Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Junior Member
    Revit MEP 2014
    Jan 2014
    12
    Default Autocad Solids import problem with Revit
    Hello everyone - been a long time since I was on here
    I've created a solid model using Autocad 2014 which has multiple solid entities that I want to export to Revit 2014 as individual entities.
    When I import it into Revit 2014 however the drawing comes in as a single item, and if I right click the bounding box and try to either partial or full explode it, it completely disappears.
    Is there any way of getting the entities changed from Autocad to Revit so I can add BIM information to each separate entity within Revit?
    Thanks in advance for any advice and a big "Hello" to anyone that remembers me
    Spacepig
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    What you are trying to do is not recommended practice. Revit does not like imported CAD stuff. You would be much better off creating new objects in Revit. Any families that we (the company I work for) get from external sources are fully examined and imported CAD entities are stripped from them before being used in a project. I am currently converting our entire detail library to native Revit objects. These are 2D drawings and I simplify them as much as possible before I import them. Any solids that I come across in the CAD files, I delete before importing and recreate in Revit.
    Drafting is a breeze.
    Junior Member
    Revit MEP 2014
    Jan 2014
    12
    Hi Rob
    Yes - I completely agree - however we have in excess of 50000 solids in the completed model - don't really fancy trying to re-create all them in Revit! - is there a work-around to do what I want to do?
    Many thanks
    Peter
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    There is, but I've never done it. You said that after exploding, everything disappears.
    Do you get any messages from Revit?
    Have you checked visibility settings, different views, etc.?
    Can you post a small portion of the file that exhibits the same behavior?
  5. #5
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    I'll back Rob that he is 100% on the money with his advice.
    Quote Originally Posted by Spacepig62 View Post
    What's the motivation behind using Revit? Is the demand coming from another source, or are you creating existing AutoCAD content that you/your company has built through the years? I can tell you first hand that importing 50,000 will take longer and have practically zero functionality than simply recreating 50,000 solids in Revit. Not only that, you can't do anything with an imported DWG file, and if you explode any imported Solid then you still have to jump through hoops to make it parametric and apply parameters.
    Based on your two posts, here's my assessment:
    • If an outside source is demanding a Revit model, then give them a true Revit model. If I asked for a DWG file, last thing I want is something drawn in Microsoft Paint and imported into AutoCAD as a JPG. That would be a fair comparison.
    • If you are attempting to recreate your own existing content in Revit, then do so from scratch.
    Hope this helps!
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  6. #6
    Junior Member
    Revit MEP 2014
    Jan 2014
    12
    I can't remember how to upload images or the dwg, however if I create a drawing in Autocad with 3 solids (say a pyramic, a box and a sphere), save it and then go to revit / open system template / import cad to bring in the drawing, then I get the 3 elements as a single entity hence the bounding box if I hover over any of them....when I try a partial or full explode I get a warning saying "Import contained 3D data or points which can't be exploded. Only 2D data was exploded.
    If you can tell me how to post bmps or dwg I can upload what I'm seeing
    Thanks again folks
    Peter
  7. #7
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    No need to upload anything. If you're importing DWG files into Revit, you're doing it all wrong to begin with. Re-read my list above.
  8. #8
    Junior Member
    Revit MEP 2014
    Jan 2014
    12
    I'm well aware of the "proper" way to do it - I'm trying to find a way around an issue we have at the moment with people who know Revit better than I do - please refer to MY question and answer if there is a way to do it or not please
  9. #9
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    My apologies in advance if I have struck a nerve. That was not my intention.
    My full intention, as a seasoned Revit user who has been through all the growing pains, is to give it to you "straight" - as most people would want it. I (or any experienced Revit user) will not promote any instruction on exploding DWG files in the Revit platform. Autodesk themselves have admitted that it's only a matter of when you will have a corrupt Revit model from this procedure, and the tool is there as a very last and only resort, or a temporary and sacrificial way of transitioning geometry from one platform to another.
    The tool is there, use it as you wish: but be aware of the consequences that will follow.
    - Tannar
  10. #10
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    On a simpler level from a not so seasoned user, 2D solids give you the same message. That is why I don't import them. Dimensions don't import so well either, so I explode them (he, he, he) and delete the solids that were once arrowheads before importing. Think of it as trying to convert an image to a .dwg in AutoCAD. It can be done but the results are always too messed up to fix. The simpler the entities the better the result in Revit and vice versa.
  1. Problem after import from CATIA to Autocad
    By Skyuro in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Jan 2014, 08:59 pm
  2. Replies: 13
    Last Post: 9th May 2013, 08:53 pm
  3. Progecad convert into solids, so then import into blender
    By lenoxmo in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jun 2011, 02:53 am
  4. Import AutocAD 3DFACE into Revit
    By David Bethel in forum Revit General
    Last Post: 22nd Jan 2011, 08:29 pm
  5. import solidworks to revit
    By FIFTHTEXAS in forum SolidWorks
    Last Post: 2nd Aug 2008, 02:50 pm
Tags for this Thread
