MACNEIL Posted February 23, 2017 Posted February 23, 2017 When I run the code below it lets me load and enter the command, but it doesn't change anything. There are no errors. I only edited the spot of the "old tag" and the "new tag" to my required values. Is there something else I am missing here? I need to change the values of multiple attribute tags to the same value on a large number of different blocks permanantly. Thanks, I read 5 minutes ago that attribute tags are unchangable without exploding. Then I found a lisp which completely disproves that statement, and I'm damn pleased I found it. If you ever want to change the tag names for attributed blocks use the following, creating a list of old & new tag names. (defun c:attr_rename_list ( / x_en enn edd ss slen ix atnam namelist hit blk_ent matchname newed x) ; Process all block instances on active drawing. Check each ; attribute for match on first element in list below. On any ; match, rename the attribute to the new name given in the ; second element. ; *********** ATTRIBUTE OLD versus NEW names list ****************** (setq namelist (list ; list old name and new name. Old name can contain wild cards. (list "OLD_TAG_NAME#1" "NEW_TAG_NAME#1") ; list old name and new name. (list "OLD_TAG_NAME#2" "NEW_TAG_NAME#2") (list "OLD_TAG_NAME#3" "NEW_TAG_NAME#3") (list "OLD_TAG_NAME#4" "NEW_TAG_NAME#4") (list "OLD_TAG_NAME#5" "NEW_TAG_NAME#5") ) ) ; ********************************************************************** ; Extract selection set of all block inserts on active drawing (setq ss (ssget "_X" '((0 . "INSERT")))) (if (/= ss nil) (progn (setq slen (sslength ss)) (setq ix 0) (while (< ix slen) (setq blk_ent (ssname ss ix)) ; get next block insert to process (setq ix (1+ ix)) ; increment for next time (setq enn (entnext blk_ent)) (setq edd (entget enn)) (while (AND enn (/= (cdr (assoc 0 edd)) "SEQEND") (/= (cdr (assoc 0 edd)) "INSERT") ) (if (= (cdr (assoc 0 edd)) "ATTRIB") (progn (setq atnam (cdr (assoc 2 edd))) (setq hit nil) (foreach x namelist (if (not hit) (progn ; no match yet, keep processing (setq matchname (car x)) (if (wcmatch atnam matchname) (progn ; found exact match or wild-card match ; Change name now. Substitute in new name. (setq newed (subst (cons 2 (cadr x)) (assoc 2 edd) edd)) (entmod newed) ; update the title block instance (entupd blk_ent) (princ "\n") (princ atnam) (princ " --> ") (princ (cadr x)) (setq hit 1) ; flag that found ) ) ) ) ) ) ) ; go to next sub ent in block instance and loop back up (if (setq enn (entnext enn)) (setq edd (entget enn))) ) ) (setq ss nil) ; release the selection set ) ) (princ) ; prettier ) I love finding the answer. It makes me feel alive. Quote
hosannabizarre Posted February 23, 2017 Author Posted February 23, 2017 (edited) I would suggest just listing all the attributes that require changing on the left, and then it's okay to have a repeated value, if they all need to be changed to the same thing. It should work. Here is the original code that I found and then used to input OLD/NEW attribute titles: (defun c:attr_rename_list ( / x_en enn edd ss slen ix atnam namelist hit blk_ent matchname newed x) ; Process all block instances on active drawing. Check each ; attribute for match on first element in list below. On any ; match, rename the attribute to the new name given in the ; second element. ; *********** ATTRIBUTE OLD versus NEW names list ****************** (setq namelist (list ; list old name and new name. Old name can contain wild cards. (list "format" "S") ; list old name and new name. (list "fail_type" "I") ) ) ; ********************************************************************** ; Extract selection set of all block inserts on active drawing (setq ss (ssget "_X" '((0 . "INSERT")))) (if (/= ss nil) (progn (setq slen (sslength ss)) (setq ix 0) (while (< ix slen) (setq blk_ent (ssname ss ix)) ; get next block insert to process (setq ix (1+ ix)) ; increment for next time (setq enn (entnext blk_ent)) (setq edd (entget enn)) (while (AND enn (/= (cdr (assoc 0 edd)) "SEQEND") (/= (cdr (assoc 0 edd)) "INSERT") ) (if (= (cdr (assoc 0 edd)) "ATTRIB") (progn (setq atnam (cdr (assoc 2 edd))) (setq hit nil) (foreach x namelist (if (not hit) (progn ; no match yet, keep processing (setq matchname (car x)) (if (wcmatch atnam matchname) (progn ; found exact match or wild-card match ; Change name now. Substitute in new name. (setq newed (subst (cons 2 (cadr x)) (assoc 2 edd) edd)) (entmod newed) ; update the title block instance (entupd blk_ent) (princ "\n") (princ atnam) (princ " --> ") (princ (cadr x)) (setq hit 1) ; flag that found ) ) ) ) ) ) ) ; go to next sub ent in block instance and loop back up (if (setq enn (entnext enn)) (setq edd (entget enn))) ) ) (setq ss nil) ; release the selection set ) ) (princ) ; prettier Edited February 24, 2017 by SLW210 Added Code Tags Quote
MACNEIL Posted February 27, 2017 Posted February 27, 2017 Hmmmm, well not sure why it's not working. I tried the both codes again with only one block in a new drawing. I even tried changing the tag to match the one in the codes and still no dice. The programs load OK and they run with no errors. I tried to attsync and then looked in the block and nothing changes. Can anyone take a look at the code for me? I am not very knowledgeable in lisp routines. Thanks, I would suggest just listing all the attributes that require changing on the left, and then it's okay to have a repeated value, if they all need to be changed to the same thing. It should work. Here is the original code that I found and then used to input OLD/NEW attribute titles: (defun c:attr_rename_list ( / x_en enn edd ss slen ix atnam namelist hit blk_ent matchname newed x) ; Process all block instances on active drawing. Check each ; attribute for match on first element in list below. On any ; match, rename the attribute to the new name given in the ; second element. ; *********** ATTRIBUTE OLD versus NEW names list ****************** (setq namelist (list ; list old name and new name. Old name can contain wild cards. (list "format" "S") ; list old name and new name. (list "fail_type" "I") ) ) ; ********************************************************************** ; Extract selection set of all block inserts on active drawing (setq ss (ssget "_X" '((0 . "INSERT")))) (if (/= ss nil) (progn (setq slen (sslength ss)) (setq ix 0) (while (< ix slen) (setq blk_ent (ssname ss ix)) ; get next block insert to process (setq ix (1+ ix)) ; increment for next time (setq enn (entnext blk_ent)) (setq edd (entget enn)) (while (AND enn (/= (cdr (assoc 0 edd)) "SEQEND") (/= (cdr (assoc 0 edd)) "INSERT") ) (if (= (cdr (assoc 0 edd)) "ATTRIB") (progn (setq atnam (cdr (assoc 2 edd))) (setq hit nil) (foreach x namelist (if (not hit) (progn ; no match yet, keep processing (setq matchname (car x)) (if (wcmatch atnam matchname) (progn ; found exact match or wild-card match ; Change name now. Substitute in new name. (setq newed (subst (cons 2 (cadr x)) (assoc 2 edd) edd)) (entmod newed) ; update the title block instance (entupd blk_ent) (princ "\n") (princ atnam) (princ " --> ") (princ (cadr x)) (setq hit 1) ; flag that found ) ) ) ) ) ) ) ; go to next sub ent in block instance and loop back up (if (setq enn (entnext enn)) (setq edd (entget enn))) ) ) (setq ss nil) ; release the selection set ) ) (princ) ; prettier Quote
Roy_043 Posted February 27, 2017 Posted February 27, 2017 @MACNEIL: Do you want to change tagstrings or textstrings (= attribute values)? The code is for the first. Note that tagstrings are in caps. Quote
MACNEIL Posted February 27, 2017 Posted February 27, 2017 I am trying to change the tagstrings. As in the definition of the attribute, maybe this isn't the right program? See attached. Quote
Roy_043 Posted February 28, 2017 Posted February 28, 2017 @MACNEIL: Change the tagstrings in the namelist to upper case. If that does not help post a dwg. Quote
MACNEIL Posted February 28, 2017 Posted February 28, 2017 I tried yesterday with capitals and just to be sure I tried again today. I made a brand new drawing with a new block and def and still get the same result. Here's the CAD file. Thanks. TEST2.dwg @MACNEIL:Change the tagstrings in the namelist to upper case. If that does not help post a dwg. Quote
