Results 1 to 2 of 2
    Forum Newbie
    Solidworks 2016
    Jan 2016
    Exclamation Modify Curvature of imported surfaces
    I am coming up to the 3 year mark of working with Solidworks (in education not professionally!).
    I have an imported surface that I have made some modifications to for a hinge mechanism. It has come to my attention that I have made the surface 'too curved', I have spent hours trying to adjust the curves on the two sides - I only need the two sides curved around 25% less (doesn't need to be dimensionally perfect at all! just look right!
    If anyone could shed some light on how I would go about this... hopefully without re-doing the whole part again as I have several other pieces I need to attempt the procedure on also!
    See sample.
    If you would like to see the part, I can provide you with the upload link as it is too large to upload unfortunately
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    Ideally you would want it controlled by sketches, but since you are dealing with an import probably the best option is Flex. Its a tricky tool to use so you will need to play around with it a lot with the "clipping planes". What i would likely do is hack your model just past the mounting point and draw the rest of it so i had better control over it. It doesn't look to be an overly complex shape from this view but a single image can be deceiving.
    Start with the flex tool and see if that gets you the results you need. If not and you need help redoing the shape post back up.
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks17,Mastercam2017, fusion360, Inventor 2017, HSMworksUltimate
    http://www.solidbox.tv Free and Paid Tutorials for Solidworks, Mastercam and Fusion360
    http://www.mysolidbox.com/ CAD and CAM optimized workstations and laptops
  1. What Is Equal Curvature
    By basty in forum SolidWorks
    Last Post: 21st Jan 2015, 08:27 pm
  2. Zebra, Draft, Surface, Section & Curvature Analysis
    By Aboodios in forum Autodesk Inventor
    Last Post: 19th Dec 2010, 09:53 pm
  3. Modify measures from an imported DXF
    By Lugia in forum AutoCAD Beginners' Area
    Last Post: 9th Mar 2010, 11:54 pm
  4. Reversing Pline Arc Curvature
    By milnehouse in forum AutoCAD Drawing Management & Output
    Last Post: 11th May 2005, 05:25 pm
  5. Need help drawing a pipe curvature.
    By Cyclopean in forum AutoCAD General
    Last Post: 11th Nov 2002, 03:00 pm
Tags for this Thread
