Lee Mac Posted June 19, 2018 Share Posted June 19, 2018 Is anyone else noticing that additional carriage returns are being automatically added between paragraphs in a post? Using FF 60.0.2 64-bit. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 19, 2018 Author Share Posted June 19, 2018 The above is a prime example - in the post editor there was only a single line between the two lines of text. Quote Link to comment Share on other sites More sharing options...
nukecad Posted June 19, 2018 Share Posted June 19, 2018 I'm not seeing it on here, also using FF60.0.2 64-bit. (Win 10 1803, build 17134.112). I do get it on some other forums that are IPBoard based, but it's a known problem with the IPB forum reply editor itself. (It will even do it between every line on some forums). The usual solution is to use 'shift+enter' to stop it putting the extra linespace in. (Or just backspace when it does it). If it's being a problem try writing any long posts in Notepad or similar, then copy/paste into the forum editor. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 20, 2018 Share Posted June 20, 2018 Trying not to hijack the same type of thing is when people paste the code already posted 1 post above in their thank you. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 20, 2018 Share Posted June 20, 2018 Which Editor on CADTutor are you using, Enhanced (WYSIWYG), Basic or Standard? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 20, 2018 Author Share Posted June 20, 2018 I'm not seeing it on here, also using FF60.0.2 64-bit. (Win 10 1803, build 17134.112). I do get it on some other forums that are IPBoard based, but it's a known problem with the IPB forum reply editor itself. (It will even do it between every line on some forums). The usual solution is to use 'shift+enter' to stop it putting the extra linespace in. (Or just backspace when it does it). If it's being a problem try writing any long posts in Notepad or similar, then copy/paste into the forum editor. To clarify, I don't see the extra lines in the forum post editor, they seem to be added after the post is submitted. This is also only a relatively recent issue, as I've not experienced this in the 10 years I've been a member here, and I've not changed my posting habits. Which Editor on CADTutor are you using, Enhanced (WYSIWYG), Basic or Standard? The WYSIWYG editor, but have also seen it using the Quick Reply editor. After posting, I find that I have to edit every post to remove the extra blank lines. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 20, 2018 Share Posted June 20, 2018 Let me try here. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 20, 2018 Share Posted June 20, 2018 I do not see it happening. The spaces in between these sentences are added by me Just trying to force this to be a long message. One more line here. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 20, 2018 Author Share Posted June 20, 2018 This is how I see your post RK: Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 20, 2018 Share Posted June 20, 2018 Correct @Lee_Mac, as stated in the message, I added those spaces in between the lines of the post, and there is no extra space at the bottom of the message. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 20, 2018 Share Posted June 20, 2018 Also, when you view the source of the HTML, there are no extra carriage returns, or spacing added by CSS... at least that I can see. Quote Link to comment Share on other sites More sharing options...
dlanorh Posted June 20, 2018 Share Posted June 20, 2018 Is anyone else noticing that additional carriage returns are being automatically added between paragraphs in a post? Using FF 60.0.2 64-bit. Maybe this is geographical (keyboard driver?) because I'm seeing the same thing. I've found that doing a preview, then going back to the editor, shows the extra carriage returns which I can edit out. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 20, 2018 Share Posted June 20, 2018 Here is a full reply Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 20, 2018 Author Share Posted June 20, 2018 Correct @Lee_Mac, as stated in the message, I added those spaces in between the lines of the post, and there is no extra space at the bottom of the message. Based on your test, perhaps I wasn't clear in my original explanation of the issue that I'm encountering - as a demonstration, I'll post screenshots of how the post editor is presented versus how the resulting post appears on the forums. Here is the start of another test paragraph, with only a single line break in between the two paragraphs. Here is a third paragraph, again, with only a single line separating the blocks of text - let's see how this is presented in the forum post. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 20, 2018 Author Share Posted June 20, 2018 And now the results... The post editor: The resulting forum post: Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 20, 2018 Author Share Posted June 20, 2018 I've also added a poll to this thread so that we can gauge who is & isn't witnessing this behaviour and see any correlation. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 21, 2018 Share Posted June 21, 2018 Yes from me. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted June 21, 2018 Share Posted June 21, 2018 And now the results... Hard to tell from screenshots. Are you saying that extra returns are being injected in between the sentences? Using FF, right? Highlight the text in the body of your post, then right-click and choose "Inspect Element". Are there truly extra returns in the HTML code? I checked your post in this thread (post #14) and it does have extra returns, but I don't know if you purposely added those as an example. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 21, 2018 Share Posted June 21, 2018 Go into your general settings and select the standard editor and see if that changes anything. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 21, 2018 Author Share Posted June 21, 2018 Hard to tell from screenshots. Are you saying that extra returns are being injected in between the sentences? Yes. In the screenshots you will see that there is only a single line separating paragraphs in the post editor, but two lines separating the paragraphs in the resulting post. Using FF, right? Highlight the text in the body of your post, then right-click and choose "Inspect Element". Are there truly extra returns in the HTML code? Yes, there are extra line breaks I checked your post in this thread (post #14) and it does have extra returns, but I don't know if you purposely added those as an example. No - as shown by the post editor screenshot - I did not add the extra returns. Quote Link to comment Share on other sites More sharing options...