Roy_043 Posted February 28, 2017 Posted February 28, 2017 Your problem is caused by the '#' character which is a special wcmatch character that matches any single digit: (wcmatch "OLD_TAG_NAME#1" "OLD_TAG_NAME#1") => nil (wcmatch "OLD_TAG_NAME01" "OLD_TAG_NAME#1") => T (wcmatch "OLD_TAG_NAME11" "OLD_TAG_NAME#1") => T ... (wcmatch "OLD_TAG_NAME91" "OLD_TAG_NAME#1") => T (wcmatch "OLD_TAG_NAME#1" "OLD_TAG_NAME`#1") => T (escaped special character) This easiest fix is to replace: (wcmatch atnam matchname) with: (= atnam matchname) Quote
MACNEIL Posted March 3, 2017 Posted March 3, 2017 Hey, Sorry haven't had a chance to try this out until just now. I cannot get this to work still. I am more than likely misunderstanding something. Can you please take a look? (defun c:attr_rename_list ( / x_en enn edd ss slen ix atnam namelist hit blk_ent matchname newed x) ; Process all block instances on active drawing. Check each ; attribute for match on first element in list below. On any ; match, rename the attribute to the new name given in the ; second element. ; *********** ATTRIBUTE OLD versus NEW names list ****************** (setq namelist (list ; list old name and new name. Old name can contain wild cards. (wcmatch "ITEM\U+0020#" "OLD_TAG_NAME#1") => nil (wcmatch "OLD_TAG_NAME01" "OLD_TAG_NAME#1") => T (wcmatch "OLD_TAG_NAME11" "OLD_TAG_NAME#1") => T ... (wcmatch "OLD_TAG_NAME91" "OLD_TAG_NAME#1") => T (wcmatch "OLD_TAG_NAME#1" "OLD_TAG_NAME`#1") => T (escaped special character) ) ) ; ********************************************************************** ; Extract selection set of all block inserts on active drawing (setq ss (ssget "_X" '((0 . "INSERT")))) (if (/= ss nil) (progn (setq slen (sslength ss)) (setq ix 0) (while (< ix slen) (setq blk_ent (ssname ss ix)) ; get next block insert to process (setq ix (1+ ix)) ; increment for next time (setq enn (entnext blk_ent)) (setq edd (entget enn)) (while (AND enn (/= (cdr (assoc 0 edd)) "SEQEND") (/= (cdr (assoc 0 edd)) "INSERT") ) (if (= (cdr (assoc 0 edd)) "ATTRIB") (progn (setq atnam (cdr (assoc 2 edd))) (setq hit nil) (foreach x namelist (if (not hit) (progn ; no match yet, keep processing (setq matchname (car x)) (if (atnam matchname) (progn ; found exact match or wild-card match ; Change name now. Substitute in new name. (setq newed (subst (cons 2 (cadr x)) (assoc 2 edd) edd)) (entmod newed) ; update the title block instance (entupd blk_ent) (princ "\n") (princ atnam) (princ " --> ") (princ (cadr x)) (setq hit 1) ; flag that found ) ) ) ) ) ) ) ; go to next sub ent in block instance and loop back up (if (setq enn (entnext enn)) (setq edd (entget enn))) ) ) (setq ss nil) ; release the selection set ) ) (princ) ; prettier ) Also I use the unicode for space in some of my tags. Will this mess this up? Thanks! Your problem is caused by the '#' character which is a special wcmatch character that matches any single digit: (wcmatch "OLD_TAG_NAME#1" "OLD_TAG_NAME#1") => nil (wcmatch "OLD_TAG_NAME01" "OLD_TAG_NAME#1") => T (wcmatch "OLD_TAG_NAME11" "OLD_TAG_NAME#1") => T ... (wcmatch "OLD_TAG_NAME91" "OLD_TAG_NAME#1") => T (wcmatch "OLD_TAG_NAME#1" "OLD_TAG_NAME`#1") => T (escaped special character) This easiest fix is to replace: (wcmatch atnam matchname) with: (= atnam matchname) Quote
Roy_043 Posted March 3, 2017 Posted March 3, 2017 (edited) (defun c:attr_rename_list ( / elst enm i new nmeLst old ss) (setq nmeLst ; All tags must be upper case. (list ; OLD NEW (list "TAGWITH\U+00A0UNICODENONBREAKINGSPACE" "S") ; \U+00A0 = Unicode non-breaking space. (list "TAG2" "I") ) ) (if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1)))) (repeat (setq i (sslength ss)) (setq enm (ssname ss (setq i (1- i)))) (while (and (setq enm (entnext enm)) (setq elst (entget enm)) (= "ATTRIB" (cdr (assoc 0 elst))) ) (if (setq new (cadr (assoc (setq old (cdr (assoc 2 elst))) nmeLst))) (progn (entmod (subst (cons 2 new) (cons 2 old) elst)) (princ (strcat "\n" old " --> " new " ")) ) ) ) ) ) (princ) ) Edited March 3, 2017 by Roy_043 Cleaned up the code. Quote
