Fracture Posted February 11, 2015 Share Posted February 11, 2015 I've made this script to adjust the extensions on our rectangular transition ducts but it doesn't want to work for me. Everything is fine if I keep it simple and leave out the " Or "Ductmate 35" " part but for this to work, I will need the or statement. Anyways, here's the script... select item.cid case 2 dim extin = item.dim[6].numvalue dim extout = item.dim[7].numvalue dim con1 = item.connector[1].value dim con2 = item.connector[2].value if ( con1 = ("TDC" or "Ductmate 35") ) and (extin < 2 ) then item.dim[6].value = 2 end if if ( con2 = ("TDC" or "Ductmate 35") ) and (extout < 2 ) then item.dim[7].value = 2 end if if ( con1 <> ("TDC" or "Ductmate 35") ) and (extin < 0.5 ) then item.dim[6].value = 0.5 end if if ( con2 <> ("TDC" or "Ductmate 35") ) and (extout < 0.5 ) then item.dim[7].value = 0.5 end if item.update() end select Can anyone spot the problem? I'm hoping its an embarrassingly simple one. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 12, 2015 Share Posted February 12, 2015 In lisp you would need another pair of brakets I think its the same here if ((......... Quote Link to comment Share on other sites More sharing options...
Fracture Posted February 12, 2015 Author Share Posted February 12, 2015 Do you mean it should look something like this? if ( con1 = ("TDC" or "Ductmate 35") ) and [color="red"]((extin < 2 ))[/color] then item.dim[6].value = 2 end if I don't think putting something into two sets of brackets ((X)) would change the logic of the statement. I tried it just to be safe and there was no change. Thanks for trying though Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 13, 2015 Share Posted February 13, 2015 Dont program with this type of code method try this if (( con1 = ("TDC" or "Ductmate 35") ) and [color=red](extin < 2 ))[/color] then Quote Link to comment Share on other sites More sharing options...
Fracture Posted February 13, 2015 Author Share Posted February 13, 2015 Thanks for the tip. That actually looks a lot better and I changed my script to use the same format. Unfortunately it didn't fix the problem, but I think I figured out what is happening. take a look at these two pieces of code... if ( con2 = ("TDC" or "Ductmate 35") ) and (extout < 2 ) then item.dim[7].value = 2 end if ;;;which is followed by... if ( con2 <> ("TDC" or "Ductmate 35") ) and (extout < 0.5 ) then item.dim[7].value = 0.5 end if I think that the or statement may be working, but then I have a second line of code which is supposed to handle what happens if con2 does not equal TDC or Ductmate 35. I didn't take into account that this statement would be true whether the connector were TDC or Ductmate 35 because it can't be both. I probalby should of made that into an "and" statement. Still, that would take a slightly chunkier piece of code. Do you know how I could use an else statement for this? I tried a few variations but kept getting errors I couldn't understand/fix. This is what my script now looks like... select item.cid case 2 dim extin = item.dim[6].numvalue dim extout = item.dim[7].numvalue dim con1 = item.connector[1].value dim con2 = item.connector[2].value if (( con1 = ("TDC" or "Ductmate 35")) and (extin < 2 )) then item.dim[6].numvalue = 2 elseif extin < 0.5 then item.dim[6].numvalue = 0.5 end if if (( con2 = ("TDC" or "Ductmate 35")) and (extout < 2 )) then item.dim[7].numvalue = 2 elseif extout < 0.5 then item.dim[7].numvalue = 0.5 end if item.update() end select Can you spot any syntax errors in that last script? By the way, thanks for all of your help so far. Quote Link to comment Share on other sites More sharing options...
