Simple dialog with wxPython in AutoCAD
import traceback
import wx
from pyrx import Ap
class TestUIDialog(wx.Dialog):
  def __init__(self, parent=None):
    style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER
    super().__init__(
        parent,
        title="PyRx wxPython Control Check",
        size=(340, 240),
        style=style,
        name="PyRxTestUIDialog",
    # Create a panel, a sizer and some controls
    panel = wx.Panel(self)
    sizer = wx.BoxSizer(wx.VERTICAL)
    self.cb = wx.CheckBox(panel, label="Modern Visual Styles Active")
    self.cb.SetValue(True)
    self.combo = wx.ComboBox(
        panel,
        choices=["Option A", "Option B"],
        value="Option A",
        style=wx.CB_READONLY,
    # Bind to an event
    self.combo.Bind(wx.EVT_COMBOBOX, self.on_combo_select)
    self.gauge = wx.Gauge(panel, range=100)
    self.gauge.SetValue(70)
    self.txt = wx.TextCtrl(panel, value="Text input test")
    self.btn = wx.Button(panel, wx.ID_OK, label="Close Test")
    # add the controls to the sizer
    for ctrl in (self.cb, self.combo, self.gauge, self.txt, self.btn):
      sizer.Add(ctrl, 0, wx.ALL | wx.EXPAND, 8)
    # add the sizer to the panel
    panel.SetSizer(sizer)
  def on_combo_select(self, event):
    print("Selected:", self.combo.GetValue())
    event.Skip()
@Ap.Command()
def testui():
  try:
    with TestUIDialog() as dlg:
      res = Ap.Application.showModalDialog(dlg)
      print(res)
  except Exception as err:
    traceback.print_exception(err)