MACNEIL Posted March 7, 2017 Posted March 7, 2017 @Roy_043 Everything is working great now, except a major problem. This is not a permanent solution, because soon as I attsync the attribute value reverts back to the original. Is there a way to do this to the tag name inside of the block? Mod please disregard my last post. Thanks you. (defun c:attr_rename_list ( / elst enm i new nmeLst old ss) (setq nmeLst ; All tags must be upper case. (list ; OLD NEW (list "TAGWITH\U+00A0UNICODENONBREAKINGSPACE" "S") ; \U+00A0 = Unicode non-breaking space. (list "TAG2" "I") ) ) (if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1)))) (repeat (setq i (sslength ss)) (setq enm (ssname ss (setq i (1- i)))) (while (and (setq enm (entnext enm)) (setq elst (entget enm)) (= "ATTRIB" (cdr (assoc 0 elst))) ) (if (setq new (cadr (assoc (setq old (cdr (assoc 2 elst))) nmeLst))) (progn (entmod (subst (cons 2 new) (cons 2 old) elst)) (princ (strcat "\n" old " --> " new " ")) ) ) ) ) ) (princ) ) Quote
Roy_043 Posted March 7, 2017 Posted March 7, 2017 (defun c:AttRenList ( / doc new tagLst) (setq tagLst ; All tags must be upper case. (list ; OLD NEW (list "TAGWITH\U+00A0UNICODENONBREAKINGSPACE" "S") ; \U+00A0 = Unicode non-breaking space. (list "TAG2" "I") ) ) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-endundomark doc) (vla-startundomark doc) (vlax-for blk (vla-get-blocks doc) (if (= :vlax-false (vla-get-isxref blk)) (vlax-for obj blk (cond ((= "AcDbBlockReference" (vla-get-objectname obj)) (if (= :vlax-true (vla-get-hasattributes obj)) (foreach att (vlax-invoke obj 'getattributes) (if (setq new (cadr (assoc (vla-get-tagstring att) tagLst))) (vla-put-tagstring att new) ) ) ) ) ((= "AcDbAttributeDefinition" (vla-get-objectname obj)) (if (setq new (cadr (assoc (vla-get-tagstring obj) tagLst))) (vla-put-tagstring obj new) ) ) ) ) ) ) (vla-endundomark doc) (princ) ) Quote
Matlin0 Posted June 2, 2023 Posted June 2, 2023 On 8/9/2010 at 10:20 AM, hosannabizarre said: (defun c:attr_rename_list ( / x_en enn edd ss slen ix atnam namelist hit blk_ent matchname newed x) ; Process all block instances on active drawing. Check each ; attribute for match on first element in list below. On any ; match, rename the attribute to the new name given in the ; second element. ; *********** ATTRIBUTE OLD versus NEW names list ****************** (setq namelist (list ; list old name and new name. Old name can contain wild cards. (list "OLD_TAG_NAME#1" "NEW_TAG_NAME#1") ; list old name and new name. (list "OLD_TAG_NAME#2" "NEW_TAG_NAME#2") (list "OLD_TAG_NAME#3" "NEW_TAG_NAME#3") (list "OLD_TAG_NAME#4" "NEW_TAG_NAME#4") (list "OLD_TAG_NAME#5" "NEW_TAG_NAME#5") ) ) ; ********************************************************************** ; Extract selection set of all block inserts on active drawing (setq ss (ssget "_X" '((0 . "INSERT")))) (if (/= ss nil) (progn (setq slen (sslength ss)) (setq ix 0) (while (< ix slen) (setq blk_ent (ssname ss ix)) ; get next block insert to process (setq ix (1+ ix)) ; increment for next time (setq enn (entnext blk_ent)) (setq edd (entget enn)) (while (AND enn (/= (cdr (assoc 0 edd)) "SEQEND") (/= (cdr (assoc 0 edd)) "INSERT") ) (if (= (cdr (assoc 0 edd)) "ATTRIB") (progn (setq atnam (cdr (assoc 2 edd))) (setq hit nil) (foreach x namelist (if (not hit) (progn ; no match yet, keep processing (setq matchname (car x)) (if (wcmatch atnam matchname) (progn ; found exact match or wild-card match ; Change name now. Substitute in new name. (setq newed (subst (cons 2 (cadr x)) (assoc 2 edd) edd)) (entmod newed) ; update the title block instance (entupd blk_ent) (princ "\n") (princ atnam) (princ " --> ") (princ (cadr x)) (setq hit 1) ; flag that found ) ) ) ) ) ) ) ; go to next sub ent in block instance and loop back up (if (setq enn (entnext enn)) (setq edd (entget enn))) ) ) (setq ss nil) ; release the selection set ) ) (princ) ; prettier ) I love finding the answer. It makes me feel alive. This was great to find and solved some of my problems. Is there a way to make it change attribute name only on a certain blockname? Quote
