ahazen Posted June 16, 2015 Share Posted June 16, 2015 I have hyperlinks to attach with names like 360-001.html or http://www.website.com/360-001. I was wondering if I could get help automating the hyperlinking process for these blocks. So block with attribute "001" would automatically be hyperlinked with http://www.website.com/360-001 when the command is run. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 17, 2015 Share Posted June 17, 2015 You can get at a blocks attribute value pretty easy using block name, tag name or pick a block and tag name, lots of example code here. In a lisp use -hyperlink and answer prompts. (setq obj (car (entsel "Pick block"))) (foreach att (vlax-invoke (vlax-ename->vla-object obj) 'getattributes) (if (= "PROJ_NO" (strcase (vla-get-tagstring att))) ; change to your tag name (setq val (vla-get-textstring att )) ) ; end if ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 17, 2015 Share Posted June 17, 2015 Please refer to your thread here. Quote Link to comment Share on other sites More sharing options...
ahazen Posted June 17, 2015 Author Share Posted June 17, 2015 Thanks! RonJon helped me out. Learning from what he did now Quote Link to comment Share on other sites More sharing options...
