Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 55
  1. #11
    Full Member beauXjames's Avatar
    AutoCAD 2008
    Apr 2008
    Austin, TX
    56
    Have you tried taking a vacation?
    -- Hrabal -- And as I walked down other corridors, thousands of silent, defenseless books passed before me like the chickens that had broken out of their cages at the slaughterhouse...the chickens that waddled and pecked for a while but were always caught by the girls, who then hung them on the conveyor belt's hooks, thus condemning them, like these books stacked along the corridors, to an early grave. ~ Too Loud a Solitude ~
  2. #12
    Full Member
    AutoCAD 2006
    May 2007
    39
    I have had this happen before. What I did was enter a viewport that I could select and then hit CTRL+R to toggle through the viewports. When it entered the one that I couldn't select I double clicked out of it and it was selectable.....wierdest thing.
  3. #13
    Senior Member lulumara's Avatar
    lulumara's Computer Details
    Window 10
    Intel i7
    P&ID
    lulumara's Discipline Details
    Cad Designer/ Draftsman
    P&ID
    Mechanical, Piping draftsman, Structural, Underground electrical distribution designer (civil), Architectural, and more.
    AutoCAD 2017
    Jun 2006
    VANCOUVER,B.C.
    335
    Just open the Layer Manager and go to viewport or look for layers who is frozen then click it to unfreez it then go back to your paperspace then you 'll see the viewport right away.
    Jimmy - using AutoCad 2017 and Solidworks 2009
  4. #14
    Full Member succu8us's Avatar
    AutoCAD 2008
    Dec 2007
    81
    way to go noypi, turn on all the layers and check the drawing.
  5. #15
    Super Member
    Dipali's Computer Details
    windows 10
    TOSHIBA "SATELLITE"
    Intel inside CORE i7
    viewsonicVA1916w
    Architectural
    Dipali's Discipline Details
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,109
    Quote Originally Posted by slimjramirez View Post
    I've had this happen several times; it's the damndest thing. If you hover over it, nothing happens. You can't select it. I'll draw it on Defpoints; which may be on, thawed, I can do anything with any other object on every other layer, but the VP is like a ghost. I know EXACTLY what you're talking about.
    I have yet to discover why this happens or how to fix it. I can only assume that there's some system variable. Probably something like VPFRUSTRATOR or something along those lines. Sometimes, if I do a saveas, for whatever reason, in the new drawing, the VP is selectable again.
    who knows?
    if you are using defpoint layer, as menetioned by SEANT above if layer 0 is off or freeze you can not select anything that is in defpoint layer. this has also been discuseD in detail here. if you search with keyword 'defpoint' , you shall find it.
    "An architect's most useful tools are an eraser at the drawing board & a wrecking bar at the site."
    Frank Lloyd Wright
  6. #16
    Senior Member
    AutoCAD 2004
    Apr 2006
    236
    I'm pretty CAD-savvy, short of writing lisps, but this one has stumped me on a few drawings. I know and use CTL-R quite a bit, and layers are the first thing I check. But it's so weird, I can run through my quick -la, o, *,t,*,*,u,* to do an all-layer on/thaw/unlock, and everything comes on accordingly, but the viewport will still not be selectable. I mean; I can CTL-R to get into the VP from the PS layout and make it active, but I still cannot select it as in changing it with grips; I can't make it wider/shorter, I can't move it to another position. I don't know if there's a system variable that permanently locks (with no method of reversing it) a VP, or if it's just a one-in-a-million-chance bug. It's only happened about 4 times that I can recall. I've always eventually got it working again soon after so it was never a major issue, but it still amazed/es me when it happens.
    It reminds me of when I was 6 and accidentally flipped my eyelid not knowing what had happened, then for years, trying to make it happen again so I could understand it...
    I eventually figured out how to flip them again (and scare the hell out of my little brothers), but I still wait for that magical moment when "There is no viewport (spoon; Matrix, yo)" happens.
    I'm such a goober... lol
    Justin J. F. RamireZ - Drafter Extraordinaire
    Bryan/College Station, Tx
    REVIT MEP 2009, CAD MEP 2009, CAD LT '00 & '04, CAD 04
  7. #17
    Forum Newbie
    AutoCAD 2005
    Oct 2008
    1
    Dipali said something about relationship from layer defpoints and 0, I tried that and is correct, my layer 0 was off and no matter what I did viewport seems like a ghost, then settinh layer 0 on, wow, like magic, all viewports being selectable. Now I need to figure how relationsip is working (environment variable?, etc.9 whatever, vieport is working.
    Thank you
  8. #18
    Full Member
    AutoCAD 2009
    Mar 2008
    New Jersey
    54
    Unfortunately this didn't work for me. I have Acad 2009 lite. I still am unable to select the viewport. I therefore made more viewports within the vp. I can cntrl R to move around but cannot select any VP. I can enter the drawing via Cntrl R but double clicking inside VP does nothing. I have spent almost an entire afternoon on this.
  9. #19
    Super Member
    windows 10
    TOSHIBA "SATELLITE"
    viewsonicVA1916w
    Architectural
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2015
    Dec 2007
    INDIA
    1,109
    Quote Originally Posted by kenny View Post
    if you have vp inside vp double clicking will try to go inside the first vp only, whcih you said were not working properly. so to check your new vp, slect the border & double click (it is maximised viewport option) and see if it lets you inside that vp or not. than you come back & give us more onfo on the first vp, so we can probably make it work also.
    Btw, START A NEW THREAD NEXT TIME FOR YOUR QUESTION.
    Frank Lloyd Wright
  10. #20
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    759
    I think Kenny has the answer to the OP's question. I have noticed, [on 2008], anyway that if you create a VP within another VP you can scale and pan as normal until you exit out of that VP. Then trying to enter the VP again will only allow you to resize but not actually enter the VP to scale or pan through it.
    You can solve this by moving the VP outside the boundries of the VP it resides in.
    KC
  1. unable to select the whole drawing
    By sparkyuk in forum AutoCAD Beginners' Area
    Last Post: 10th May 2007, 05:43 pm
  2. Unable to select Text
    By Jon J in forum AutoCAD Drawing Management & Output
    Last Post: 8th May 2007, 11:42 pm
  3. Unable to delete viewport
    By bugleboy62 in forum AutoCAD Drawing Management & Output
    Last Post: 21st Feb 2007, 08:37 pm
  4. Unable to delete viewport
    By bugleboy62 in forum AutoCAD Beginners' Area
  5. Unable to adjust scale in viewport
    By waltpeat in forum AutoCAD Drawing Management & Output
    Last Post: 17th Aug 2006, 02:37 pm
