Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Junior Member
    AutoCAD LT 2018
    Nov 2013
    Fernandina Beach, FL
    15
    Default Preventing Layers from Being Purged?
    Morning all,
    I'm working on updating some files that are used as templates. The company format for templates is a DWG file with a title block created, all of the layers created, dimension and text styles set, LTS set, etc. To use the template, we copy the file into a folder created for the facility, then rename it to whatever the facility name is. We have a CAD team then that creates a separate, facility-specific drawing and inserts it into this drawing as a block. Then the information in the title block is changed as needed and the drawing is sent along to a member of another team, who places fixtures into the drawing and puts them on their respective layers. The second team has very minimal AutoCAD training as that is not their primary job.
    To minimize file size we want the second team to purge the drawing. However, we still want to retain the unused layers in case fixtures are added at a later date that will need those layers (since the second team is not so AutoCAD savvy, if the layer isn't there some will just put it on "0" and change the color of the fixture rather than creating a layer for it and putting it on that layer).
    My question is: Is there any simple way to prevent the unused layer from being purged? I know the "purge" command allows you to select what will and won't be purged, but since the second team does not have much AutoCAD experience this is not feasible.
    This may be a rather hokey workaround, but I'm thinking to draw some very small lines in some portion of the title block that won't be disturbed, put them each on a different layer, and set the color on all of the lines to white so they don't show. Then make them part of the title block. I know that's not very technical, but I think it would do the job which is the ultimate goal.
    Any suggestions for a better way to accomplish the goal?
    Thanks in advance!
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,565
    The method described here attaches Xdata to layer 0. Since Layer 0 can't be purged, neither can this Xdata (using normal means).
    R.K. McSwain
    CAD Panacea | twitter
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,158
    Open up the title block and at the midpoint of one of the polylines (anywhere basically) add a series of points, and place each one, on one of the layers that you use, that way there is always something in the drawing on every layer and the layer can't be purged. I mentioned the midpoint because one drawback could be if someone uses a point style, and then the points show up, but if you set the UCS to Front or Left (depending on which edge they are) before drawing the points, then you won't see them if a point style is applied. Just don't forget to set the UCS back to world when you finish .
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,589
    "Draw some lines" put them ever so slightly away from lower left and rescale them down to be really small like 0.000001 long. They will plot as a dot if you use extents as your limit but if they are so close to a title edge you will probably not see it.
    Write a simple script or lisp to create.
  5. #5
    Senior Member
    OMEGA-ThundeR's Computer Details
    Windows 10
    HP Z440
    Civil
    OMEGA-ThundeR's Discipline Details
    Civil Engineer (CAD Design)
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    320
    OR you could design some lisp routines that purges everything besides the layer info. As said purging has the option to purge only the things you want when done manually.
    But the whole process of creating the drawing seems like assembly line work.. Person 1 creates a template, person 2 puts the template in a drawing and places the dwg file in a project folder, person 3 draws the objects and person 4 purges the drawing to keep the file size down.
    Looks like it can use some optimisations...
  6. #6
    Senior Member mikekmx's Avatar
    Electrical 2008
    Dec 2012
    UK
    445
    Quote Originally Posted by LydiaGP View Post
    Morning all,
    Thanks in advance!
    that is a good way to do what you want. KISS.
    where did my sig go?
  7. #7
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    if these blocks always end up on the same layer in a drawing, put the linework in the native block on that layer. Layers come with any inserted object into the receiving drawing. If the layers are already there, no sweat. If they don't exist in the receiving drawing, they will be created upon insertion.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  8. #8
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,565
    AutoCAD
    None of these methods of creating graphical entities on layers will prevent those layers from being purged, because the entities can be removed.
    Try and purge the 3 layers in the attached drawing. And note that DBLIST confirms there are no graphical objects in the drawing.
    purgeme.dwg
    R.K. McSwain
  9. #9
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,158
    DBLIST and XDATA are not available in LT
  10. #10
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,137
    Quote Originally Posted by rkmcswain View Post
    .......Try and purge the 3 layers in the attached drawing.....
    I purged Regapps and then the three layers.
  1. Stop layers from being purged
    By stryder444 in forum AutoCAD Drawing Management & Output
    Last Post: 7th Mar 2014, 03:25 pm
  2. Keep layers from being deleted or purged
    By toberino in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2012, 08:55 pm
  3. preventing dimstyle overrides...
    By hazardman in forum AutoCAD Drawing Management & Output
    Last Post: 16th Mar 2012, 05:02 pm
  4. Preventing mirroring of text in external references
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 19th Jan 2007, 02:24 am
  5. Preventing multiple instances of acad.exe from running
    By joerockt in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jul 2006, 08:09 pm
