jes_g Posted February 20, 2018 Share Posted February 20, 2018 Sample.dwg Hi all, I want to write a program which will export the coordinates of vertices for selected polylines with Object Data which corresponds to each polyline. Please refer to a sample drawing attached with this thread. I am happy with this program to export coordinates ; ---------------------------------------------------------------------- ; (Export LWPOLYLINE Vertices & Points to File) ; Copyright (C) 2000 DotSoft, All Rights Reserved ; Website: http://www.dotsoft.com ; ---------------------------------------------------------------------- ; DISCLAIMER: DotSoft Disclaims any and all liability for any damages ; arising out of the use or operation, or inability to use the software. ; FURTHERMORE, User agrees to hold DotSoft harmless from such claims. ; DotSoft makes no warranty, either expressed or implied, as to the ; fitness of this product for a particular purpose. All materials are ; to be considered ‘as-is’, and use of this software should be ; considered as AT YOUR OWN RISK. ; ---------------------------------------------------------------------- ;;Revised 8/23/07 CAB to report coordinates in current UCS (defun c:ptexport () (setq sset (ssget '((-4 . "<OR")(0 . "POINT") (0 . "LWPOLYLINE")(-4 . "OR>")))) (if sset (progn (setq itm 0 num (sslength sset)) (setq fn (getfiled "Point Export File" "" "txt" 1)) (if (/= fn nil) (progn (setq fh (open fn "w")) (while (< itm num) (setq hnd (ssname sset itm)) (setq ent (entget hnd)) (setq obj (cdr (assoc 0 ent))) (cond ((= obj "POINT") (setq pnt (cdr (assoc 10 ent))) (setq pnt (trans pnt 0 1));;**CAB (princ (strcat (rtos (car pnt) 2 "," (rtos (cadr pnt) 2 "," (rtos (caddr pnt) 2 ) fh) (princ "\n" fh) ) ((= obj "LWPOLYLINE") (if (= (cdr (assoc 38 ent)) nil) (setq elv 0.0) (setq elv (cdr (assoc 38 ent))) ) (foreach rec ent (if (= (car rec) 10) (progn (setq pnt (cdr rec)) (setq pnt (trans pnt 0 1));;**CAB (princ (strcat (rtos (car pnt) 2 "," (rtos (cadr pnt) 2 "," (rtos elv 2 ) fh) (princ "\n" fh) ) ) ) ) (t nil) ) (setq itm (1+ itm)) ) (close fh) ) ) ) ) (princ) ) (princ "\nPoint Export loaded, type PTEXPORT to run.") (princ) Now I want to add Object data such as: 1. For polylines on 'LVCable' layer - CSAMetric, Conductor, FeederNo, NoOfCores 2. For polylines on other layers - CSABlue, CSANeutral, CSARed, CSAYellow, FeederNo Thank you Best wishes, Jes G Sample.dwg Quote Link to comment Share on other sites More sharing options...
asos2000 Posted February 20, 2018 Share Posted February 20, 2018 Give this a try http://lee-mac.com/polyinfo.html Quote Link to comment Share on other sites More sharing options...
ronjonp Posted February 20, 2018 Share Posted February 20, 2018 If you really want to write this program, most of the legwork is already HERE. Quote Link to comment Share on other sites More sharing options...
