Nice and very informative tips...thanks for posting it here...
I've been using Logitech mice for years, the Performance Mouse MX most recently and for some time. SetPoint is severely lacking; at most you can assign a keystroke "Ctrl+<Key>".
^^ Hence my ordering the Macro programmable mouse linked above.![]()
"Potential has a shelf life." - Margaret Atwood
...The moment I tried the best I can, the better I got the most wonderful design ever...
You've never worked with MicroStation (MS), have you?
When working with AutoCAD products, I have no real need for either of these devices (specifically the additional macro programmable buttons). I have a keyboard for that.
When working with MS (something I'm cross training on now), however, the keyboard is almost useless. Everything stems from a menu, or toolbar or sort, with hundreds of palettes... it's retarded. I actually got the idea to purchase these devices as a result of some MS forums that had posted positive results, as the macro keys could be programmed with functionality that otherwise cannot be achieved with the standard keyboard (something I find infuriating). Again, haven't tested them out yet to know for sure; I just love getting new gadgets! LoL
Edit: The other device I ordered is the Logitech G13. I didn't mention that (in this thread) earlier.
I had the same problem using Autocad with a Logitech M305 mouse.
Setting button 3 to Other > Generic button under Setpoint solved it halfway; panning became possible, but fitfully.
Setting buttons 4 and 5 (mouse wheel left and right) to "Do nothing" solved the issue.
Another reason why I opted for the MX518. The mouse wheel doesn't have a left/right tilt. I bought a mouse that had that feature a long time ago and it frustrated me so much that I swore I'd never get another like that.
Chuck Norris counted to infinity...
Twice.
The G700's got onboard memory for different profiles... to which you can assign (as I have) acad.exe to an aptly named profile 'AutoCAD'. This combined with the ability to automatically switch profiles when an assigned application is the active window, the same buttons now have different functions simply by switching windows.
This is the main reason I went from the Performance Mouse MX to the G700.
In my AutoCAD profile, I set the Left Tilt, and Right Tilt buttons as 'Middle Button'... so NMW I invoke the PAN command (thank you MBUTTONPAN = 1).
Separately, both the G700 (mouse), and the G13 (gameboard) have colors association with the profiles... so I've set the AutoCAD profile as red (same color as my command line text), and the MS profile green for simplicity.
Thank you for clearing this. I've been sitting here for hours wondering which command to assign to the middle button. I have a problem though. The panning occurs far too fast. If I just click and drag 1mm, my model disappears. I have to look for it for a while before discovering it somewhere in the horison. Any idea why that might be?
Wait. Let me rephrase that. I have an aditional screen which I connect to my laptop. Panning is fine when the 3dsmax window is in my laptop screen, it pans far too fast when it is in my external screen. Any idea why?
