Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 48
    Full Member
    AutoCAD 2009
    Nov 2008
    86
    Default Add Blocks to my own Panel
    Hello,
    Can anyone tell me how I can add blocks I have created to a Panel I have created on my Ribbon.
    I have a drawing where I have created numerous dynamic blocks, I have now created a tab on my ribbon & have created several panels from this tab e.g. Power, Fire, Containment etc
    I would like to insert buttons to each panel relating to each block, for example I would have a button in my Power panel which is called Single Socket and when I press it my single socket block from my block drawing appears and can be added.
    Thank you
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,021
    I think it would make more sense to create a custom tool palette and populate it with your blocks.
    Full Member
    AutoCAD 2009
    Nov 2008
    86
    I currently have the palette set up but in my previous employment I used the ribbon format as described above and would like to convert my current computer to this way
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    You will have to go into the CUI and in the command list portion, add a new command for the first one, after you have it set, drag that up into the panel in the first Row, create a Row if you haven't already. If that one works, then copy the first one in the command list area, modify for the next name, drag and drop, continue.
    You will need each block as its own .dwg file, pick a spot on your local drive to create a library folder, place your blocks there, use that path for the command for each one.
    Add more Rows as necessary and continue creating a command for each block, dragging and dropping in the panel you have selected.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  5. #5
    Senior Member tomhamlet's Avatar
    tomhamlet's Computer Details
    Windows 7
    DELL Desktop
    AMD phenom 2 (6 core)
    6gig
    1 gig
    1 tb
    Dell widescreen
    See details...
    tomhamlet's Discipline Details
    mechanical engineer, draftsman
    See details below.
    At Denios, we design storage and containment units for hazerdous materials. We also design cranes, racks, or whatever the customer needs.
    Mechanical 2011
    Oct 2012
    Louisville, KY
    121
    I am also trying to do something simular, how would associating the icon with the particular dwg that has the particular block desired?
  6. #6
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    tomhamlet, would you rephrase your question, I am not entirely sure what you are asking.
  7. #7
    Windows 7
    DELL Desktop
    6gig
    1 gig
    1 tb
    Dell widescreen
    See details...
    See details below.
    Mechanical 2011
    Oct 2012
    Louisville, KY
    121
    Ok. I have kind of ansered my question but still need to know more about it.
    I have made an icon on my insert palette to insert my border named "11X17-XX". AutoCAD looks for this in my C drive. At first it was not in my C drive but I eventually put it there. Now it works. So now my question here is how do I make AutoCAD search in a different drive, such as my I drive, for this border?
    Also, my current macro for this button is C^C^_INSERT 11X17-XX. This gets the border on my screen, but how would I go about satisfying AutoCAD's arguments so that when I hit my icon AutoCAD knows to place my border with the basepoint on 0,0; the scale at 1; and the rotation at 0 degrees?
  8. #8
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    I use this instead of a macro, pretty much the same, same. Obviously adjust for your folder path and file name.
    Code:
    (command ".insert" "I:/DwgLib/_TB17x11" "0,0" "1" "1" "0")
    Inserts at 0,0, X scale of 1, Y scale of 1, rotation of 0
  9. #9
    Windows 7
    DELL Desktop
    6gig
    1 gig
    1 tb
    Dell widescreen
    See details...
    See details below.
    Mechanical 2011
    Oct 2012
    Louisville, KY
    121
    It works! Thanks for the help rkent! I only have one more question. Is there a way to get this on to all of my coworkers computers without going to everyone and doing it manually?
  10. #10
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    I would look to Robert Bell for this, search on the web for
    enterprise cui robert bell
    He has a paper on the Autodesk University Augi site, it will be worth registering in order to get a hold of this paper.
    Good luck.
  1. Panel Schedules
    By GAC in forum MEP
    Last Post: 10th Nov 2012, 03:49 am
  2. Solar panel
    By Casusa in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Apr 2012, 04:02 pm
  3. Multi panel doors dynamic blocks
    By Geependo in forum AutoCAD Drawing Management & Output
    Last Post: 28th Aug 2010, 08:51 pm
  4. Signature Panel
    By BIGMIKE09281946 in forum AutoCAD Beginners' Area
    Last Post: 11th Nov 2008, 07:08 pm
  5. Panel Templates
    By cssltd in forum AutoCAD Beginners' Area
    Last Post: 5th Nov 2008, 12:52 pm
