Hi everyone,
I will explain what I would like to be able to do; I would like to link the Title Block attributes (Only some of them, "Drawing Number", "Drawing Title", "Revision", etc.) to the Drawing Index on the cover sheet of the drawing series and to the Transmittal spreadsheet and have it set up so the if any one of these is changed the other two will update.
Which is the best way to achieve this? Attribute data extraction, a lisp routine or is there another better way?
I appreciate your efforts to clarify this.
Thanks,
Caddy79. :?
I'm thinking fields might be your best bet and/or data-linking. I'll try and come back with something more definitive.
  • 1 year later...
I also would like to link the Title Block attributes (Only some of them, "Drawing Number", "Drawing Title", "Revision", etc.) to the Drawing Index on the cover sheet of the drawing series so the if any one of these is changed the other will update.
Have you had any success in finding an answer to this question?
or better still a lisp or maco?
