Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    Full Member
    AutoCAD 2014
    May 2014
    91
    Default How to Create an Oil Ring in AutoCAD?
    How do you create an oil ring (please see below image) in AutoCAD?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Doing it in 3D create one ridge, extrude it then use a circular array. Union all the ridges. BTW...isn't that the spacer between the two rails you are pointing at?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    This is what I came up with on my second try. I used a radius of 5.96831. The extruded profile had a width of .375 and a height of .135. The number of items in my polar array was 100. It is not perfect however as there is a tapered overlap of 0.0158 at the inside circumference of the spacer. But....once the array is exploded (since it is a block) I could simply union all 100 objects and the overlap would disappear.
    Full Member
    AutoCAD 2014
    May 2014
    91
    Yes it is.
  5. #5
    Full Member
    AutoCAD 2014
    May 2014
    91
    Attachment 62678
    I don't understand. Please tell me step-by-step.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    First you have to create your profile. Have you done that? Here is what my profile progression looked like. All three profiles are comprised of polylines. The last profile is a single continuous polyline.
    What do you have for dimensional data? What is the ring O.D. and I.D.? What is the height of the spacer? How many ridges are there? What is the material thickness?
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    It just dawned on me why I had the overlapping extruded profiles. I forgot to taper my extruded profile. Duh!
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    After you have created your profile extrude it such that it extends beyond both the O.D. and I.D. of the ring (which you should have drawn already). In the image below the green, yellow and white lines will be extruded so they extend through the profile. The extruded lines will become surfaces. These surfaces can be used to trim our extruded profile. For this you need to use the SLICE command with the Surface option.
    My extruded profile is circled in red. See how in extends beyond both the green and yellow arcs?
    A close up of the extruded profile and lines to be used to slice it. The lines on the side will give it the required taper. Note: First slice the object with the extruded arcs.
    Once you have the extruded profile in the shape it needs to be use the ARRAY command with the Polar option to create a full spacer ring.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Lastly, here is a closeup view of a portion of the spacer.
    Good luck with your oil ring spacer. Have fun and post an image of the finished 3D model when you are done.
  10. #10
    Full Member
    AutoCAD 2014
    May 2014
    91
    What is a "ridge"?
    Please explain with an image.
  1. O-ring groove
    By paulmcz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Mar 2015, 06:24 pm
  2. Ring beam
    By KTS in forum Architecture & ADT
    Last Post: 1st Aug 2013, 12:57 am
  3. Ring Mate
    By slide in forum SolidWorks
    Last Post: 16th Jan 2010, 11:25 pm
  4. Diamond Wedding Ring
    By FazBear in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Aug 2006, 08:33 am
  5. Wedding Ring Templates ??
    By mykemitchell in forum AutoCAD Beginners' Area
    Last Post: 3rd Sep 2003, 09:26 pm
