did a pretty good job, no telling the cost, this was quite a while ago. My boss did ask a few years ago about getting some paid interns to do some old blueprints that need scanned. Yes, if your company wants to spend the money, there are some pretty good software choices out there to make it easier. AutoCADsoftware After a short learning curve I did very well with Raster Design and a few LISPs. I plan to see if my work will get this... HP AI Vectorization | HP® Official Site | HP® Official Site, at least see about a trial. Interesting approach.I think verification against known dimensions is still necessary even after vectorization. Quote
